[petsc-users] use kspsolve repeately
丁老师 ztdepyahoo at 163.com
Sat Aug 24 04:57:00 CDT 2013
in  my code, i need to use kspsolve in the following way
    KSP ksp;
    KSPCreate(PETSC_COMM_WORLD,&ksp);
    KSPSetOperators(ksp,A,A,SAME_NONZERO_PATTERN);
    KSPSetOperators(ksp,A,A,SAME_PRECONDITIONER);
    KSPSetInitialGuessNonzero(ksp,PETSC_TRUE)
     KSPSetType(ksp,KSPBCGS);
    KSPSetFromOptions(ksp);
  set the matrix A value and right hand side bu and bv.
    kspsolve(A,bu);
    kspsolve(A,bv);
  change the value of matrix A and bu bv,
     kspsolve(A,bu);
     kspsolve(A,bv);
 the first and second call to the kspsolve use the same preconditioner. but which preconditoner does the third and fourth call to the kspsolve since the value of the matrix A has changed.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130824/f1da7836/attachment.html>
