[petsc-users] accessing global vector in a DMMA
Zhang zyzhang at nuaa.edu.cn
Wed Aug 21 22:04:12 CDT 2013
Thank your help, Barry,
If I assign the sum of local values (, such as ul[i+1]-2*ul[i]+ul[i-1],) to a global value ustar[i],
1. should I use the local value for ustar as well ?
2. Once I finished the work of assigning values for ustar and restored them, should I use VecAssemblyBegin/End to them later?
Because I find such a usage in the examples. I am not sure it necessary or not.
3. AS a test if I choose the incorrect way, say, ustar[i] comes straightly from u[i+/-1]..., why I did not get any error, such as
memory access out of range? Or even this is dangerous, such errors will not be shown in a serial run?
Cheers,
Zhenyu
> -----原始邮件-----
> 发件人: "Barry Smith" <bsmith at mcs.anl.gov>
> 发送时间: 2013-08-22 11:02:13 (星期四)
> 收件人: Zhang <zyzhang at nuaa.edu.cn>
> 抄送: petsc-users at mcs.anl.gov
> 主题: Re: [petsc-users] accessing global vector in a DMMA
>    In PETSc the "local vector" or "local representation" refers to vectors WITH ghost points. The global vector or global representation refers to vectors WITHOUT ghost points.  Hence to access locations like [i+1] which extend over to the next process you need to use the local ghosted representation.
>    Barry
> One could argue that it is not the clearest names to use. Just remember local == ghosted and global == not ghosted.
> On Aug 21, 2013, at 8:25 PM, Zhang <zyzhang at nuaa.edu.cn> wrote:
> > Dear All,
> > Now I am confused with the way to access a global vector defined from DMDA.
> > Here is the codes. When I switch on _DEBUG1_ the results get wrong.  While if it's off,
> > the results fine. I just wonder why I gave to use the local form of ul,vl,wl to access the
> > values such as ul[k][j][i+1], and etc.
> > Thank you first for any suggestion.
> > Zhenyu
> > ierr = DMCreateGlobalVector(ctxu->grid, &ctxu->x );CHKERRQ(ierr);
> >   ierr = VecDuplicate(ctxu->x,&ctxu->b);CHKERRQ(ierr);
> > ierr = DMCreateGlobalVector(ctxv->grid, &ctxv->x );CHKERRQ(ierr);
> >     ierr = VecDuplicate(ctxv->x,&ctxv->b);CHKERRQ(ierr);
> > ierr = DMCreateGlobalVector(ctxw->grid, &ctxw->x );CHKERRQ(ierr);
> >     ierr = VecDuplicate(ctxw->x,&ctxw->b);CHKERRQ(ierr);
> >   VecCopy(ctxu->x,ctxu->b);
> >   VecCopy(ctxv->x,ctxv->b);
> >   VecCopy(ctxw->x ,ctxw->b);
> >   DMDAVecGetArray( ctxu->grid, ctxu->b, &ustar );
> >   DMDAVecGetArray( ctxv->grid, ctxv->b, &vstar );
> >   DMDAVecGetArray( ctxw->grid, ctxw->b, &wstar );
> > #if defined(_DEBUG1_)
> >   DMDAVecGetArray( ctxu->grid, ctxu->x, &u );
> >   DMDAVecGetArray( ctxv->grid, ctxv->x, &v );
> >   DMDAVecGetArray( ctxw->grid, ctxw->x, &w );
> > #else
> >   DMGetLocalVector(ctxu->grid,&ctxu->local);
> >   DMGetLocalVector(ctxv->grid,&ctxv->local);
> >   DMGetLocalVector(ctxw->grid,&ctxw->local);
> >   DMGlobalToLocalBegin(ctxu->grid,ctxu->x,INSERT_VALUES,ctxu->local);
> >   DMGlobalToLocalEnd(ctxu->grid,ctxu->x,INSERT_VALUES,ctxu->local);
> >   DMGlobalToLocalBegin(ctxv->grid,ctxv->x,INSERT_VALUES,ctxv->local);
> >   DMGlobalToLocalEnd(ctxv->grid,ctxv->x,INSERT_VALUES,ctxv->local);
> > & nbsp; DMGlobalToLocalBegin(ctxw->grid,ctxw->x,INSERT_VALUES,ctxw->local);
> >   DMGlobalToLocalEnd(ctxw->grid,ctxw->x,INSERT_VALUES,ctxw->local);
> >   DMDAVecGetArray( ctxu->grid, ctxu->local, &ul );
> >   DMDAVecGetArray( ctxv->grid, ctxv->local, &vl );
> >   DMDAVecGetArray( ctxw->grid, ctxw->local, &wl );
> > #endif
> >   // U
> >   DMDAGetCorners( ctxu->grid, &is, &js, &ks, &in, &jn, &kn );
> >   ie = is + in - 1;
> >   je = js + jn - 1;
> >   ke = ks + kn - 1;
> >   is=max(is,1);
> >   js=max(js,1);
> >   ks=max(ks,1);
> >   ie=min(ie,ctxu->l-2);
> >   je=min(je,ctxu->m-2);
> >   ke=min(ke,ctxu->n-2);
> >   for (k=ks; k<=ke; k++) {
> >     for (j=js; j<=je; j++) {
> >       for (i=is; i<=ie; i+ +) {
> >         ustar[k][j][i] +=
> >                                - dtdx*(0.25*((u[k][j][i]+u[k][j][i+1])*(u[k][j][i]+u[k][j][i+1]))
> >                                        - 0.25*((u[k][j][i]+u[k][j][i-1])*(u[k][j][i]+u[k][j][i-1])))
> >                                - dtdy*(0.25*(u [k][j][i]+u [k][j+1][i])*(v [k][j][i]+v [k][j][i+1])
> >                                         - 0.25*(u [k][j][i]+u [k][j-1][i])*(v [k][j-1][i]+v [k][j-1][i+1]))
> >                                - dtdz*(0.25*(u [k][j][i]+u [k+1][j][i])*(w [k][j][i]+w [k][j][i+1])
> >                                        - 0.25*(u [k][j][i]+u [k-1][j][i])*(w [k-1][j][i]+w [k-1][j][i+1]))
> >                                + dtdxx*(u [k][j][i-1]-2*u [k][j][i]+u [k][j] [i+1])
> >                                + dtdyy*(u [k][j-1][i]-2*u [k][j][i]+u [k][j+1][i])
> >                                + dtdzz*(u [k-1][j][i]-2*u [k][j][i]+u [k+1][j][i]);
> > #else
> >         ustar[k][j][i] +=
> >                                - dtdx*(0.25*((ul[k][j][i]+ul[k][j][i+1])*(ul[k][j][i]+ul[k][j][i+1]))
> >                              &nbs p;         - 0.25*((ul[k][j][i]+ul[k][j][i-1])*(ul[k][j][i]+ul[k][j][i-1])))
> >                                - dtdy*(0.25*(ul[k][j][i]+ul[k][j+1][i])*(vl[k][j][i]+vl[k][j][i+1])
> >                                        - 0.25*(ul[k][j][i]+ul[k][j-1][i])*(vl[k][j-1][i]+vl[k][j-1][i+1]))
> >                                - dtdz*(0.25*(ul[k][j][i]+ul[k+1][j][i])*(wl[k][j][i]+wl[k][j][i+1])
> >           &nb sp;                            - 0.25*(ul[k][j][i]+ul[k-1][j][i])*(wl[k-1][j][i]+wl[k-1][j][i+1]))
> >                                + dtdxx*(ul[k][j][i-1]-2*ul[k][j][i]+ul[k][j][i+1])
> >                                + dtdyy*(ul[k][j-1][i]-2*ul[k][j][i]+ul[k][j+1][i])
> >                                + dtdzz*(ul[k-1][j][i]-2*ul[k][j][i]+ul[k+1][j][i]);
> >         #endif
> > DMDAVecRestoreArray( ctxu->grid, ctxu->x, &u );
> > DMDAVecRestoreArray( ctxv->grid, ctxv->x, &v );
> > DMDAVecRestoreArray( ctxw->grid, ctxw->x, &w );
> > #else
> > DMDAVecRestoreArray( ctxu->grid, ctxu->local, &ul );
> > DMDAVecRestoreArray( ctxv->grid, ctxv->local, &vl );
> > DMDAVecRestoreArray( ctxw->grid, ctxw->local, &wl );
> > DMRestoreLocalVector(ctxu->grid,&ctxu->local);
> > DMRestoreLocalVector(ctxv->grid,&ctxv->local);
> > DMRestoreLocalVector(ctxw->grid,&ctxw->local);
> > #endif
> > DMDAVecRestoreArray( ctxu->grid, ctxu->b, &ustar );
> > DMDAVecRestoreArray( ctxv->grid, ctxv->b, &vstar );
> > DMDAVecRestoreArray( ctxw->grid, ctxw->b, &wstar );
