[petsc-users] A problem with sizeof grid
Sat Aug 24 09:12:28 CDT 2013
On Aug 24, 2013, at 5:19 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Aug 24, 2013 at 2:54 AM, Zhang <zyzhang at nuaa.edu.cn> wrote:
> Hi,
> I ran my 3d structured CFD code for a cavity flow with different grid size from 20x20x20 to 80x80x80. Whether fast or not, all they converged and gave me the expected result.
> but when I tried with 120x120x120 grid, errors appeared as follows. Since I believe my physical memory is large enough for these test. So I just wonder what really happened with the GMRES solver + hypre PC. I hope you may leave me a hint. Thanks.
> This is a question for the Hypre list. It looks like out of memory errors.
   Since this occurs in the PCApply_Hypre() it is less likely to be a memory problem (by then most of the memory setup has occurred). The hypre error code of 1 is HYPRE_ERROR_GENERIC  which is not really useful :-)
   We need to get a better handle on exactly where the error occurs in hypre.
   Please do the following:
     switch to another PETSC_ARCH where you will build a debug version of PETSc, for example export PETSC_ARCH=arch-debug
     edit config/PETSc/packages/hypre.py and locate the line     args.append('--without-superlu') add a new line args.append('--with-print-errors') immediately after it.
    save the file
    run the same configure command you ran before but this time WITHOUT --with-debugging=0
     then run make to build the PETSc libraries
     then recompile your program
     run your program as before. When it hits the hypre error hypre should print some messages about exactly where it hit the problem. Send them to us.
     You can also run the program under valgrind and see if it reports any memory corruption errors. http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
    Barry
   Thanks for the report. Because of it I will add the hypre ability to print the error messages to PETSc's debug build to make it easier to track down problems like this.
>   Matt
> Zhenyu
> mpirun -np 8 ./nsproj  ../input/sample_120.zzy.dat -px 2 -py 2 -pz 2 -ksp_type gmres -pc_type hypre -ksp_rtol 1.e-2
> ....GRID POINT DIMENSIONS W/ GHOST CELLS : 122 X 122 X 122
> px= 2, py= 2, pz= 2
> ....BEGINNING SIMULATION
> time: 0,  SolvePressure iter= 0, residnorm= 0.000000e+00
> time: 20,  SolvePressure iter= 2, residnorm= 1.329163e+21
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Error in external library!
> [0]PETSC ERROR : Error in HYPRE solver, error code 1!
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./nsproj on a arch-linux2-c-opt named amax by zhenyu Sat Aug 24 16:05:05 2013
> [0]PETSC ERROR: Libraries linked from /home/zhenyu/petsc-3.4.2/arch-linux2-c-opt/lib
> [0]PETSC ERROR: Configure run at Sat Aug 24 12:43:12 2013
> [1]PETSC ERROR: --------------------- Error Message ------------------------------------
> [1]PETSC ERROR: Error in external library!
> [1]PETSC ERROR: Error in HYPRE solver, error code 1!
> [1]PETSC ERROR: ------------------------------------------------- -----------------------
> [1]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [1]PETSC ERROR: See docs/index.html for manual pages.
> [1]PETSC ERROR: ------------------------------------------------------------------------
> [1]PETSC ERROR: ./nsproj on a arch-linux2-c-opt named amax by zhenyu Sat Aug 24 16:05:05 2013
> [1]PETSC ERROR: Libraries linked from /home/zhenyu/petsc-3.4.2/arch-linux2-c-opt/lib
> [1]PETSC ERROR: Configure run at Sat Aug 24 12:43:12 2013
> [1]PETSC ERROR: Configure options --with-debugging=0 --with-shared-libraries=1 --with-dynamic-loading=1 --with-x=1 --with-blas-lapack-dir=/usr/lib/lapack --with-valgrind=1 --with-cc=gcc --with-fc=gfortran --with-clanguage=C++ --with-c++-support=1 --with-sieve=1 --with-opt-sieve=1 --download-generator --download-triangle --download-ctetgen --with-ctetgen --download -chaco --download-boost=1 --download-hypre=1 --download-metis --download-parmetis --download-hdf5 --download-openmpi --download-f-blas-lapack --download-superlu_dist
> [1]PETSC ERROR: PCApply_HYPRE() line 170 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/impls/hypre/hypre.c
> [1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message ------------------------------------
> [2]PETSC ERROR: Error in external library!
> [2]PETSC ERROR: Error in HYPRE solver, error code 1!
> [2]PETSC ERROR: ------------------------------------------------------------------------
> [2]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
> [2]PETSC ERROR: See docs/changes/index.html for recent updates.
> [2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [2]PETSC ERROR: See docs/index.html for manual pages.
> [2]PETSC ERROR: ------------------------------------------------- -----------------------
> [2]PETSC ERROR: ./nsproj on a arch-linux2-c-opt named amax by zhenyu Sat Aug 24 16:05:05 2013
> [2]PETSC ERROR: Libraries linked from /home/zhenyu/petsc-3.4.2/arch-linux2-c-opt/lib
> [2]PETSC ERROR: Configure run at Sat Aug 24 12:43:12 2013
> [2]PETSC ERROR: Configure options --with-debugging=0 --with-shared-libraries=1 --with-dynamic-loading=1 --with-x=1 --with-blas-lapack-dir=/usr/lib/lapack --with-valgrind=1 --with-cc=gcc --with-fc=gfortran --with-clanguage=C++ --with-c++-support=1 --with-sieve=1 --with-opt-sieve=1 --download-generator --download-triangle --download-ctetgen --with-ctetgen --download-chaco --download-boost=1 --download-hypre=1 --download-metis --download-parmetis --download-hdf5 --download-openmpi --download-f-blas-lapack --download-superlu_dist
> [2]PETSC ERROR: PCApply_HYPRE() line 170 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/impls/hyp re/hypre.c
> [2]PETSC ERROR: PCApply() line 442 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/interface/precon.c
> [2]PETSC ERROR: KSP_PCApply() line 227 in /home/zhenyu/petsc-3.4.2/include/petsc-private/kspimpl.h
> [2]PETSC ERROR: KSPInitialResidual() line 64 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itres.c
> [3]PETSC ERROR: --------------------- Error Message ------------------------------------
> [3]PETSC ERROR: Error in external library!
> [3]PETSC ERROR: Error in HYPRE solver, error code 1!
> [3]PETSC ERROR: ------------------------------------------------------------------------
> [3]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
> [3]PETSC ERROR: See docs/changes/index.html for recent updates.
> [3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [3]PETSC ERROR: See docs/index.html for manual pages.
> [3]PETSC ERROR: ./nsproj on a arch- linux2-c-opt named amax by zhenyu Sat Aug 24 16:05:05 2013
> [3]PETSC ERROR: Libraries linked from /home/zhenyu/petsc-3.4.2/arch-linux2-c-opt/lib
> [3]PETSC ERROR: Configure run at Sat Aug 24 12:43:12 2013
> [3]PETSC ERROR: Configure options --with-debugging=0 --with-shared-libraries=1 --with-dynamic-loading=1 --with-x=1 --with-blas-lapack-dir=/usr/lib/lapack --with-valgrind=1 --with-cc=gcc --with-fc=gfortran --with-clanguage=C++ --with-c++-support=1 --with-sieve=1 --with-opt-sieve=1 --download-generator --download-triangle --download-ctetgen --with-ctetgen --download-chaco --download-boost=1 --download-hypre=1 --download-metis --download-parmetis --download-hdf5 --download-openmpi --download-f-blas-lapack --download-superlu_dist
> [3]PETSC ERROR: PCApply_HYPRE() line 170 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/impls/hypre/hypre.c
> [3]PETSC ERROR: PCApply() line 442 in /home/zhen yu/petsc-3.4.2/src/ksp/pc/interface/precon.c
> [3]PETSC ERROR: [4]PETSC ERROR: --------------------- Error Message ------------------------------------
> [4]PETSC ERROR: Error in external library!
> [4]PETSC ERROR: Error in HYPRE solver, error code 1!
> [4]PETSC ERROR: ------------------------------------------------------------------------
> [4]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
> [4]PETSC ERROR: See docs/changes/index.html for recent updates.
> [4]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [4]PETSC ERROR: See docs/index.html for manual pages.
> [4]PETSC ERROR: ./nsproj on a arch-linux2-c-opt named amax by zhenyu Sat Aug 24 16:05:05 2013
> [4]PETSC ERROR: Libraries linked from /home/zhenyu/petsc-3.4.2/arch-linux2-c-opt/lib
> [4]PETSC ERROR: Configure run at Sat Aug 24 12:43:12 2013
> [4]PETSC ERROR: Configure options --with-de bugging=0 --with-shared-libraries=1 --with-dynamic-loading=1 --with-x=1 --with-blas-lapack-dir=/usr/lib/lapack --with-valgrind=1 --with-cc=gcc --with-fc=gfortran --with-clanguage=C++ --with-c++-support=1 --with-sieve=1 --with-opt-sieve=1 --download-generator --download-triangle --download-ctetgen --with-ctetgen --download-chaco --download-boost=1 --download-hypre=1 --download-metis --download-parmetis --download-hdf5 --download-openmpi --download-f-blas-lapack --download-superlu_dist
> [4]PETSC ERROR: PCApply_HYPRE() line 170 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/impls/hypre/hypre.c
> [4]PETSC ERROR: PCApply() line 442 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/interface/precon.c
> [4]PETSC ERROR: KSP_PCApply() line 227 in /home/zhenyu/petsc-3.4.2/include/petsc-private/kspimpl.h
> [4]PETSC ERROR: KSPInitialResidual() line 64 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itres.c[4]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/impls/gmres/gmres.c
> [4]PETSC ERROR: KSPSolve() line 441 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
> [4]PETSC ERROR: SolvePressure() line 898 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nssolver_petsc.cc
> [4]PETSC ERROR: start_sim() line 190 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nsproj_petsc.cc
> [5]PETSC ERROR: --------------------- Error Message ------------------------------------
> [5]PETSC ERROR: Error in external library!
> [5]PETSC ERROR: Error in HYPRE solver, error code 1!
> [5]PETSC ERROR: ------------------------------------------------------------------------
> [5]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
> [5]PETSC ERROR: See docs/changes/index.html for recent updates.
> [5]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [5]PETSC ERROR: See docs/index.html for manual pages.
> [5]P ETSC ERROR: ------------------------------------------------------------------------
> [5]PETSC ERROR: ./nsproj on a arch-linux2-c-opt named amax by zhenyu Sat Aug 24 16:05:05 2013
> [5]PETSC ERROR: Libraries linked from /home/zhenyu/petsc-3.4.2/arch-linux2-c-opt/lib
> [5]PETSC ERROR: Configure run at Sat Aug 24 12:43:12 2013
> [5]PETSC ERROR: Configure options --with-debugging=0 --with-shared-libraries=1 --with-dynamic-loading=1 --with-x=1 --with-blas-lapack-dir=/usr/lib/lapack --with-valgrind=1 --with-cc=gcc --with-fc=gfortran --with-clanguage=C++ --with-c++-support=1 --with-sieve=1 --with-opt-sieve=1 --download-generator --download-triangle --download-ctetgen --with-ctetgen --download-chaco --download-boost=1 --download-hypre=1 --download-metis --download-parmetis --download-hdf5 --download-openmpi --download-f-blas-lapack --download-superlu_dist
> [5]PETSC ERROR: PCApply_HYPR E() line 170 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/impls/hypre/hypre.c
> [5]PETSC ERROR: PCApply() line 442 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/interface/precon.c
> [5]PETSC ERROR: KSP_PCApply() line 227 in /home/zhenyu/petsc-3.4.2/include/petsc-private/kspimpl.h
> [5]PETSC ERROR: KSPInitialResidual() line 64 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itres.c
> [5]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/impls/gmres/gmres.c
> [5]PETSC ERROR: KSPSolve() line 441 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
> [5]PETSC ERROR: SolvePressure() line 898 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nssolver_petsc.cc
> [5]PETSC ERROR: start_sim() line 190 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nsproj_petsc.cc
> [6]PETSC ERROR: --------------------- Error Message ------------------------------------
> [6]PETSC ERROR: Error in external library!
> [6]PETSC ERROR: Error in HYPRE so lver, error code 1!
> [6]PETSC ERROR: ------------------------------------------------------------------------
> [6]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
> [6]PETSC ERROR: See docs/changes/index.html for recent updates.
> [6]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [6]PETSC ERROR: See docs/index.html for manual pages.
> [6]PETSC ERROR: ./nsproj on a arch-linux2-c-opt named amax by zhenyu Sat Aug 24 16:05:05 2013
> [6]PETSC ERROR: Libraries linked from /home/zhenyu/petsc-3.4.2/arch-linux2-c-opt/lib
> [6]PETSC ERROR: Configure run at Sat Aug 24 12:43:12 2013
> [6]PETSC ERROR: Configure options --with-debugging=0 --with-shared-libraries=1 --with-dynamic-loading=1 --with-x=1 --with-blas-lapack-dir=/usr/lib/lapack --with-valgrind=1 --with-cc=gcc --with-fc=gfortran --with-clanguage=C++ --with-c++-support=1 --with-sieve=1 --with-opt-sieve =1 --download-generator --download-triangle --download-ctetgen --with-ctetgen --download-chaco --download-boost=1 --download-hypre=1 --download-metis --download-parmetis --download-hdf5 --download-openmpi --download-f-blas-lapack --download-superlu_dist
> [6]PETSC ERROR: PCApply_HYPRE() line 170 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/impls/hypre/hypre.c
> [6]PETSC ERROR: PCApply() line 442 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/interface/precon.c
> [6]PETSC ERROR: KSP_PCApply() line 227 in /home/zhenyu/petsc-3.4.2/include/petsc-private/kspimpl.h
> [6]PETSC ERROR: KSPInitialResidual() line 64 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itres.c
> [6]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/impls/gmres/gmres.c
> [6]PETSC ERROR: KSPSolve() line 441 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
> [7]PETSC ERROR: -------------- ------- Error Message ------------------------------------
> [7]PETSC ERROR: Error in external library!
> [7]PETSC ERROR: Error in HYPRE solver, error code 1!
> [7]PETSC ERROR: ------------------------------------------------------------------------
> [7]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
> [7]PETSC ERROR: See docs/changes/index.html for recent updates.
> [7]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [7]PETSC ERROR: See docs/index.html for manual pages.
> [7]PETSC ERROR: ./nsproj on a arch-linux2-c-opt named amax by zhenyu Sat Aug 24 16:05:05 2013
> [7]PETSC ERROR: Libraries linked from /home/zhenyu/petsc-3.4.2/arch-linux2-c-opt/lib
> [7]PETSC ERROR: Configure run at Sat Aug 24 12:43:12 2013
> [7]PETSC ERROR: Configure options --with-debugging=0 --with-shared-libraries=1 --with-dynamic-loading=1 --with-x=1 --with-blas-lapack-dir =/usr/lib/lapack --with-valgrind=1 --with-cc=gcc --with-fc=gfortran --with-clanguage=C++ --with-c++-support=1 --with-sieve=1 --with-opt-sieve=1 --download-generator --download-triangle --download-ctetgen --with-ctetgen --download-chaco --download-boost=1 --download-hypre=1 --download-metis --download-parmetis --download-hdf5 --download-openmpi --download-f-blas-lapack --download-superlu_dist
> [7]PETSC ERROR: PCApply_HYPRE() line 170 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/impls/hypre/hypre.c
> [7]PETSC ERROR: PCApply() line 442 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/interface/precon.c
> [7]PETSC ERROR: KSP_PCApply() line 227 in /home/zhenyu/petsc-3.4.2/include/petsc-private/kspimpl.h
> [7]PETSC ERROR: KSPInitialResidual() line 64 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itres.c
> [7]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/impls/gmre s/gmres.c
> [7]PETSC ERROR: KSPSolve() line 441 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
> [7]PETSC ERROR: SolvePressure() line 898 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nssolver_petsc.cc
> [7]PETSC ERROR: start_sim() line 190 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nsproj_petsc.cc
> [0]PETSC ERROR: Configure options --with-debugging=0 --with-shared-libraries=1 --with-dynamic-loading=1 --with-x=1 --with-blas-lapack-dir=/usr/lib/lapack --with-valgrind=1 --with-cc=gcc --with-fc=gfortran --with-clanguage=C++ --with-c++-support=1 --with-sieve=1 --with-opt-sieve=1 --download-generator --download-triangle --download-ctetgen --with-ctetgen --download-chaco --download-boost=1 --download-hypre=1 --download-metis --download-parmetis --download-hdf5 --download-openmpi --download-f-blas-lapack --download-superlu_dist
> [0]PETSC ERROR: PCApply_HYPRE() line 170 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/impls/hypre/hypre.c
> [0]PETSC ERROR: PCApply() line 442 in /home/zhenyu/petsc-3.4.2/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSP_PCApply() line 227 in /home/zhenyu/petsc-3.4.2/include/petsc-private/kspimpl.h
> [0]PETSC ERROR: KSPInitialResidual() line 64 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: KSPSolve() line 441 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: SolvePressure() line 898 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nssolver_petsc.cc
> [0]PETSC ERROR: start_sim() line 190 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nsproj_petsc.cc
> [1]PETSC ERROR: KSP_PCApply() line 227 in /home/zhenyu/petsc-3.4.2/include/pet sc-private/kspimpl.h
> [1]PETSC ERROR: KSPInitialResidual() line 64 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itres.c
> [1]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/impls/gmres/gmres.c
> [1]PETSC ERROR: KSPSolve() line 441 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
> [1]PETSC ERROR: SolvePressure() line 898 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nssolver_petsc.cc
> [1]PETSC ERROR: start_sim() line 190 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nsproj_petsc.cc
> [2]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/impls/gmres/gmres.c
> [2]PETSC ERROR: KSPSolve() line 441 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
> [2]PETSC ERROR: SolvePressure() line 898 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nssolver_petsc.cc
> [2]PETSC ERROR: start_sim() line 190 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/ nsproj_petsc.cc
> [3]PETSC ERROR: KSPInitialResidual() line 64 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itres.c
> [3]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/impls/gmres/gmres.c
> [3]PETSC ERROR: KSPSolve() line 441 in /home/zhenyu/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
> [3]PETSC ERROR: SolvePressure() line 898 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nssolver_petsc.cc
> [3]PETSC ERROR: start_sim() line 190 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nsproj_petsc.cc
> [6]PETSC ERROR: SolvePressure() line 898 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nssolver_petsc.cc
> [6]PETSC ERROR: start_sim() line 190 in "unknowndirectory/"/home/zhenyu/work/nsproj_0.3_zzy/src/nsproj_petsc.cc
> mpirun noticed that the j ob aborted, but has no info as to the process
> that caused that situation.
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
