[petsc-users] SNES Line Search Monitor
Peter Brune brune at mcs.anl.gov
Sat Aug 17 08:49:19 CDT 2013
On Sat, Aug 17, 2013 at 1:40 AM, Su Yan <suyan0 at gmail.com> wrote:
> Hi, I ran into something really weird when I tried to solve a nonlinear
> equation with Newton method and line search. Specifically, I used
> SNESSetType(snesMbr, SNESNEWTONLS); and
> PetscOptionsSetValue("-snes_linesearch_type", "l2");
Which version of PETSc are you using?
> When I execute my program abc.bin with the following command:
> ./abc.bin -snes_monitor -snes_linesearch_monitor
> I got the following output:
> 0 SNES Function norm 1.457697974866e+07
>        Line search: lambdas = [1, 0.5, 0], fnorms = [669102, 7.35102e+06,
> 1.4577e+07]
>        Line search terminated: lambda = 1.00553, fnorms = 652606
> 1 SNES Function norm 6.526060362905e+05
>        Line search: lambdas = [1, 0.5, 0], fnorms = [3406.6, 326873,
> 652606]
>        Line search terminated: lambda = 1.00171, fnorms = 2801.6
> 2 SNES Function norm 2.801596249480e+03
>        Line search: lambdas = [1, 0.5, 0], fnorms = [2.51242, 1401.2,
> 2801.6]
>        Line search terminated: lambda = 1.00029, fnorms = 2.09292
> 3 SNES Function norm 2.092918540169e+00
>        Line search: lambdas = [1, 0.5, 0], fnorms = [0.000123295, 1.04646,
> 2.09292]
>        Line search terminated: lambda = 1, fnorms = 0.000122588
> 4 SNES Function norm 1.225883678418e-04
> Converged Reason: FNORM_RELATIVE
> The nonlinear problem converged normally with a relative f_norm set as
> 1E-7.
> However, if I execute exactly the same program, but with a slightly
> different runtime command:
>  0 SNES Function norm 1.457697974975e+07
> 1 SNES Function norm 6.526060348917e+05
> 2 SNES Function norm 2.801608208510e+03
> 3 SNES Function norm 2.450488738084e+03
> 4 SNES Function norm 3.269507987119e+02
> 5 SNES Function norm 3.016606325384e+02
> 6 SNES Function norm 2.463851989463e+02
> 7 SNES Function norm 1.546266418976e+02
> 8 SNES Function norm 1.492518400407e+02
> 9 SNES Function norm 1.477122410995e+02
> 10 SNES Function norm 1.503359418680e+02
> 11 SNES Function norm 1.504759910776e+02
> 12 SNES Function norm 1.417592634863e+02
> 13 SNES Function norm 3.047096130411e+05
Is this problem reproducible?  Note that even your 0th norm is very
slightly different, and the first three norms are quite similar.
> and the solver diverged.
> The only difference was that whether I used "-snes_linesearch_monitor" or
> not.
> In my understanding, this runtime option only turns on the screen print.
> So why did it make such a big difference? Is there anything special with
> this option turned on? Hope someone could help me out.
This is correct.  It should not influence the solution at all, and all it
does is enable printing.  Also, the l2 line search takes significantly more
work for well-behaved Newton convergence than bt, as bt automatically
accepts the full step.  l2 is mostly meant for cases where the step is
automatically ill-scaled.
- Peter
> Thanks a lot.
> Regards,
> Su
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130817/f6a2d7c4/attachment.html>
