[petsc-users] How can get the inverse matrix of P(transpose)AP
Sun Aug 18 08:15:53 CDT 2013
Cong Li <solvercorleone at gmail.com> writes:
> Hi
> I met a problem when trying to get a inverse matrix.
> The problem is like this:
> I have a matrix P (m x k matrix, and k<<m) and a matrix A (m x m matrix,
> large SPD matrix). Now I want to get the inverse matrix of
> P(transpose)*A*p.
Can you back up and explain at a high level what you're trying to accomplish?
> Since P(transpose)*A*p is only a k x k matrix, and PETSc only supports
> sequential direct solver, I want to store P(transpose)*A*p in MATSEQDENSE
> type.
> And the questions are
> 1. given P and A are PETSc parallel matrix, for instance MATMPIAIJ, how can
> I get sequential dense matrix P(transpose)*A*p?
> 2. If I need to multiply P(transpose)*A*p with other parallel dense matrix,
> how I can do it?
> Thanks a lot.
> Cong
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130818/d85448ee/attachment.pgp>
