[petsc-users] Performance of PETSc TS solver
Fri Aug 30 17:51:51 CDT 2013
Also, which TS method are you using? Rosenbrock methods will amortize a lot
of assembly cost by reusing the matrix for several stages.
On Aug 30, 2013 3:48 PM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
>    I would next parallelize the function evaluation since it is the single
> largest consumer of time and should presumably be faster in parallel. After
> that revisit the -log_summary again to decide if the Jacobian evaluation
> can be improved.
>    Barry
> On Aug 30, 2013, at 5:28 PM, "Jin, Shuangshuang" <
> Shuangshuang.Jin at pnnl.gov> wrote:
> > Hello, I'm trying to update some of my status here. I just managed to"
> _distribute_ the work of computing the Jacobian matrix" as you suggested,
> so each processor only computes a part of elements for the Jacobian matrix
> instead of a global Jacobian matrix. I observed a reduction of the
> computation time from 351 seconds to 55 seconds, which is much better but
> still slower than I expected given the problem size is small. (4n functions
> in IFunction, and 4n*4n Jacobian matrix in IJacobian, n = 288).
> > I looked at the log profile again, and saw that most of the computation
> time are still for Functioan Eval and Jacobian Eval:
> > TSStep               600 1.0 5.6103e+01 1.0 9.42e+0825.6 3.0e+06 2.9e+02
> 7.0e+04 93100 99 99 92 152100 99 99110   279
> > TSFunctionEval      2996 1.0 2.9608e+01 4.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 3.0e+04 30  0  0  0 39  50  0  0  0 47     0
> > TSJacobianEval      1796 1.0 2.3436e+01 1.0 0.00e+00 0.0 5.4e+02 3.8e+01
> 1.3e+04 39  0  0  0 16  64  0  0  0 20     0
> > Warning -- total time of even greater than time of entire stage --
> something is wrong with the timer
> > SNESSolve            600 1.0 5.5692e+01 1.1 9.42e+0825.7 3.0e+06 2.9e+02
> 6.4e+04 88100 99 99 84 144100 99 99101   281
> > SNESFunctionEval    2396 1.0 2.3715e+01 3.4 1.04e+06 1.0 0.0e+00 0.0e+00
> 2.4e+04 25  0  0  0 31  41  0  0  0 38     1
> > SNESJacobianEval    1796 1.0 2.3447e+01 1.0 0.00e+00 0.0 5.4e+02 3.8e+01
> > SNESLineSearch      1796 1.0 1.8313e+01 1.0 1.54e+0831.4 4.9e+05 2.9e+02
> 2.5e+04 30 16 16 16 33  50 16 16 16 39   139
> > KSPGMRESOrthog      9090 1.0 1.1399e+00 4.1 1.60e+07 1.0 0.0e+00 0.0e+00
> 9.1e+03  1  3  0  0 12   2  3  0  0 14   450
> > KSPSetUp            3592 1.0 2.8342e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 3.0e+01  0  0  0  0  0   0  0  0  0  0     0
> > KSPSolve            1796 1.0 2.3052e+00 1.0 7.87e+0825.2 2.5e+06 2.9e+02
> 2.0e+04  4 84 83 83 26   6 84 83 83 31  5680
> > PCSetUp             3592 1.0 9.1255e-02 1.7 6.47e+05 2.5 0.0e+00 0.0e+00
> 1.8e+01  0  0  0  0  0   0  0  0  0  0   159
> > PCSetUpOnBlocks     1796 1.0 6.6802e-02 2.3 6.47e+05 2.5 0.0e+00 0.0e+00
> 1.2e+01  0  0  0  0  0   0  0  0  0  0   217
> > PCApply            10886 1.0 2.6064e-01 1.3 4.70e+06 1.5 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   1  1  0  0  0   481
> > I was wondering why SNESFunctionEval and SNESJacobianEval took over 23
> seconds each, however, the KSPSolve only took 2.3 seconds, which is 10
> times faster. Is this normal? Do you have any more suggestion on how to
> reduce the FunctionEval and JacobianEval time?
> > (Currently in IFunction, my f function is sequentially formulated; in
> IJacobian, the Jacobian matrix is distributed formulated).
> > Thanks,
> > Shuangshuang
> > -----Original Message-----
> > From: Jed Brown [mailto:five9a2 at gmail.com] On Behalf Of Jed Brown
> > Sent: Friday, August 16, 2013 5:00 PM
> > To: Jin, Shuangshuang; Barry Smith; Shri (abhyshr at mcs.anl.gov)
> > Cc: petsc-users at mcs.anl.gov
> > Subject: RE: [petsc-users] Performance of PETSc TS solver
> > "Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
> >>  // This proves to be the most time-consuming block in the computation:
> >>  // Assign values to J matrix for the first 2*n rows (constant values)
> >>  ... (skipped)
> >>  // Assign values to J matrix for the following 2*n rows (depends on X
> values)
> >>  for (i = 0; i < n; i++) {
> >>    for (j = 0; j < n; j++) {
> >>       ...(skipped)
> > This is a dense iteration.  Are the entries really mostly nonzero?  Why
> is your i loop over all rows instead of only over xstart to xstart+xlen?
> >>  for (i = 0; i < 4*n; i++) {
> >>    rowcol[i] = i;
> >>  // Compute function over the locally owned part of the grid
> >>  for (i = xstart; i < xstart+xlen; i++) {
> >>    ierr = MatSetValues(*B, 1, &i, 4*n, rowcol, &J[i][0],
> >> INSERT_VALUES); CHKERRQ(ierr);
> > This is seems to be creating a distributed dense matrix from a dense
> matrix J of the global dimension.  Is that correct?  You need to
> _distribute_ the work of computing the matrix entries if you want to see a
> speedup.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130830/e6a12600/attachment-0001.html>
