[petsc-users] FORTRAN 90 with PETSc
Fri Aug 16 21:17:02 CDT 2013
On Fri, Aug 16, 2013 at 6:37 PM, Frank <fangxingjun0319 at gmail.com> wrote:
> Hi,
> I am using PETSc to iterate a problem, that is to say I call KSPSolve
> repeatedly.
> Firstly, I write all the PETSc components in one subroutine, including
> "MatCreate", "VecCreateMPI", etc. Everything works fine.
> Then, I want to only initialize ksp once outside the loop, and the matrix
> and rhs is changed within the loop repeatedly. Here are my problem:
> 1. I tried to use COMMON to transfer the following variables. I include
> "petsc.var" in the solver subroutine.  It cannot be compiled.
> "petsc.var"
> Vec         x,b
> Mat         A
> KSP         ksp
> PC          pc
> COMMON /MYPETSC/x, b, A,ksp,pc
> 2. I defined the following in the main program:
> PROGRAM MAIN
> #include <finclude/petscsys.h>
> #include <finclude/petscvec.h>
> #include <finclude/petscmat.h>
> #include <finclude/petscpc.h>
> #include <finclude/petscksp.h>
> Vec         x,b
> Mat         A
> KSP         ksp
> PC          pc
> CALL INIT_PETSC(ksp,pc,A,x,b)
> CALL LOOP(ksp,pc,A,x,b)
> END PROGRAM
> SUBROUTINE LOOP(ksp,pc,A,x,b)
> Vec         x,b
> Mat         A
> KSP         ksp
> PC          pc
> CALL SOLVE(ksp,pc,A,x,b)
> END SUBROUTINE
> SUBROUTINE SOLVE(ksp,pc,A,x,b)
> Vec         x,b
> Mat         A
> KSP         ksp
> PC          pc
> CALL (ksp, b,x,ierr)
> END SUBROUTINE
> It can be compiled, but ksp does not iterate.
> Could you please explain to me the reason and solution for this problem.
I do not understand "does not iterate". Is there an error message?
     Matt
> Thank you very much.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130816/6aaddd38/attachment.html>
