[petsc-users] Attach approximate null space to a fieldsplit block
Mon Aug 19 08:03:34 CDT 2013
On Mon, Aug 19, 2013 at 7:40 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> "Garth N. Wells" <gnw20 at cam.ac.uk> writes:
> > I'm using PCFIELDSPLIT for a mixed problem, with fields indicated via
> > an index set (using PCFieldSplitSetIS). I'd like to attach an
> > approximate null space to the A00 block of the system. Is there a way
> > to attach the null space to one block?
There is a better way. You can attach the null space to the IS that forms
the split
  PetscObjectAttach((PetscObject) is0, "nullspace", nullspace);
and PCFIELDSPLIT will pull it out and attach it to the preconditioner for
block 0.
   Matt
> With MatNest, you can use MatSetNearNullSpace on sub-blocks and it will
> be used automatically.  This is also the low-memory way to use
> PCFieldSplit.  Note that if you use MatSetValuesLocal, you can use the
> NEST format with identical code in assembly; only matrix creation is
> different, see src/snes/example/tutorials/ex28.c for an example that
> works with both AIJ and NEST formats.
> Otherwise, you should be able to PCSetUp, then get out the sub-solvers
> PCFieldSplitGetSubKSP, pull out their matrices, and call
> MatSetNearNullSpace.  Those submatrices should not be overwritten as
> long as you use SAME_NONZERO_PATTERN, so the null space would still work
> in future iterations.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130819/f70a6535/attachment-0001.html>
