[petsc-users] PETSC ERROR: Logging has not been enabled
Wed Aug 21 17:12:49 CDT 2013
   Most likely the tool you are using to launch the parallel program is wrong for the MPI you have linked PETSc with. Are you starting the program with mpiexec ? Is that mpiexec the one that goes with the MPI (mpicc or mpif90) that you built PETSc with?
   What happens if you compile a trivial MPI only code with the mpicc and then try to run it in parallel with the mpiexec?
   Barry
On Aug 21, 2013, at 5:05 PM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> Dear all,
> My program runs fine when using just one processor, valgrind shows no errors too, but when using more than one processor I get the following errors:
> [0]PETSC ERROR: PetscOptionsInsertFile() line 461 in /home/bkhanal/Documents/softwares/petsc-3.4.2/src/sys/objects/options.c
> [0]PETSC ERROR: PetscOptionsInsert() line 623 in /home/bkhanal/Documents/softwares/petsc-3.4.2/src/sys/objects/options.c
> [0]PETSC ERROR: PetscInitialize() line 769 in /home/bkhanal/Documents/softwares/petsc-3.4.2/src/sys/objects/pinit.c
> PETSC ERROR: Logging has not been enabled.
> You might have forgotten to call PetscInitialize().
> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
> [cli_0]: aborting job:
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   EXIT CODE: 56
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> I have not forgotten to call PetscInitialize, if that helps!
> Thanks,
> Bishesh
