[petsc-users] How to exclude -C compiler option (VecGetArray in Fortran)
Fri Aug 9 16:52:46 CDT 2013
On Fri, 9 Aug 2013, Danyang Su wrote:
> Hi All,
> I get some problem in VecGetArray in Fortran, which I guess is due to the
> default -C compiler option.
> Current compiler option are:
> $ make ksp_inhm
> /cygdrive/c/cygwin/packages/petsc-3.4.2/bin/win32fe/win32fe ifort -c  -MT -Z7
> -fpp  -I/cygdrive/c/cygwin/packages/petsc-3.4.2/in
> clude -I/cygdrive/c/cygwin/packages/petsc-3.4.2/arch-mswin-c-debug/include
> -I/cygdrive/c/cygwin/packages/parmetis-4.0.3/include
> -I/cygdrive/c/cygwin/packages/metis-5.1.0/include -I/cygdrive/c/Program\
> Files/MPICH2/include    -o ksp_inhm.o ksp_inhm.F90
> /cygdrive/c/cygwin/packages/petsc-3.4.2/bin/win32fe/win32fe cl -MT -wd4996 -Z7
> -o ksp_inhm_d ksp_inhm.o  -L/cygdrive/c/cygwin/p
> ackages/petsc-3.4.2/arch-mswin-c-debug/lib  -lpetsc -lflapack -lfblas
> /cygdrive/c/cygwin/packages/parmetis-4.0.3/build/libparmet
> is/Release/parmetis.lib
> /cygdrive/c/cygwin/packages/metis-5.1.0/build/libmetis/Release/metis.lib
> /cygdrive/c/Program\ Files/MPIC
> H2/lib/fmpich2.lib /cygdrive/c/Program\ Files/MPICH2/lib/fmpich2g.lib
> /cygdrive/c/Program\ Files/MPICH2/lib/mpi.lib Gdi32.lib Us
> er32.lib Advapi32.lib Kernel32.lib Ws2_32.lib
> Relevant codes are as follows:
> #define xx_a(ib) xx_v(xx_i + (ib))
>       PetscScalar :: xx_v(1)
>       PetscOffset :: xx_i
> call VecGetArray(x, xx_v, xx_i, ierr)
> write(*, 90) istart+1, xx_a(istart+1), iend, xx_a(iend)    !istart and iend
> are the ownership range
> 90          format ('x(', i6, ') = ',e11.4, ' x(', i6, ') = ',e11.4)
> call VecRestoreArray(x, xx_v, xx_i, ierr)
> The output (xx_a(istart+1), xx_a(iend)) is CORRECT for the processor 0, but
> INCORRECT for the other processors.
The code is buggy. You should use xx_a(1),xx_a(n) - where 'n' is the local size.
You can use VecGetLocalSize() to get the local size.
> I found in the manual that for the fortran user, the compiler option -C should
> not be used. How I can set this option?
This issuse is not -C related. If it were - you would have to use
VecGetArrayF90() - [which should be the prefered function anyway.]
Satish
> Thanks and regards,
> Danyang
