[petsc-users] Mat Destroy
Sun Aug 25 07:41:48 CDT 2013
On Sun, Aug 25, 2013 at 7:38 AM, Michael Povolotskyi <mpovolot at purdue.edu>wrote:
> On 8/23/2013 7:37 PM, Jed Brown wrote:
>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>     We call free() at that point. But not that in Unix this does not
>>>     mean the memory is returned to the operating system so you will not
>>>     see the process memory go down.  If you then allocate new objects
>>>     they will reuse this memory.
>> Also note that MatDestroy only releases a references, so if another
>> object still holds a reference to your matrix, nothing will be freed.
> Thank you!
> Just to clarify: if a code reads like this:
> Mat A;
> MatCreate(MPI_COMM_WORLD, &A);
> Mat B = A;
> MatDestroy(&B);
> Will the free() function be called for the memory that contains the matrix
> data in this case?
Yes, it will. You might want
Mat B = A;
PetscObjectReference((PetscObject) B);
so that you also need
MatDestroy(B);
    Matt
> Thank you,
> Michael.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130825/e3b721c3/attachment.html>
