[petsc-users] Mat Destroy
Fri Aug 23 18:37:25 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>    We call free() at that point. But not that in Unix this does not
>    mean the memory is returned to the operating system so you will not
>    see the process memory go down.  If you then allocate new objects
>    they will reuse this memory.
Also note that MatDestroy only releases a references, so if another
object still holds a reference to your matrix, nothing will be freed.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/ab9c4be0/attachment.pgp>
