[petsc-users] IJacobian "PetscReal a"
Jin, Shuangshuang Shuangshuang.Jin at pnnl.gov
Thu Aug 29 16:01:48 CDT 2013
Hello, when I look at IJacobian function in the example: http://www.mcs.anl.gov/petsc/petsc-current/src/ts/examples/tutorials/ex19.c
static PetscErrorCode IJacobian(TS ts,PetscReal t,Vec X,Vec Xdot,PetscReal a,Mat *A,Mat *B,MatStructure *flag,void *ctx)
  PetscErrorCode ierr;
  PetscInt       rowcol[] = {0,1};
  PetscScalar    *x,J[2][2];
  PetscFunctionBeginUser;
  ierr    = VecGetArray(X,&x);CHKERRQ(ierr);
  J[0][0] = a;    J[0][1] = -1.;
  J[1][0] = 1.;   J[1][1] = -1. + x[1]*x[1];
  ierr    = MatSetValues(*B,2,rowcol,2,rowcol,&J[0][0],INSERT_VALUES);CHKERRQ(ierr);
  ierr    = VecRestoreArray(X,&x);CHKERRQ(ierr);
  ierr = MatAssemblyBegin(*A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
  ierr = MatAssemblyEnd(*A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
  if (*A != *B) {
    ierr = MatAssemblyBegin(*B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
    ierr = MatAssemblyEnd(*B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
  *flag = SAME_NONZERO_PATTERN;
  PetscFunctionReturn(0);
There's a PetscReal a. Is it a constant? And if the value of a known outside of the IJacobian function, saying the main() part.
If it is, then as shown in this example, J[0][0] = a; J[0][1] = -1.; J[1][0] = 1.; are constant through all the iterations. How can I use MatRetrieveValues(*A) and MatStoreValues(*A) to reuse them?
I'm asking this question because I have a large Jacobian matrix, but half of the matrix contains constant values. However, I don't know what's "PetscReal a" when I try to use it to compute my constant elements of Jacobian matrix which doesn't depend on the value of x at all.
Shuangshuang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130829/414e1c0c/attachment.html>
