[petsc-users] GAMG speed
Michele Rosso mrosso at uci.edu
Tue Aug 13 18:09:02 CDT 2013
Hi Karli,
thank you for your hint: now it works.
Now I would like to speed up the solution: I was counting on increasing
the number of levels/the number of processors used, but now I see I
cannot do that.
Do you have any hint to achieve better speed?
Thanks!
Best,
Michele
On 08/13/2013 01:33 PM, Karl Rupp wrote:
> Hi Michele,
> I suggest you try a different decomposition of your grid. With k
> levels, you should have at least 2^{k-1} grid nodes per coordinate
> direction in order to be able to correctly build a coarser mesh. In
> your case, you should have at least 8 nodes (leading to coarser levels
> of size 4, 2, and 1) in z direction.
> Best regards,
> Karli
> On 08/13/2013 02:28 PM, Michele Rosso wrote:
>> Hi Barry,
>> I was finally able to try multigrid with a singular system and a
>> finer grid.
>> GAMG works perfectly and has no problem in handling the singular system.
>> On the other hand, MG is giving me problem:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Argument out of range!
>> [0]PETSC ERROR: Partition in x direction is too fine! 32 64!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: ./hit on a arch-cray-xt5-pkgs-opt named nid01332 by
>> Unknown Tue Aug 13 15:06:21 2013
>> [0]PETSC ERROR: Libraries linked from
>> /nics/c/home/mrosso/LIBS/petsc-3.4.2/arch-cray-xt5-pkgs-opt/lib
>> [0]PETSC ERROR: Configure run at Wed Jul 31 22:48:06 2013
>> The input I used is:
>> -ksp_monitor -ksp_converged_reason -pc_type mg  -pc_mg_galerkin
>> -pc_mg_levels 4 -options_left
>> I am simulating a 256^3 grid with 256 processors. Since I am using a 2D
>> domain decomposition, each sub-domain contains 256x64x4 grid points.
>> To be consistent with my code indexing, I had to initialize DMDA with
>> reverse ordering, that is z,y,x, so when the error message says "x is
>> too fine" it actually means "z is too fine".
>> I was wondering what is the minimum number of nodes per direction that
>> would avoid this problem and how the number of levels is related to
>> minimum grid size required.
>> Thank you!
>> Michele
>> On 08/02/2013 03:11 PM, Barry Smith wrote:
>>> On Aug 2, 2013, at 4:52 PM, Michele Rosso<mrosso at uci.edu>  wrote:
>>>> Barry,
>>>> thank you very much for your help. I was trying to debug the error
>>>> with no success!
>>>> Now it works like a charm for me too!
>>>> I have still two questions for you:
>>>> 1) How did you choose the number of levels to use: trial and error?
>>>     I just used 2 because it is more than one level :-).  When you
>>> use a finer mesh you can use more levels.
>>>> 2) For a singular system (periodic), besides the nullspace removal,
>>>> should I change any parameter?
>>>     I don't know of anything.
>>>     But there is a possible problem with -pc_mg_galerkin, PETSc does
>>> not transfer the null space information from the fine mesh to the
>>> other meshes and technically we really want the multigrid to remove
>>> the null space on all the levels but usually it will work without
>>> worrying about that.
>>>     Barry
>>>> Again, thank you very much!
>>>> Michele
>>>> On 08/02/2013 02:38 PM, Barry Smith wrote:
>>>>>     Finally got it. My failing memory. I had to add the line
>>>>>     call KSPSetDMActive(ksp,PETSC_FALSE,ierr)
>>>>>     immediately after KSPSetDM()   and
>>>>>     change
>>>>>      call DMCreateMatrix(da,MATMPIAIJ,A,ierr)
>>>>>     to
>>>>>      call DMCreateMatrix(da,MATAIJ,A,ierr)
>>>>>      so it will work in both parallel and sequential then
>>>>> ksp_monitor -ksp_converged_reason -pc_type mg -ksp_view
>>>>> -pc_mg_galerkin -pc_mg_levels 2
>>>>> works great with 2 levels.
>>>>>     Barry
>>>>> On Aug 1, 2013, at 6:29 PM, Michele Rosso
>>>>> <mrosso at uci.edu>
>>>>>   wrote:
>>>>>> Barry,
>>>>>> no problem. I attached the full code in test_poisson_solver.tar.gz.
>>>>>> My test code is a very reduced version of my productive code
>>>>>> (incompressible DNS code) thus fftw3 and the library 2decomp&fft
>>>>>> are needed to run it.
>>>>>> I attached the 2decomp&fft version I used: it is a matter of
>>>>>> minutes to install it, so you should not have any problem.
>>>>>> Please, contact me for any question/suggestion.
>>>>>> I the mean time I will try to debug it.
>>>>>> Michele
>>>>>> On 08/01/2013 04:19 PM, Barry Smith wrote:
>>>>>>>     Run on one process until this is debugged. You can try the
>>>>>>> option
>>>>>>> -start_in_debugger noxterm
>>>>>>> and then call VecView(vec,0) in the debugger when it gives the
>>>>>>> error below. It seems like some objects are not getting their
>>>>>>> initial values set properly. Are you able to email the code so
>>>>>>> we can run it and figure out what is going on?
>>>>>>>     Barry
>>>>>>> On Aug 1, 2013, at 5:52 PM, Michele Rosso
>>>>>>> <mrosso at uci.edu>
>>>>>>>   wrote:
>>>>>>>> Barry,
>>>>>>>> I checked the matrix: the element (0,0) is not zero, nor any
>>>>>>>> other diagonal element is.
>>>>>>>> The matrix is symmetric positive define (i.e. the standard
>>>>>>>> Poisson matrix).
>>>>>>>> Also, -da_refine is never used (see previous output).
>>>>>>>> I tried to run with -pc_type mg -pc_mg_galerkin
>>>>>>>> -mg_levels_pc_type jacobi -mg_levels_ksp_type chebyshev
>>>>>>>> -mg_levels_ksp_chebyshev_estimate_eigenvalues -ksp_view
>>>>>>>> -options_left
>>>>>>>> and now the error is different:
>>>>>>>> 0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error
>>>>>>>> Message ------------------------------------
>>>>>>>> [1]PETSC ERROR: Floating point exception!
>>>>>>>> [1]PETSC ERROR: Vec entry at local location 0 is not-a-number
>>>>>>>> or infinite at beginning of function: Parameter number 2!
>>>>>>>> [1]PETSC ERROR:
>>>>>>>> [1]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>>> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>> [1]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>> shooting.
>>>>>>>> [2]PETSC ERROR: --------------------- Error Message
>>>>>>>> [2]PETSC ERROR: Floating point exception!
>>>>>>>> [2]PETSC ERROR: Vec entry at local location 0 is not-a-number
>>>>>>>> [2]PETSC ERROR:
>>>>>>>> [2]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>>> [2]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>> [2]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>> shooting.
>>>>>>>> [2]PETSC ERROR: [3]PETSC ERROR: --------------------- Error
>>>>>>>> [3]PETSC ERROR: Floating point exception!
>>>>>>>> [3]PETSC ERROR: Vec entry at local location 0 is not-a-number
>>>>>>>> [3]PETSC ERROR:
>>>>>>>> [3]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>>> [3]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>> [3]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>> shooting.
>>>>>>>> [3]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>> [3]PETSC ERROR:
>>>>>>>> [1]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>> [1]PETSC ERROR:
>>>>>>>> [1]PETSC ERROR: ./test on a linux-gnu-dbg named enterprise-A by
>>>>>>>> mic Thu Aug  1 15:43:16 2013
>>>>>>>> [1]PETSC ERROR: Libraries linked from
>>>>>>>> /opt/petsc/petsc-3.4.2/linux-gnu-dbg/lib
>>>>>>>> [2]PETSC ERROR:
>>>>>>>> [2]PETSC ERROR: ./test on a linux-gnu-dbg named enterprise-A by
>>>>>>>> [2]PETSC ERROR: Libraries linked from
>>>>>>>> [2]PETSC ERROR: Configure run at Thu Aug  1 12:01:44 2013
>>>>>>>> [2]PETSC ERROR: [3]PETSC ERROR: ./test on a linux-gnu-dbg named
>>>>>>>> enterprise-A by mic Thu Aug  1 15:43:16 2013
>>>>>>>> [3]PETSC ERROR: Libraries linked from
>>>>>>>> [3]PETSC ERROR: Configure run at Thu Aug  1 12:01:44 2013
>>>>>>>> [3]PETSC ERROR: Configure options
>>>>>>>> [1]PETSC ERROR: Configure options
>>>>>>>> [1]PETSC ERROR:
>>>>>>>> [1]PETSC ERROR: VecValidValues() line 28 in
>>>>>>>> src/vec/vec/interface/rvector.c
>>>>>>>> Configure options
>>>>>>>> [2]PETSC ERROR:
>>>>>>>> [2]PETSC ERROR: VecValidValues() line 28 in
>>>>>>>> [3]PETSC ERROR:
>>>>>>>> [3]PETSC ERROR: VecValidValues() line 28 in
>>>>>>>> [3]PETSC ERROR: [1]PETSC ERROR: MatMult() line 2174 in
>>>>>>>> src/mat/interface/matrix.c
>>>>>>>> [1]PETSC ERROR: [2]PETSC ERROR: MatMult() line 2174 in
>>>>>>>> [2]PETSC ERROR: KSP_MatMult() line 204 in
>>>>>>>> src/ksp/ksp/impls/cheby//opt/petsc/petsc-3.4.2/include/petsc-private/kspimpl.h
>>>>>>>> MatMult() line 2174 in src/mat/interface/matrix.c
>>>>>>>> [3]PETSC ERROR: KSP_MatMult() line 204 in
>>>>>>>> [1]PETSC ERROR: KSPSolve_Chebyshev() line 504 in
>>>>>>>> src/ksp/ksp/impls/cheby/cheby.c
>>>>>>>> [2]PETSC ERROR: KSPSolve_Chebyshev() line 504 in
>>>>>>>> [3]PETSC ERROR: KSPSolve() line 441 in
>>>>>>>> src/ksp/ksp/interface/itfunc.c
>>>>>>>> [1]PETSC ERROR: KSPSolve() line 441 in
>>>>>>>> [2]PETSC ERROR: PCMGMCycle_Private() line 19 in
>>>>>>>> src/ksp/pc/impls/mg/mg.c
>>>>>>>> [3]PETSC ERROR: PCMGMCycle_Private() line 19 in
>>>>>>>> PCMGMCycle_Private() line 19 in src/ksp/pc/impls/mg/mg.c
>>>>>>>> [1]PETSC ERROR: PCApply_MG() line 330 in src/ksp/pc/impls/mg/mg.c
>>>>>>>> [2]PETSC ERROR: PCApply_MG() line 330 in src/ksp/pc/impls/mg/mg.c
>>>>>>>> [2]PETSC ERROR: PCApply() line 442 in
>>>>>>>> src/ksp/pc/interface/precon.c
>>>>>>>> [3]PETSC ERROR: PCApply_MG() line 330 in src/ksp/pc/impls/mg/mg.c
>>>>>>>> [3]PETSC ERROR: PCApply() line 442 in
>>>>>>>> [1]PETSC ERROR: PCApply() line 442 in
>>>>>>>> [1]PETSC ERROR: KSP_PCApply() line 227 in
>>>>>>>> src/ksp/ksp/impls/cg//opt/petsc/petsc-3.4.2/include/petsc-private/kspimpl.h
>>>>>>>> [2]PETSC ERROR: KSP_PCApply() line 227 in
>>>>>>>> [2]PETSC ERROR: [3]PETSC ERROR: KSP_PCApply() line 227 in
>>>>>>>> [3]PETSC ERROR: KSPSolve_CG() line 175 in
>>>>>>>> src/ksp/ksp/impls/cg/cg.c
>>>>>>>> [1]PETSC ERROR: KSPSolve_CG() line 175 in
>>>>>>>> KSPSolve_CG() line 175 in src/ksp/ksp/impls/cg/cg.c
>>>>>>>> [2]PETSC ERROR: KSPSolve() line 441 in
>>>>>>>> [0]PETSC ERROR: Floating point exception!
>>>>>>>> [0]PETSC ERROR: Vec entry at local location 0 is not-a-number
>>>>>>>> [0]PETSC ERROR:
>>>>>>>> shooting.
>>>>>>>> [0]PETSC ERROR:
>>>>>>>> [0]PETSC ERROR: ./test on a linux-gnu-dbg named enterprise-A by
>>>>>>>> [0]PETSC ERROR: Configure run at Thu Aug  1 12:01:44 2013
>>>>>>>> [0]PETSC ERROR: Configure options
>>>>>>>> [0]PETSC ERROR:
>>>>>>>> [0]PETSC ERROR: VecValidValues() line 28 in
>>>>>>>> [0]PETSC ERROR: MatMult() line 2174 in src/mat/interface/matrix.c
>>>>>>>> [0]PETSC ERROR: KSP_MatMult() line 204 in
>>>>>>>> [0]PETSC ERROR: KSPSolve_Chebyshev() line 504 in
>>>>>>>> [0]PETSC ERROR: KSPSolve() line 441 in
>>>>>>>> [0]PETSC ERROR: PCMGMCycle_Private() line 19 in
>>>>>>>> [0]PETSC ERROR: PCApply_MG() line 330 in src/ksp/pc/impls/mg/mg.c
>>>>>>>> [0]PETSC ERROR: PCApply() line 442 in
>>>>>>>> [0]PETSC ERROR: KSP_PCApply() line 227 in
>>>>>>>> [0]PETSC ERROR: KSPSolve_CG() line 175 in
>>>>>>>> #PETSc Option Table entries:
>>>>>>>> -ksp_view
>>>>>>>> -options_left
>>>>>>>> -pc_mg_galerkin
>>>>>>>> -pc_type mg
>>>>>>>> #End of PETSc Option Table entries
>>>>>>>> There are no unused options.
>>>>>>>> Michele
>>>>>>>> On 08/01/2013 03:27 PM, Barry Smith wrote:
>>>>>>>>>    Do a MatView() on A before the solve (remove the -da_refine
>>>>>>>>> 4) so it is small. Is the 0,0 entry 0? If the matrix has zero
>>>>>>>>> on the diagonals you cannot us Gauss-Seidel as the smoother.
>>>>>>>>> You can start with -mg_levels_pc_type jacobi
>>>>>>>>> -mg_levels_ksp_type chebychev
>>>>>>>>>     Is the matrix a Stokes-like matrix? If so then different
>>>>>>>>> preconditioners are in order.
>>>>>>>>>     Barry
>>>>>>>>> On Aug 1, 2013, at 5:21 PM, Michele Rosso
>>>>>>>>> <mrosso at uci.edu>
>>>>>>>>>   wrote:
>>>>>>>>>> Barry,
>>>>>>>>>> here it is the fraction of code where I set the rhs term and
>>>>>>>>>> the matrix.
>>>>>>>>>>         ! Create matrix
>>>>>>>>>>         call form_matrix( A , qrho, lsf, head )
>>>>>>>>>>         call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>>>>>>>>>>         call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
>>>>>>>>>>         ! Create rhs term
>>>>>>>>>>         call form_rhs(work, qrho, lsf, b , head)
>>>>>>>>>>         ! Solve system
>>>>>>>>>>         call KSPSetFromOptions(ksp,ierr)
>>>>>>>>>>         call KSPSetUp(ksp,ierr)
>>>>>>>>>>         call KSPSolve(ksp,b,x,ierr)
>>>>>>>>>>         call KSPGetIterationNumber(ksp, iiter ,ierr)
>>>>>>>>>> The subroutine form_matrix returns the Mat object A that is
>>>>>>>>>> filled by using MatSetValuesStencil.
>>>>>>>>>> qrho, lsf and head are additional arguments that are needed
>>>>>>>>>> to compute the matrix value.
>>>>>>>>>> Michele
>>>>>>>>>> On 08/01/2013 03:11 PM, Barry Smith wrote:
>>>>>>>>>>>    Where are you putting the values into the matrix? It
>>>>>>>>>>> seems the matrix has no values in it? The code is stopping
>>>>>>>>>>> because in the Gauss-Seidel smoothing it has detected zero
>>>>>>>>>>> diagonals.
>>>>>>>>>>>     Barry
>>>>>>>>>>> On Aug 1, 2013, at 4:47 PM, Michele Rosso
>>>>>>>>>>> <mrosso at uci.edu>
>>>>>>>>>>>   wrote:
>>>>>>>>>>>> Barry,
>>>>>>>>>>>> I run with :   -pc_type mg -pc_mg_galerkin -da_refine 4
>>>>>>>>>>>> -ksp_view -options_left
>>>>>>>>>>>> For the test I use a 64^3 grid and 4 processors.
>>>>>>>>>>>> The output is:
>>>>>>>>>>>> [2]PETSC ERROR: Arguments are incompatible!
>>>>>>>>>>>> [2]PETSC ERROR: Zero diagonal on row 0!
>>>>>>>>>>>> [2]PETSC ERROR:
>>>>>>>>>>>> updates.
>>>>>>>>>>>> shooting.
>>>>>>>>>>>> [2]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>>>> [2]PETSC ERROR:
>>>>>>>>>>>> enterprise-A by mic Thu Aug  1 14:44:04 2013
>>>>>>>>>>>> [0]PETSC ERROR: [2]PETSC ERROR: Libraries linked from
>>>>>>>>>>>> [2]PETSC ERROR: Configure options
>>>>>>>>>>>> [2]PETSC ERROR:
>>>>>>>>>>>> [2]PETSC ERROR: MatInvertDiagonal_SeqAIJ() line 1457 in
>>>>>>>>>>>> src/mat/impls/aij/seq/aij.c
>>>>>>>>>>>> [2]PETSC ERROR: MatSOR_SeqAIJ() line 1489 in
>>>>>>>>>>>> [2]PETSC ERROR: MatSOR_MPIAIJ() line 1623 in
>>>>>>>>>>>> src/mat/impls/aij/mpi/mpiaij.c
>>>>>>>>>>>> [2]PETSC ERROR: MatSOR() line 3649 in
>>>>>>>>>>>> [2]PETSC ERROR: [0]PETSC ERROR: PCApply_SOR() line 35 in
>>>>>>>>>>>> src/ksp/pc/impls/sor/sor.c
>>>>>>>>>>>> src/ksp/ksp/interface//opt/petsc/petsc-3.4.2/include/petsc-private/kspimpl.h
>>>>>>>>>>>> [2]PETSC ERROR: KSPInitialResidual() line 64 in
>>>>>>>>>>>> src/ksp/ksp/interface/itres.c
>>>>>>>>>>>> [2]PETSC ERROR: KSPSolve_GMRES() line 239 in
>>>>>>>>>>>> src/ksp/ksp/impls/gmres/gmres.c
>>>>>>>>>>>> [2]PETSC ERROR: [0]PETSC ERROR: KSPSolve_Chebyshev() line
>>>>>>>>>>>> 409 in src/ksp/ksp/impls/cheby/cheby.c
>>>>>>>>>>>> [0]PETSC ERROR: [2]PETSC ERROR: KSP_PCApply() line 227 in
>>>>>>>>>>>> [2]PETSC ERROR: KSPSolve_CG() line 175 in
>>>>>>>>>>>> updates.
>>>>>>>>>>>> [3]PETSC ERROR: [0]PETSC ERROR: See docs/faq.html for hints
>>>>>>>>>>>> [3]PETSC ERROR: Arguments are incompatible!
>>>>>>>>>>>> [3]PETSC ERROR: Zero diagonal on row 0!
>>>>>>>>>>>> [3]PETSC ERROR:
>>>>>>>>>>>> updates.
>>>>>>>>>>>> shooting.
>>>>>>>>>>>> [3]PETSC ERROR:
>>>>>>>>>>>> [1]PETSC ERROR: [3]PETSC ERROR: Configure run at Thu Aug  1
>>>>>>>>>>>> 12:01:44 2013
>>>>>>>>>>>> [3]PETSC ERROR:
>>>>>>>>>>>> [3]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>> [3]PETSC ERROR: MatSOR_SeqAIJ() line 1489 in
>>>>>>>>>>>> [3]PETSC ERROR: [0]PETSC ERROR: MatSOR_MPIAIJ() line 1623
>>>>>>>>>>>> in src/mat/impls/aij/mpi/mpiaij.c
>>>>>>>>>>>> [1]PETSC ERROR: Arguments are incompatible!
>>>>>>>>>>>> [1]PETSC ERROR: Zero diagonal on row 0!
>>>>>>>>>>>> [1]PETSC ERROR:
>>>>>>>>>>>> updates.
>>>>>>>>>>>> shooting.
>>>>>>>>>>>> [1]PETSC ERROR:
>>>>>>>>>>>> [1]PETSC ERROR: Configure run at Thu Aug  1 12:01:44 2013
>>>>>>>>>>>> [1]PETSC ERROR:
>>>>>>>>>>>> [1]PETSC ERROR: MatInvertDiagonal_SeqAIJ() line 1457 in
>>>>>>>>>>>> [1]PETSC ERROR: [3]PETSC ERROR: MatSOR() line 3649 in
>>>>>>>>>>>> [3]PETSC ERROR: PCApply_SOR() line 35 in
>>>>>>>>>>>> [3]PETSC ERROR: KSPInitialResidual() line 64 in
>>>>>>>>>>>> [3]PETSC ERROR: KSPSolve_GMRES() line 239 in
>>>>>>>>>>>> [3]PETSC ERROR: KSPSolve_Chebyshev() line 409 in
>>>>>>>>>>>> MatSOR_SeqAIJ() line 1489 in src/mat/impls/aij/seq/aij.c
>>>>>>>>>>>> [1]PETSC ERROR: MatSOR_MPIAIJ() line 1623 in
>>>>>>>>>>>> [1]PETSC ERROR: MatSOR() line 3649 in
>>>>>>>>>>>> [1]PETSC ERROR: PCApply_SOR() line 35 in
>>>>>>>>>>>> [1]PETSC ERROR: KSPInitialResidual() line 64 in
>>>>>>>>>>>> [1]PETSC ERROR: KSPSolve_GMRES() line 239 in
>>>>>>>>>>>> [1]PETSC ERROR: KSPSolve_Chebyshev() line 409 in
>>>>>>>>>>>> [1]PETSC ERROR: PCMGMCycle_Private() line 19 in
>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>> [0]PETSC ERROR: MatInvertDiagonal_SeqAIJ() line 1457 in
>>>>>>>>>>>> [0]PETSC ERROR: MatSOR_SeqAIJ() line 1489 in
>>>>>>>>>>>> [0]PETSC ERROR: MatSOR_MPIAIJ() line 1623 in
>>>>>>>>>>>> [0]PETSC ERROR: MatSOR() line 3649 in
>>>>>>>>>>>> [0]PETSC ERROR: KSPInitialResidual() line 64 in
>>>>>>>>>>>> [0]PETSC ERROR: KSPSolve_GMRES() line 239 in
>>>>>>>>>>>> [0]PETSC ERROR: KSPSolve_Chebyshev() line 409 in
>>>>>>>>>>>> -da_refine 4
>>>>>>>>>>>> -ksp_view
>>>>>>>>>>>> -options_left
>>>>>>>>>>>> -pc_mg_galerkin
>>>>>>>>>>>> -pc_type mg
>>>>>>>>>>>> There is one unused database option. It is:
>>>>>>>>>>>> Option left: name:-da_refine value: 4
>>>>>>>>>>>> Here is the code I use to setup DMDA and KSP:
>>>>>>>>>>>>      call DMDACreate3d( PETSC_COMM_WORLD
>>>>>>>>>>>>                      & DMDA_BOUNDARY_PERIODIC ,
>>>>>>>>>>>> DMDA_BOUNDARY_PERIODIC,     &
>>>>>>>>>>>> DMDA_STENCIL_STAR,          &
>>>>>>>>>>>>                      & N_Z , N_Y , N_X , N_B3 , N_B2 ,
>>>>>>>>>>>> 1_ip,  1_ip , 1_ip , &
>>>>>>>>>>>>                      & int(NNZ,ip) ,int(NNY,ip) , NNX, da ,
>>>>>>>>>>>> ierr)
>>>>>>>>>>>>           ! Create Global Vectors
>>>>>>>>>>>>      call DMCreateGlobalVector(da,b,ierr)
>>>>>>>>>>>>      call VecDuplicate(b,x,ierr)
>>>>>>>>>>>>           ! Set initial guess for first use of the module to 0
>>>>>>>>>>>>      call VecSet(x,0.0_rp,ierr)
>>>>>>>>>>>>           ! Create matrix
>>>>>>>>>>>>            ! Create solver
>>>>>>>>>>>>      call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
>>>>>>>>>>>>      call KSPSetDM(ksp,da,ierr)
>>>>>>>>>>>>      call
>>>>>>>>>>>> KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
>>>>>>>>>>>> !    call KSPSetOperators(ksp,A,A,SAME_NONZERO_PATTERN,ierr)
>>>>>>>>>>>>      call KSPSetType(ksp,KSPCG,ierr)
>>>>>>>>>>>>      call
>>>>>>>>>>>> KSPSetNormType(ksp,KSP_NORM_UNPRECONDITIONED,ierr) ! Real
>>>>>>>>>>>> residual
>>>>>>>>>>>>      call KSPSetInitialGuessNonzero(ksp,PETSC_TRUE,ierr)
>>>>>>>>>>>>      call KSPSetTolerances(ksp, tol
>>>>>>>>>>>> ,PETSC_DEFAULT_DOUBLE_PRECISION,&
>>>>>>>>>>>> PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_INTEGER,ierr)
>>>>>>>>>>>>      ! To allow using option from command line
>>>>>>>>>>>> Michele
>>>>>>>>>>>> On 08/01/2013 01:04 PM, Barry Smith wrote:
>>>>>>>>>>>>>     You can use the option -pc_mg_galerkin  and then MG
>>>>>>>>>>>>> will compute the coarser matrices with a sparse matrix
>>>>>>>>>>>>> matrix matrix product so you should not need to change
>>>>>>>>>>>>> your code to try it out.  You still need to use the
>>>>>>>>>>>>> KSPSetDM() and -da_refine n to get it working
>>>>>>>>>>>>>     If it doesn't work, send us all the output.
>>>>>>>>>>>>>     Barry
>>>>>>>>>>>>> On Aug 1, 2013, at 2:47 PM, Michele Rosso
>>>>>>>>>>>>> <mrosso at uci.edu>
>>>>>>>>>>>>>   wrote:
>>>>>>>>>>>>>> Barry,
>>>>>>>>>>>>>> you are correct, I did not use it. I think I get now
>>>>>>>>>>>>>> where is the problem. Correct me if I am wrong, but for the
>>>>>>>>>>>>>> geometric multigrid to work, ksp must be provided with
>>>>>>>>>>>>>> subroutines to compute the matrix and the rhs at any
>>>>>>>>>>>>>> level through
>>>>>>>>>>>>>> KSPSetComputeOperators and KSPSetComputeRHS.
>>>>>>>>>>>>>> I do not do that, I simply build a rhs vector and a
>>>>>>>>>>>>>> matrix and then I solve the system.
>>>>>>>>>>>>>> If you confirm what I just wrote, I will try to modify my
>>>>>>>>>>>>>> code accordingly and get back to you.
>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>> Michele
>>>>>>>>>>>>>>   On 08/01/2013 11:48 AM, Barry Smith wrote:
>>>>>>>>>>>>>>>    Do you use KSPSetDM(ksp,da);  ?  See
>>>>>>>>>>>>>>> src/ksp/ksp/examples/tutorials/ex19.c
>>>>>>>>>>>>>>>     Barry
>>>>>>>>>>>>>>> On Aug 1, 2013, at 1:35 PM, Michele Rosso
>>>>>>>>>>>>>>> <mrosso at uci.edu>
>>>>>>>>>>>>>>>   wrote:
>>>>>>>>>>>>>>>> Barry,
>>>>>>>>>>>>>>>> I am using a finite difference Cartesian uniform grid
>>>>>>>>>>>>>>>> and DMDA and so far it has not given me any problem.
>>>>>>>>>>>>>>>> I am using a ksp solver (not snes). In a previous
>>>>>>>>>>>>>>>> thread, I was told an odd number of grid points was
>>>>>>>>>>>>>>>> needed for the geometric multigrid, is that correct?
>>>>>>>>>>>>>>>> I tried to run my case with
>>>>>>>>>>>>>>>> -pc_type mg -da_refine 4
>>>>>>>>>>>>>>>> but it does not seem to use the -da_refine option:
>>>>>>>>>>>>>>>> mpiexec   -np 4 ./test  -pc_type mg -da_refine 4
>>>>>>>>>>>>>>>> KSP Object: 4 MPI processes
>>>>>>>>>>>>>>>>   type: cg
>>>>>>>>>>>>>>>>   maximum iterations=10000
>>>>>>>>>>>>>>>>   tolerances:  relative=1e-08, absolute=1e-50,
>>>>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>>>>   left preconditioning
>>>>>>>>>>>>>>>>   using nonzero initial guess
>>>>>>>>>>>>>>>>   using UNPRECONDITIONED norm type for convergence test
>>>>>>>>>>>>>>>> PC Object: 4 MPI processes
>>>>>>>>>>>>>>>>   type: mg
>>>>>>>>>>>>>>>>     MG: type is MULTIPLICATIVE, levels=1 cycles=v
>>>>>>>>>>>>>>>>       Cycles per PCApply=1
>>>>>>>>>>>>>>>>       Not using Galerkin computed coarse grid matrices
>>>>>>>>>>>>>>>>   Coarse grid solver -- level
>>>>>>>>>>>>>>>>     KSP Object: (mg_levels_0_)     4 MPI processes
>>>>>>>>>>>>>>>>       type: chebyshev
>>>>>>>>>>>>>>>>         Chebyshev: eigenvalue estimates:  min =
>>>>>>>>>>>>>>>> 0.134543, max = 1.47998
>>>>>>>>>>>>>>>>         Chebyshev: estimated using: [0 0.1; 0 1.1]
>>>>>>>>>>>>>>>>         KSP Object: (mg_levels_0_est_)         4 MPI
>>>>>>>>>>>>>>>> processes
>>>>>>>>>>>>>>>>           type: gmres
>>>>>>>>>>>>>>>>             GMRES: restart=30, using Classical
>>>>>>>>>>>>>>>> (unmodified) Gram-Schmidt Orthogonalization with no
>>>>>>>>>>>>>>>> iterative refinement
>>>>>>>>>>>>>>>>             GMRES: happy breakdown tolerance 1e-30
>>>>>>>>>>>>>>>>           maximum iterations=10, initial guess is zero
>>>>>>>>>>>>>>>>           tolerances: relative=1e-05, absolute=1e-50,
>>>>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>>>>           using NONE norm type for convergence test
>>>>>>>>>>>>>>>>         PC Object: (mg_levels_0_)         4 MPI processes
>>>>>>>>>>>>>>>>           type: sor
>>>>>>>>>>>>>>>>             SOR: type = local_symmetric, iterations =
>>>>>>>>>>>>>>>> 1, local iterations = 1, omega = 1
>>>>>>>>>>>>>>>>           linear system matrix = precond matrix:
>>>>>>>>>>>>>>>>           Matrix Object:           4 MPI processes
>>>>>>>>>>>>>>>>             type: mpiaij
>>>>>>>>>>>>>>>>             rows=262144, cols=262144
>>>>>>>>>>>>>>>>             total: nonzeros=1835008, allocated
>>>>>>>>>>>>>>>> nonzeros=1835008
>>>>>>>>>>>>>>>>             total number of mallocs used during
>>>>>>>>>>>>>>>> MatSetValues calls =0
>>>>>>>>>>>>>>>>       maximum iterations=1, initial guess is zero
>>>>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>>>>       type: sor
>>>>>>>>>>>>>>>>         SOR: type = local_symmetric, iterations = 1,
>>>>>>>>>>>>>>>>         type: mpiaij
>>>>>>>>>>>>>>>> nonzeros=1835008
>>>>>>>>>>>>>>>>     type: mpiaij
>>>>>>>>>>>>>>>>     total: nonzeros=1835008, allocated nonzeros=1835008
>>>>>>>>>>>>>>>>     total number of mallocs used during MatSetValues
>>>>>>>>>>>>>>>> calls =0
>>>>>>>>>>>>>>>> Solution       =    1.53600013 sec
>>>>>>>>>>>>>>>> -da_refine 4
>>>>>>>>>>>>>>>> -ksp_view
>>>>>>>>>>>>>>>> -options_left
>>>>>>>>>>>>>>>> -pc_type mg
>>>>>>>>>>>>>>>> Michele
>>>>>>>>>>>>>>>> On 08/01/2013 11:21 AM, Barry Smith wrote:
>>>>>>>>>>>>>>>>>     What kind of mesh are you using? Are you using
>>>>>>>>>>>>>>>>> DMDA? If you are using DMDA (and have written your
>>>>>>>>>>>>>>>>> code to use it "correctly") then it should be trivial
>>>>>>>>>>>>>>>>> to run with geometric multigrid and geometric
>>>>>>>>>>>>>>>>> multigrid should be a bit faster.
>>>>>>>>>>>>>>>>>     For example on src/snes/examples/tutorials/ex19.c
>>>>>>>>>>>>>>>>> I run with ./ex19 -pc_type mg -da_refine 4 and it
>>>>>>>>>>>>>>>>> refines the original DMDA 4 times and uses geometric
>>>>>>>>>>>>>>>>> multigrid with 5 levels.
>>>>>>>>>>>>>>>>>     Barry
>>>>>>>>>>>>>>>>> On Aug 1, 2013, at 1:14 PM, Michele Rosso
>>>>>>>>>>>>>>>>> <mrosso at uci.edu>
>>>>>>>>>>>>>>>>>   wrote:
>>>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>>>> I am successfully using PETSc (v3.4.2)  to solve a 3D
>>>>>>>>>>>>>>>>>> Poisson's equation with CG + GAMG as I was suggested
>>>>>>>>>>>>>>>>>> to do in a previous thread.
>>>>>>>>>>>>>>>>>> So far I am using GAMG with the default settings, i.e.
>>>>>>>>>>>>>>>>>> -pc_type gamg -pc_gamg_agg_nsmooths 1
>>>>>>>>>>>>>>>>>> The speed of the solution is satisfactory, but I
>>>>>>>>>>>>>>>>>> would like to know if you have any suggestions to
>>>>>>>>>>>>>>>>>> further speed it up, particularly
>>>>>>>>>>>>>>>>>> if there is any parameters worth looking into to
>>>>>>>>>>>>>>>>>> achieve an even faster solution, for example number
>>>>>>>>>>>>>>>>>> of levels and so on.
>>>>>>>>>>>>>>>>>> So far I am using Dirichlet's BCs for my test case,
>>>>>>>>>>>>>>>>>> but I will soon have periodic conditions: in this
>>>>>>>>>>>>>>>>>> case, does GAMG require particular settings?
>>>>>>>>>>>>>>>>>> Finally, I did not try geometric multigrid: do you
>>>>>>>>>>>>>>>>>> think it is worth a shot?
>>>>>>>>>>>>>>>>>> Here are my current settings:
>>>>>>>>>>>>>>>>>> I run with
>>>>>>>>>>>>>>>>>> -pc_type gamg -pc_gamg_agg_nsmooths 1 -ksp_view
>>>>>>>>>>>>>>>>>> -options_left
>>>>>>>>>>>>>>>>>> and the output is:
>>>>>>>>>>>>>>>>>>    type: cg
>>>>>>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>>>>>>    type: gamg
>>>>>>>>>>>>>>>>>>      MG: type is MULTIPLICATIVE, levels=3 cycles=v
>>>>>>>>>>>>>>>>>>        Using Galerkin computed coarse grid matrices
>>>>>>>>>>>>>>>>>>      KSP Object: (mg_coarse_)     4 MPI processes
>>>>>>>>>>>>>>>>>>        type: preonly
>>>>>>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>>>>>>      PC Object: (mg_coarse_)     4 MPI processes
>>>>>>>>>>>>>>>>>>        type: bjacobi
>>>>>>>>>>>>>>>>>>          block Jacobi: number of blocks = 4
>>>>>>>>>>>>>>>>>>          Local solve info for each block is in the
>>>>>>>>>>>>>>>>>> following KSP and PC objects:
>>>>>>>>>>>>>>>>>>        [0] number of local blocks = 1, first local
>>>>>>>>>>>>>>>>>> block number = 0
>>>>>>>>>>>>>>>>>>                  [0] local block number 0
>>>>>>>>>>>>>>>>>> KSP Object: (mg_coarse_sub_)         1 MPI processes
>>>>>>>>>>>>>>>>>>            type: preonly
>>>>>>>>>>>>>>>>>> absolute=1e-50, divergence=10000
>>>>>>>>>>>>>>>>>> KSP Object: (mg_coarse_sub_)            left
>>>>>>>>>>>>>>>>>> preconditioning
>>>>>>>>>>>>>>>>>>            PC Object: (mg_coarse_sub_)       1 MPI
>>>>>>>>>>>>>>>>>> processes
>>>>>>>>>>>>>>>>>>            type: preonly
>>>>>>>>>>>>>>>>>>           1 MPI processes
>>>>>>>>>>>>>>>>>>            type: lu
>>>>>>>>>>>>>>>>>>            LU: out-of-place factorization
>>>>>>>>>>>>>>>>>> processes
>>>>>>>>>>>>>>>>>>            type: lu
>>>>>>>>>>>>>>>>>>            tolerance for zero pivot 2.22045e-14
>>>>>>>>>>>>>>>>>>              using diagonal shift on blocks to
>>>>>>>>>>>>>>>>>> prevent zero pivot
>>>>>>>>>>>>>>>>>>              matrix ordering: nd
>>>>>>>>>>>>>>>>>> prevent zero pivot
>>>>>>>>>>>>>>>>>>              matrix ordering: nd
>>>>>>>>>>>>>>>>>>              factor fill ratio given 5, needed 0
>>>>>>>>>>>>>>>>>>                Factored matrix follows:
>>>>>>>>>>>>>>>>>>              factor fill ratio given 5, needed 4.13207
>>>>>>>>>>>>>>>>>>                    Matrix Object:              Matrix
>>>>>>>>>>>>>>>>>> Object:                 1 MPI processes
>>>>>>>>>>>>>>>>>>                    type: seqaij
>>>>>>>>>>>>>>>>>>                      rows=395, cols=395
>>>>>>>>>>>>>>>>>>                      package used to perform
>>>>>>>>>>>>>>>>>> factorization: petsc
>>>>>>>>>>>>>>>>>>                    total: nonzeros=132379, allocated
>>>>>>>>>>>>>>>>>> nonzeros=132379
>>>>>>>>>>>>>>>>>> during MatSetValues calls =0
>>>>>>>>>>>>>>>>>>                          not using I-node routines
>>>>>>>>>>>>>>>>>>             1 MPI processes
>>>>>>>>>>>>>>>>>>                    type: seqaij
>>>>>>>>>>>>>>>>>>                      rows=0, cols=0
>>>>>>>>>>>>>>>>>>                    total: nonzeros=1, allocated
>>>>>>>>>>>>>>>>>> nonzeros=1
>>>>>>>>>>>>>>>>>>    Matrix Object:             1 MPI processes
>>>>>>>>>>>>>>>>>>              type: seqaij
>>>>>>>>>>>>>>>>>>            Matrix Object:KSP Object:           1 MPI
>>>>>>>>>>>>>>>>>> processes
>>>>>>>>>>>>>>>>>>              type: seqaij
>>>>>>>>>>>>>>>>>>              rows=0, cols=0
>>>>>>>>>>>>>>>>>>              total: nonzeros=0, allocated nonzeros=0
>>>>>>>>>>>>>>>>>>            rows=395, cols=395
>>>>>>>>>>>>>>>>>>              total: nonzeros=32037, allocated
>>>>>>>>>>>>>>>>>> nonzeros=32037
>>>>>>>>>>>>>>>>>> processes
>>>>>>>>>>>>>>>>>>            type: preonly
>>>>>>>>>>>>>>>>>> processes
>>>>>>>>>>>>>>>>>>            type: lu
>>>>>>>>>>>>>>>>>> prevent zero pivot
>>>>>>>>>>>>>>>>>>              matrix ordering: nd
>>>>>>>>>>>>>>>>>> processes
>>>>>>>>>>>>>>>>>>                    type: seqaij
>>>>>>>>>>>>>>>>>>                    rows=0, cols=0
>>>>>>>>>>>>>>>>>> nonzeros=1
>>>>>>>>>>>>>>>>>>              type: seqaij
>>>>>>>>>>>>>>>>>>              rows=0, cols=0
>>>>>>>>>>>>>>>>>>            type: preonly
>>>>>>>>>>>>>>>>>> processes
>>>>>>>>>>>>>>>>>>            type: lu
>>>>>>>>>>>>>>>>>> prevent zero pivot
>>>>>>>>>>>>>>>>>>              matrix ordering: nd
>>>>>>>>>>>>>>>>>> processes
>>>>>>>>>>>>>>>>>>                    type: seqaij
>>>>>>>>>>>>>>>>>>                    rows=0, cols=0
>>>>>>>>>>>>>>>>>> nonzeros=1
>>>>>>>>>>>>>>>>>>              type: seqaij
>>>>>>>>>>>>>>>>>>              rows=0, cols=0
>>>>>>>>>>>>>>>>>>        [1] number of local blocks = 1, first local
>>>>>>>>>>>>>>>>>> block number = 1
>>>>>>>>>>>>>>>>>>          [1] local block number 0
>>>>>>>>>>>>>>>>>>        [2] number of local blocks = 1, first local
>>>>>>>>>>>>>>>>>> block number = 2
>>>>>>>>>>>>>>>>>>          [2] local block number 0
>>>>>>>>>>>>>>>>>>        [3] number of local blocks = 1, first local
>>>>>>>>>>>>>>>>>> block number = 3
>>>>>>>>>>>>>>>>>>          [3] local block number 0
>>>>>>>>>>>>>>>>>>          type: mpiaij
>>>>>>>>>>>>>>>>>>          rows=395, cols=395
>>>>>>>>>>>>>>>>>>          total: nonzeros=32037, allocated nonzeros=32037
>>>>>>>>>>>>>>>>>>            not using I-node (on process 0) routines
>>>>>>>>>>>>>>>>>>    Down solver (pre-smoother) on level 1
>>>>>>>>>>>>>>>>>>      KSP Object: (mg_levels_1_)     4 MPI processes
>>>>>>>>>>>>>>>>>>        type: chebyshev
>>>>>>>>>>>>>>>>>> 0.0636225, max = 1.33607
>>>>>>>>>>>>>>>>>>        maximum iterations=2
>>>>>>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>>>>>>      PC Object: (mg_levels_1_)     4 MPI processes
>>>>>>>>>>>>>>>>>>        type: jacobi
>>>>>>>>>>>>>>>>>>          type: mpiaij
>>>>>>>>>>>>>>>>>>          rows=23918, cols=23918
>>>>>>>>>>>>>>>>>>          total: nonzeros=818732, allocated
>>>>>>>>>>>>>>>>>> nonzeros=818732
>>>>>>>>>>>>>>>>>>    Up solver (post-smoother) same as down solver
>>>>>>>>>>>>>>>>>> (pre-smoother)
>>>>>>>>>>>>>>>>>>    Down solver (pre-smoother) on level 2
>>>>>>>>>>>>>>>>>>      KSP Object: (mg_levels_2_)     4 MPI processes
>>>>>>>>>>>>>>>>>>        type: chebyshev
>>>>>>>>>>>>>>>>>> 0.0971369, max = 2.03987
>>>>>>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>>>>>>      PC Object: (mg_levels_2_)     4 MPI processes
>>>>>>>>>>>>>>>>>>        type: jacobi
>>>>>>>>>>>>>>>>>>          type: mpiaij
>>>>>>>>>>>>>>>>>> nonzeros=1835008
>>>>>>>>>>>>>>>>>> (pre-smoother)
>>>>>>>>>>>>>>>>>>      type: mpiaij
>>>>>>>>>>>>>>>>>> calls =0
>>>>>>>>>>>>>>>>>> -ksp_view
>>>>>>>>>>>>>>>>>> -options_left
>>>>>>>>>>>>>>>>>> -pc_type gamg
>>>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>>>> Michele
>>>>>> <test_poisson_solver.tar.gz><2decomp_fft-1.5.847-modified.tar.gz>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130813/5f240378/attachment-0001.html>
