[petsc-users] GAMG and linear elasticity
Tue Aug 27 15:15:10 CDT 2013
Tabrez Ali <stali at geology.wisc.edu> writes:
> Hello
> What is the proper way to use GAMG on a vanilla 3D linear elasticity
> problem. Should I use
> -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1
Yeah, and only the first of these is needed because the others are
default with -pc_type gamg.
> -pc_type fieldsplit -pc_fieldsplit_block_size 3 -fieldsplit_pc_type gamg
> -fieldsplit_pc_gamg_type agg -fieldsplit_pc_gamg_agg_nsmooths 1
> Do these options even make sense? With the second set of options the %
> increase in number of iterations with increasing problem size is lower
> than the first but not optimal.
And it's probably more expensive because it has to do inner solves.
Also, if you have less compressible regions, it will get much worse.
> Also, ksp/ksp/examples/ex56 performs much better in that the number of
> iterations remain more or less constant unlike what I see with my own
> problem. What am I doing wrong?
You probably forgot to set the near null space.  You can use
MatSetNearNullSpace (and maybe MatNullSpaceCreateRigidBody) or the more
hacky (IMO) PCSetCoordinates.  It's important to have translational
*and* rotational modes in the near null space that GAMG uses to build a
coarse space.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130827/e4fb1e28/attachment.pgp>
