[petsc-users] problem (Segmentation voilation) using -pc_type hypre -pc_hypre_type -pilut with multiple nodes in a cluster
Fri Aug 9 11:58:44 CDT 2013
On Fri, Aug 9, 2013 at 11:52 AM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> Dear all,
> I was experimenting with my stokes problem in 3D staggered grid with high
> viscosity jump using -pc_fieldsplit of type schur complement. Using hypre
> pilut preconditioner for the ksp for A00 block seemed to be giving nice
> results for smaller size. Using the following options in my laptop, or in
> the cluster I'm using with ONE node multiple cores WORKS fine:
> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
> -fieldsplit_0_ksp_type gcr -fieldsplit_0_ksp_rtol 1.0e-5
> -fieldsplit_0_pc_type hypre -fieldsplit_0_pc_hypre_type pilut
> But when I try to submit jobs with multiple nodes, the process never seem
> to end! When using gamg instead of hypre, the same program works with
> multiple nodes in the same cluster.
> But gamg gave much slower convergence than the hypre, so I wanted to use
> the hypre.
Did you give a near nullspace to GAMG (probably the 3 translational and 3
rotational modes for this problem)? Without these,
convergence can be quite slow.
> When I kill the job and look at the error file, the error it reports:
It looks like PILUT is just slow.
  Matt
> [8]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [8]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [8]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[8]PETSCERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [8]PETSC ERROR: likely location of problem given in stack below
> [8]PETSC ERROR: ---------------------  Stack Frames
> [8]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [8]PETSC ERROR:       INSTEAD the line number of the start of the function
> [8]PETSC ERROR:       is given.
> [8]PETSC ERROR: [8] HYPRE_SetupXXX line 130
> /tmp/petsc-3.4.1/src/ksp/pc/impls/hypre/hypre.c
> [8]PETSC ERROR: [8] PCSetUp_HYPRE line 94
> [8]PETSC ERROR: [8] PCSetUp line 868
> /tmp/petsc-3.4.1/src/ksp/pc/interface/precon.c
> [8]PETSC ERROR: [8] KSPSetUp line 192
> /tmp/petsc-3.4.1/src/ksp/ksp/interface/itfunc.c
> [8]PETSC ERROR: [8] KSPSolve line 356
> [8]PETSC ERROR: [8] MatMult_SchurComplement line 75
> /tmp/petsc-3.4.1/src/ksp/ksp/utils/schurm.c
> [8]PETSC ERROR: [8] MatNullSpaceTest line 408
> /tmp/petsc-3.4.1/src/mat/interface/matnull.c
> [8]PETSC ERROR: [8] solveModel line 133
> "unknowndirectory/"/epi/asclepios2/bkhanal/works/AdLemModel/src/PetscAdLemTaras3D.cxx
> [8]PETSC ERROR: --------------------- Error Message
> [8]PETSC ERROR: Signal received!
> [8]PETSC ERROR:
> [8]PETSC ERROR: Petsc Release Version 3.4.1, Jun, 10, 2013
> [8]PETSC ERROR: See docs/changes/index.html for recent updates.
> [8]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [8]PETSC ERROR: See docs/index.html for manual pages.
> [8]PETSC ERROR:
> [8]PETSC ERROR:
> /epi/asclepios2/bkhanal/works/AdLemModel/build/src/AdLemMain on a
> arch-linux2-cxx-debug named nef002 by bkhanal Fri Aug  9 18:00:22 2013
> [8]PETSC ERROR: Libraries linked from /home/bkhanal/petsc/lib
> [8]PETSC ERROR: Configure run at Mon Jul  1 13:44:30 2013
> [8]PETSC ERROR: Configure options --with-mpi-dir=/opt/openmpi-gcc/current/
> --with-shared-libraries --prefix=/home/bkhanal/petsc
> -download-f-blas-lapack=1 --download-hypre --with-clanguage=cxx
> [8]PETSC ERROR:
> [8]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130809/89de8324/attachment.html>
