[petsc-users] GAMG speed
Wed Aug 14 06:35:34 CDT 2013
Please always use "reply-all" so that your messages go to the list.
This is standard mailing list etiquette.  It is important to preserve
threading for people who find this discussion later and so that we do
not waste our time re-answering the same questions that have already
been answered in private side-conversations.  You'll likely get an
answer faster that way too.
Michele Rosso <mrosso at uci.edu> writes:
> Jed,
> thank you very much for the detailed analysis.
> I confirm that
>   -log_summary -ksp_monitor -ksp_view -ksp_converged_reason -pc_type mg
>    -pc_mg_galerkin -pc_mg_levels 5 -mg_levels_ksp_type richardson
>    -mg_levels_ksp_max_it 1
> results in a faster solve with the 256^3 grid (it finally beats CG + ICC).
> Yes, I perform different solves: I setup matrix and KSP only once at the beginning of the run and then I re-use them
> at each time step. The rhs term changes during the simulation though. For now (single phase flow) the matrix does not change,
> but I will be dealing soon with a multiphase flow and thus not even the matrix values will be constant in time (it will be a variable coefficients Poisson Equation).
Okay, the coefficient variation from the multiphase flow can drastically
change the characteristics of the solve.
> I need to solve up to the discretization error, so maybe FMG is worth a try.
> The matrix-free approach is appealing given that the Poisson solver is really mission critical (basically it accounts for most of the simulation time).
> I will use the level set method and ghost fluid method in order to account for the discontinuities at the interface between phases: the computation of the matrix and rhs
> values will be influenced by such methods so my only concern is to be sure matrix-free can be used in these circumstances.
Matrix-free can be used in principle, but those problems can be several
orders of magnitude more ill-conditioned, so don't invest any more time
on it right now.  Get the discretization set up using assembled
matrices, then go through the options we've tried to find an efficient
solver.  The best choice will likely depend on the details of the
formulation, the types of fluids involved, and the geometric
configuration of the fluids.
> I do not have any prior experience with matrix-free methods so I will have to rely on your assistance for this.
> Thank you very much.
> Michele
>>> Hi Jed,
>>> I attached the output for both the runs you suggested. At the beginning
>>> of each file I included the options I used.
>>> On a side note, I tried to run with a grid of 256^3 (exactly as before)
>>> but with less levels, i.e. 3 instead of 4 or 5.
>>> My system stops the run because of an Out Of Memory condition. It is
>>> really odd since I have not changed anything except
>>> - pc_mg_levels.  I cannot send you any output since there is none. Do
>>> you have any guess where the problem comes from?
>> The selected algorithm does a direct solve on the coarse grid.  Each
>> time you reduce the number of levels, the coarse grid size grows by a
>> factor of 8.  Going from 5 to 3 levels is going from a 16^3 coarse grid
>> to a 64^3 coarse grid.  Applying a direct solver to the latter ends up
>> using a lot of memory.  I think this is not worth bothering with and it
>> might even be (slightly) faster to use 6 levels.  That is not where the
>> time is being spent.
>>>    0 KSP Residual norm 3.653965664551e-05
>>>    1 KSP Residual norm 1.910638846094e-06
>>>    2 KSP Residual norm 8.690440116045e-08
>>>    3 KSP Residual norm 3.732213639394e-09
>>>    4 KSP Residual norm 1.964855338020e-10
>> This converges well.
>>>                           Max       Max/Min        Avg      Total
>>> Time (sec):           4.048e+00      1.00012   4.048e+00
>>> Objects:              2.490e+02      1.00000   2.490e+02
>>> Flops:                2.663e+08      1.00000   2.663e+08  2.130e+09
>>> Flops/sec:            6.579e+07      1.00012   6.579e+07  5.263e+08
>>> MPI Messages:         6.820e+02      1.00000   6.820e+02  5.456e+03
>>> MPI Message Lengths:  8.245e+06      1.00000   1.209e+04  6.596e+07
>>> MPI Reductions:       4.580e+02      1.00000
>>> VecTDot               12 1.0 2.9428e-02 1.2 6.29e+06 1.0 0.0e+00 0.0e+00 1.2e+01  1  2  0  0  3   1  2  0  0  3  1710
>>> VecNorm                9 1.0 1.0796e-02 1.2 4.72e+06 1.0 0.0e+00 0.0e+00 9.0e+00  0  2  0  0  2   0  2  0  0  2  3497
>>> VecScale              24 1.0 2.4652e-04 1.1 1.99e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6442
>>> VecCopy                3 1.0 5.0740e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>> VecSet               116 1.0 1.4349e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>> VecAXPY               12 1.0 2.8027e-02 1.0 6.29e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0  1796
>>> VecAYPX               29 1.0 3.0655e-02 1.4 4.16e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0  1085
>>> VecScatterBegin      123 1.0 3.5391e-02 1.1 0.00e+00 0.0 3.5e+03 1.2e+04 0.0e+00  1  0 65 66  0   1  0 65 66  0     0
>>> VecScatterEnd        123 1.0 2.5395e-02 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>> MatMult               31 1.0 2.3556e-01 1.0 5.62e+07 1.0 1.0e+03 2.3e+04 0.0e+00  6 21 19 36  0   6 21 19 36  0  1908
>>> MatMultAdd            24 1.0 5.9044e-02 1.0 1.21e+07 1.0 5.8e+02 2.8e+03 0.0e+00  1  5 11  2  0   1  5 11  2  0  1644
>>> MatMultTranspose      28 1.0 7.4601e-02 1.1 1.42e+07 1.0 6.7e+02 2.8e+03 0.0e+00  2  5 12  3  0   2  5 12  3  0  1518
>>> MatSolve               6 1.0 3.8311e-03 1.0 1.44e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  3006
>>> MatSOR                48 1.0 5.8050e-01 1.0 1.01e+08 1.0 8.6e+02 1.5e+04 4.8e+01 14 38 16 19 10  14 38 16 19 11  1390
>> Most of the solve time is in MatSOR and MatMult.  That's expected since
>> the subdomains are pretty big.
>>> MatLUFactorSym         1 1.0 3.0620e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00  0  0  0  0  1   0  0  0  0  1     0
>>> MatLUFactorNum         1 1.0 2.4665e-02 1.0 1.95e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  7  0  0  0   1  7  0  0  0  6329
>>> MatAssemblyBegin      20 1.0 2.4351e-02 6.7 0.00e+00 0.0 0.0e+00 0.0e+00 2.2e+01  0  0  0  0  5   0  0  0  0  5     0
>>> MatAssemblyEnd        20 1.0 1.3176e-01 1.0 0.00e+00 0.0 5.6e+02 2.1e+03 7.2e+01  3  0 10  2 16   3  0 10  2 16     0
>>> MatGetRowIJ            1 1.0 1.1516e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>> MatGetOrdering         1 1.0 4.1008e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>> MatView               16 1.3 1.0209e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  3   0  0  0  0  3     0
>>> MatPtAP                4 1.0 6.4001e-01 1.0 4.06e+07 1.0 1.1e+03 1.7e+04 1.0e+02 16 15 21 30 22  16 15 21 30 22   507
>> MatPtAP dominates the setup time.  For profiling, you could register a
>> stage (PetscLogStageRegister) and time the setup separately from the
>> solve.
>>> MatPtAPSymbolic        4 1.0 3.7003e-01 1.0 0.00e+00 0.0 7.2e+02 2.0e+04 6.0e+01  9  0 13 22 13   9  0 13 22 13     0
>>> MatPtAPNumeric         4 1.0 2.7004e-01 1.0 4.06e+07 1.0 4.2e+02 1.2e+04 4.0e+01  7 15  8  8  9   7 15  8  8  9  1202
>>> MatGetRedundant        1 1.0 7.9393e-04 1.0 0.00e+00 0.0 1.7e+02 7.1e+03 4.0e+00  0  0  3  2  1   0  0  3  2  1     0
>>> MatGetLocalMat         4 1.0 3.9521e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  1  0  0  0  2   1  0  0  0  2     0
>>> MatGetBrAoCol          4 1.0 1.7719e-02 1.0 0.00e+00 0.0 4.3e+02 2.7e+04 8.0e+00  0  0  8 18  2   0  0  8 18  2     0
>>> MatGetSymTrans         8 1.0 1.3007e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>> KSPSetUp               7 1.0 1.3097e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01  0  0  0  0  5   0  0  0  0  5     0
>>> KSPSolve               2 1.0 1.0450e+00 1.0 2.04e+08 1.0 3.4e+03 1.2e+04 7.5e+01 26 77 62 60 16  26 77 62 60 16  1563
>>> PCSetUp                1 1.0 8.6248e-01 1.0 6.21e+07 1.0 1.9e+03 1.1e+04 3.2e+02 21 23 35 32 69  21 23 35 32 69   576
>>> PCApply                6 1.0 8.4384e-01 1.0 1.61e+08 1.0 3.2e+03 9.0e+03 4.8e+01 21 60 59 44 10  21 60 59 44 11  1523
>> Do you know why there are 6 PCApply events?  With four iterations of the
>> Krylov method, there should be only 5 events.  Oh, it looks like you do
>> two solves.  Is one of those with a different system?
>> Recall that the old KSPSolve time was over 3.35 seconds.
>>> -mg_levels_ksp_max_it 1 -pc_mg_type full
>>>    0 KSP Residual norm 3.654533581988e-05
>>>    1 KSP Residual norm 8.730776244351e-07
>>>    2 KSP Residual norm 3.474626061661e-08
>>>    3 KSP Residual norm 1.813665557493e-09
>> This converges slightly faster, but ends up not paying off.
>>> Time (sec):           4.261e+00      1.00012   4.261e+00
>>> Objects:              2.950e+02      1.00000   2.950e+02
>>> Flops:                3.322e+08      1.00000   3.322e+08  2.658e+09
>>> Flops/sec:            7.797e+07      1.00012   7.796e+07  6.237e+08
>>> MPI Messages:         1.442e+03      1.00000   1.442e+03  1.154e+04
>>> MPI Message Lengths:  1.018e+07      1.00000   7.057e+03  8.141e+07
>>> MPI Reductions:       5.460e+02      1.00000
>> More messages, more work, etc., so not better.
>>> KSPSolve               2 1.0 1.2287e+00 1.0 2.70e+08 1.0 9.5e+03 5.8e+03 1.6e+02 29 81 82 68 30  29 81 82 68 30  1758
>>> PCSetUp                1 1.0 8.6414e-01 1.0 6.21e+07 1.0 1.9e+03 1.1e+04 3.2e+02 20 19 17 26 58  20 19 17 26 58   575
>>> PCApply                5 1.0 1.0571e+00 1.0 2.33e+08 1.0 9.3e+03 4.9e+03 1.4e+02 24 70 81 56 26  24 70 81 56 26  1764
>> It's still entirely possible that you can make Full MG beat V-cycles,
>> especially if you only need to converge up to discretization error.  By
>> my figures, your good solver takes 12 work units to converge well below
>> discretization error (after Galerkin setup, but maybe you only need to
>> do that once?).  If you only need to equal truncation error, this can be
>> brought down to about 5 (probably at best a 2x speedup in parallel).
>> This would involve a high-order (cubic) FMG prolongation.
>> Alternatively, you can speed up the implementation (and significantly
>> reduce memory usage) by creating geometric coarse levels and a
>> matrix-free implementation of MatSOR and MatMult.  (The matrices are
>> great for experimenting, but if this solver is mission critical and
>> still a bottleneck, the matrix is an inefficient way to represent the
>> operator since it has very low arithmetic intensity/requires a lot of
>> memory bandwidth.)  I predict you can probably speed up the solve by
>> perhaps another factor of 2 with a good matrix-free FMG implementation.
>> Do you want to go down this path?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130814/a3895e9e/attachment-0001.pgp>
