[petsc-users] Setting block size for MPI vectors
Tue Aug 27 17:23:50 CDT 2013
On Aug 27, 2013, at 4:57 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> Thanks Barry. Yes, I tried that sequence and it works. But curiously
> if I call VecSetBlockSize after VecSetType, it does fails with the
> same error.
  Yupe. Because the SetType() function is where the construction actually takes place (in C++ the object is instantiated).
> Would it be useful to take block size as a user input in VecCreateMPI
> to be consistent with VecCreateMPIWithArray ? Just a thought. For now,
> I will stick with the long winded way.
   We've debated back and forth this. The WithArray() version has to take the block size because it has to instantiate the vector at that point because it needs a place to put the array pointer.
   Our longer term plan is that most PETSc programs would not directly be creating Vecs and Mats with VecCreate… or MatCreate… rather they would create a DM and then use the DM object to create the appropriately laid out vectors and matrices for the users and solvers with DMCreateGlobalVector() etc.
   Barry
> Vijay
> On Tue, Aug 27, 2013 at 4:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   You need to use the "long winded" construction of vectors to add these options. For example,
>>    VecCreate()
>>    VecSetBlockSize()
>>    VecSetSizes()
>>    VecSetType()
>>  the reason is that the Vec may be constructed differently based on these options but the VecCreateMPI() is suppose to produce an already constructed Vec.
>>   Barry
>> On Aug 27, 2013, at 4:45 PM, "Vijay S. Mahadevan" <vijay.m at gmail.com> wrote:
>>> I am trying to create an MPI vector and then trying to set the block
>>> size after the initial creation. But I receive an error in
>>> PetscLayoutSetBlockSize. Since there is no explicit block size
>>> argument during construction, I call VecSetBlockSize afterwards. The
>>> relevant code and error are below.
>>> Is there an alternate call to set the block size to the vector so that
>>> VecSetValuesBlocked will work correctly ? If there is no current way
>>> to do this, that's fine and I can try to get the local array and set
>>> the values accordingly.
>>> Code:
>>> ierr = VecCreateMPI(PETSC_COMM_WORLD, 10, PETSC_DECIDE, &x);CHKERRQ(ierr);
>>> ierr = VecSetBlockSize(x, 2);CHKERRQ(ierr);
>>> ierr = VecSetFromOptions(x);CHKERRQ(ierr);
>>> Relevant errors:
>>> 0]PETSC ERROR: Arguments are incompatible!
>>> [0]PETSC ERROR: Cannot change block size 1 to 2!
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: Petsc Development GIT revision:
>>> 0799ffdeffb47ef0458c1305293fae28c4d2cd92  GIT Date: 2013-08-01
>>> 06:36:16 +0800
>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: ./ex1 on a arch-darwin-cxx-debug named
>>> anlextwls002-168.wl.anl-external.org by mahadevan Tue Aug 27 16:37:18
>>> 2013
>>> [0]PETSC ERROR: Libraries linked from /opt/petsc-dbg/lib
>>> [0]PETSC ERROR: Configure run at Wed Jul 31 18:03:46 2013
>>> [0]PETSC ERROR: Configure options --prefix=/opt/petsc-dbg
>>> PETSC_ARCH=arch-darwin-cxx-debug --download-scalapack=1
>>> --download-blacs=1
>>> --with-mumps-dir=/Users/mahadevan/source/MUMPS_4.10.0-p3
>>> --download-hypre=1 --with-metis=1 --with-parmetis=1
>>> --known-mpi-shared-libraries=1
>>> --with-blas-lapack-lib=/System/Library/Frameworks/vecLib.framework/vecLib
>>> --with-c++-support=1 --with-c-support=1 --with-cc=mpicc
>>> --with-clanguage=C++ --with-moab-dir=/opt/moab
>>> --with-dynamic-loading=1 --with-fc=mpif90 --with-fortran=1
>>> --with-mpi=1 --with-shared-libraries=1 --with-valgrind=1
>>> --with-valgrind-dir=/opt/local --with-cc=mpicc --with-cxx=mpicxx
>>> COPTFLAGS="-g -fPIC" CXXOPTFLAGS="-g -fPIC" FOPTFLAGS="-g -fPIC"
>>> --with-metis-dir=/usr/local --with-parmetis-dir=/usr/local
>>> --with-netcdf-dir=/usr/local --with-zoltan=1
>>> --with-zoltan-lib="-L/usr/local/lib -lptscotch -lscotch -lscotchmetis
>>> -lscotcherr -lscotcherrexit -lzoltan"
>>> --with-zoltan-include=/usr/local/include --with-hdf5
>>> --with-hdf5-include=/usr/local/include
>>> --with-hdf5-lib="-L/usr/local/lib -lhdf5_fortran -lhdf5"
>>> --with-netcdf-dir=/usr/local --with-cmake=/opt/local/bin/cmake
>>> --with-x-dir=/opt/local
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: PetscLayoutSetBlockSize() line 459 in
>>> /Users/mahadevan/source/petsc-dev/src/vec/is/utils/pmap.c
>>> [0]PETSC ERROR: VecSetBlockSize() line 1471 in
>>> /Users/mahadevan/source/petsc-dev/src/vec/vec/interface/vector.c
>>> [0]PETSC ERROR: main() line 32 in src/vec/vec/examples/tests/ex1.c
>>> Thanks,
>>> Vijay
