[petsc-users] Optimized run crashes on one machine but not another
Garnet Vaz garnet.vaz at gmail.com
Wed Aug 28 15:32:07 CDT 2013
Hi Matt,
I just ran git clone https://bitbucket.org/petsc/petsc and built
the debug build. The code still crashes now with a slightly
different back trace. It looks like a request for a large (wrong)
amount of memory which could be from some unitialized value
I have lying about. I will look into this some more.
Attached is the configure.log file for my current build.
Garnet
On Wed, Aug 28, 2013 at 1:08 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 28, 2013 at 3:04 PM, Garnet Vaz <garnet.vaz at gmail.com> wrote:
>> Hi Matt,
>> I just built the 3.4.2 release in the hope that it will work. It was
>> working fine for the 'next'
>> branch until a recent update last night. I updated my laptop/desktop with
>> a 1/2 hour
>> gap which caused crashes in one build but not in the other. Hence, I
>> moved to the
>> 3.4.2 release.
>> I will rebuild using the current 'next' and let you know if there are any
>> problems.
> Can you send configure.log? I built against OpenMPI and it looks like a
> get a similar error
> which is not there with MPICH. Trying to confirm now.
>   Matt
>> Thanks.
>> Garnet
>> On Wed, Aug 28, 2013 at 12:51 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Wed, Aug 28, 2013 at 1:58 PM, Garnet Vaz <garnet.vaz at gmail.com>wrote:
>>>> Hi Matt,
>>>> Attached is a folder containing the code and a sample mesh.
>>> I have built and run it here with the 'next' branch from today, and it
>>> does not crash.
>>> What branch are you using?
>>>     Matt
>>>> Thanks for the help.
>>>> Garnet
>>>> On Wed, Aug 28, 2013 at 11:43 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Wed, Aug 28, 2013 at 12:52 PM, Garnet Vaz <garnet.vaz at gmail.com>wrote:
>>>>>> Thanks Jed. I did as you told and the code finally crashes on both
>>>>>> builds. I installed the 3.4.2 release now.
>>>>>> The problem now seems to come from DMPlexDistribute(). I have two
>>>>>> versions to load the mesh. One creates a mesh using Triangle
>>>>>> from PETSc and the other loads a mesh using
>>>>>> DMPlexCreateFromCellList().
>>>>>> Is the following piece of code for creating a mesh using Triangle
>>>>>> right?
>>>>> Okay, something is really very wrong here. It is calling
>>>>> EnlargePartition(), but for
>>>>> that path to be taken, you have to trip and earlier exception. It
>>>>> should not be possible
>>>>> to call it. So I think you have memory corruption somewhere.
>>>>> Can you send a sample code we can run?
>>>>>   Thanks,
>>>>>       Matt
>>>>>>   ierr =
>>>>>> DMPlexCreateBoxMesh(comm,2,interpolate,&user->dm);CHKERRQ(ierr);
>>>>>>   if (user->dm) {
>>>>>>     DM        refinedMesh     = NULL;
>>>>>>     DM        distributedMesh = NULL;
>>>>>>     ierr =
>>>>>> DMPlexSetRefinementLimit(user->dm,refinementLimit);CHKERRQ(ierr);
>>>>>>     ierr =
>>>>>> DMRefine(user->dm,PETSC_COMM_WORLD,&refinedMesh);CHKERRQ(ierr);
>>>>>>     if (refinedMesh) {
>>>>>>       ierr     = DMDestroy(&user->dm);CHKERRQ(ierr);
>>>>>>       user->dm = refinedMesh;
>>>>>>     ierr   =
>>>>>> DMPlexDistribute(user->dm,"chaco",1,&distributedMesh);CHKERRQ(ierr);
>>>>>>     if (distributedMesh) {
>>>>>>       user->dm  = distributedMesh;
>>>>>> Using gdb, the code gives a SEGV during distribution. The backtrace
>>>>>> when the fault
>>>>>> occurs points to an invalid pointer for ISGetIndices(). Attached is a
>>>>>> screenshot of the
>>>>>> gdb backtrace.
>>>>>> Do I need to set up some index set here?
>>>>>> The same error occurs when trying to distribute a mesh using
>>>>>> Garnet
>>>>>> On Wed, Aug 28, 2013 at 6:38 AM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>>>> Garnet Vaz <garnet.vaz at gmail.com> writes:
>>>>>>> > Hi,
>>>>>>> > I just rebuilt PETSc on both my laptop and my desktop.
>>>>>>> > On both machines the output of >grep GIT configure.log
>>>>>>> >         Defined "VERSION_GIT" to
>>>>>>> > ""d8f7425765acda418e23a679c25fd616d9da8153""
>>>>>>> >         Defined "VERSION_DATE_GIT" to ""2013-08-27 10:05:35 -0500""
>>>>>>> Thanks for the report.  Matt just merged a bunch of DMPlex-related
>>>>>>> branches (about 60 commits in total).  Can you 'git pull && make' to
>>>>>>> let
>>>>>>> us know if the problem is still there?  (It may not fix the issue,
>>>>>>> but
>>>>>>> at least we'll be debugging current code.)
>>>>>>> When dealing with debug vs. optimized issues, it's useful to
>>>>>>> configure
>>>>>>> --with-debugging=0 COPTFLAGS='-O2 -g'.  This allows valgrind to
>>>>>>> include
>>>>>>> line numbers, but it (usually!) does not affect whether the error
>>>>>>> occurs.
>>>>>>> > My code runs on both machines in the debug build without causing
>>>>>>> > any problems. When I try to run the optimized build, the code
>>>>>>> crashes
>>>>>>> > with a SEGV fault on my laptop but not on the desktop. I have built
>>>>>>> > PETSc using the same configure options.
>>>>>>> > I have attached the outputs of valgrind for both my laptop/desktop
>>>>>>> for
>>>>>>> > both the debug/opt builds. How can I figure out what differences
>>>>>>> are
>>>>>>> > causing the errors in one case and not the other?
>>>>>>> It looks like an uninitialized variable.  Debug mode often ends up
>>>>>>> initializing local variables where as optimized leaves junk in them.
>>>>>>> Stack allocation alignment/padding is also often different.
>>>>>>> Unfortunately, valgrind is less powerful for debugging stack
>>>>>>> corruption,
>>>>>>> so the uninitialized warning is usually the best you get.
>>>>>> Regards,
>>>>>> Garnet
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Regards,
>>>> Garnet
>>> experiments lead.
>>> -- Norbert Wiener
>> Regards,
>> Garnet
> experiments lead.
> -- Norbert Wiener
Garnet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130828/81949437/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130828/81949437/attachment-0001.bin>
