[petsc-users] Optimized run crashes on one machine but not another
Garnet Vaz garnet.vaz at gmail.com
Wed Aug 28 13:58:44 CDT 2013
Hi Matt,
Attached is a folder containing the code and a sample mesh.
Thanks for the help.
Garnet
On Wed, Aug 28, 2013 at 11:43 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 28, 2013 at 12:52 PM, Garnet Vaz <garnet.vaz at gmail.com> wrote:
>> Thanks Jed. I did as you told and the code finally crashes on both
>> builds. I installed the 3.4.2 release now.
>> The problem now seems to come from DMPlexDistribute(). I have two
>> versions to load the mesh. One creates a mesh using Triangle
>> from PETSc and the other loads a mesh using DMPlexCreateFromCellList().
>> Is the following piece of code for creating a mesh using Triangle right?
> Okay, something is really very wrong here. It is calling
> EnlargePartition(), but for
> that path to be taken, you have to trip and earlier exception. It should
> not be possible
> to call it. So I think you have memory corruption somewhere.
> Can you send a sample code we can run?
>   Thanks,
>       Matt
>>   ierr = DMPlexCreateBoxMesh(comm,2,interpolate,&user->dm);CHKERRQ(ierr);
>>   if (user->dm) {
>>     DM        refinedMesh     = NULL;
>>     DM        distributedMesh = NULL;
>>     ierr =
>> DMPlexSetRefinementLimit(user->dm,refinementLimit);CHKERRQ(ierr);
>>     ierr = DMRefine(user->dm,PETSC_COMM_WORLD,&refinedMesh);CHKERRQ(ierr);
>>     if (refinedMesh) {
>>       ierr     = DMDestroy(&user->dm);CHKERRQ(ierr);
>>       user->dm = refinedMesh;
>>     ierr   =
>> DMPlexDistribute(user->dm,"chaco",1,&distributedMesh);CHKERRQ(ierr);
>>     if (distributedMesh) {
>>       user->dm  = distributedMesh;
>> Using gdb, the code gives a SEGV during distribution. The backtrace when
>> the fault
>> occurs points to an invalid pointer for ISGetIndices(). Attached is a
>> screenshot of the
>> gdb backtrace.
>> Do I need to set up some index set here?
>> The same error occurs when trying to distribute a mesh using
>> Garnet
>> On Wed, Aug 28, 2013 at 6:38 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> Garnet Vaz <garnet.vaz at gmail.com> writes:
>>> > Hi,
>>> > I just rebuilt PETSc on both my laptop and my desktop.
>>> > On both machines the output of >grep GIT configure.log
>>> >         Defined "VERSION_GIT" to
>>> > ""d8f7425765acda418e23a679c25fd616d9da8153""
>>> >         Defined "VERSION_DATE_GIT" to ""2013-08-27 10:05:35 -0500""
>>> Thanks for the report.  Matt just merged a bunch of DMPlex-related
>>> branches (about 60 commits in total).  Can you 'git pull && make' to let
>>> us know if the problem is still there?  (It may not fix the issue, but
>>> at least we'll be debugging current code.)
>>> When dealing with debug vs. optimized issues, it's useful to configure
>>> --with-debugging=0 COPTFLAGS='-O2 -g'.  This allows valgrind to include
>>> line numbers, but it (usually!) does not affect whether the error
>>> occurs.
>>> > My code runs on both machines in the debug build without causing
>>> > any problems. When I try to run the optimized build, the code crashes
>>> > with a SEGV fault on my laptop but not on the desktop. I have built
>>> > PETSc using the same configure options.
>>> > I have attached the outputs of valgrind for both my laptop/desktop for
>>> > both the debug/opt builds. How can I figure out what differences are
>>> > causing the errors in one case and not the other?
>>> It looks like an uninitialized variable.  Debug mode often ends up
>>> initializing local variables where as optimized leaves junk in them.
>>> Stack allocation alignment/padding is also often different.
>>> Unfortunately, valgrind is less powerful for debugging stack corruption,
>>> so the uninitialized warning is usually the best you get.
>> Regards,
>> Garnet
> experiments lead.
> -- Norbert Wiener
Garnet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130828/2015beb0/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130828/2015beb0/attachment-0001.bin>
