[petsc-users] How can I convert parall matrix to MATSEQDENSE
Sun Aug 18 08:12:51 CDT 2013
Cong Li <solvercorleone at gmail.com> writes:
> Hi, all
> Could someone tell me how I can convert a parallel MATDENSE (or MATMPIAIJ)
> matrix to a MATSEQDENSE matrix?
Get the array and use MPI_Gather.  With MATMPIAIJ, you almost certainly
should not compute an explicit inverse.
> I need this converted sequential matrix for direct solver to get its
> inverse matrix.
You can do that with Elemental without needing to serialize the matrix
inversion.  Also, why do you need an explicit inverse?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130818/963cfa70/attachment.pgp>
