[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Tue Aug 6 16:34:58 CDT 2013
On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>> > Now, I implemented two different approaches, each for both 2D and
>>>>>>>> 3D, in
>>>>>>>> > MATLAB. It works for the smaller sizes but I have problems
>>>>>>>> solving it for
>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>> > I use staggered grid with p on cell centers, and components of v
>>>>>>>> on cell
>>>>>>>> > faces. Similar split up of K to cell center and faces to account
>>>>>>>> for the
>>>>>>>> > variable viscosity case)
>>>>>>>> Okay, you're using a staggered-grid finite difference
>>>>>>>> discretization of
>>>>>>>> variable-viscosity Stokes.  This is a common problem and I recommend
>>>>>>>> starting with PCFieldSplit with Schur complement reduction (make
>>>>>>>> that
>>>>>>>> work first, then switch to block preconditioner).  You can use
>>>>>>>> PCLSC or
>>>>>>>> (probably better for you), assemble a preconditioning matrix
>>>>>>>> containing
>>>>>>>> the inverse viscosity in the pressure-pressure block.  This diagonal
>>>>>>>> matrix is a spectrally equivalent (or nearly so, depending on
>>>>>>>> discretization) approximation of the Schur complement.  The velocity
>>>>>>>> block can be solved with algebraic multigrid.  Read the PCFieldSplit
>>>>>>>> docs (follow papers as appropriate) and let us know if you get
>>>>>>>> stuck.
>>>>>>> I was trying to assemble the inverse viscosity diagonal matrix to
>>>>>>> use as the preconditioner for the Schur complement solve step as you
>>>>>>> suggested. I've few questions about the ways to implement this in Petsc:
>>>>>>> A naive approach that I can think of would be to create a vector
>>>>>>> with its components as reciprocal viscosities of the cell centers
>>>>>>> corresponding to the pressure variables, and then create a diagonal matrix
>>>>>>> from this vector. However I'm not sure about:
>>>>>>> How can I make this matrix, (say S_p) compatible to the Petsc
>>>>>>> distribution of the different rows of the main system matrix over different
>>>>>>> processors ? The main matrix was created using the DMDA structure with 4
>>>>>>> dof as explained before.
>>>>>>> The main matrix correspond to the DMDA with 4 dofs but for the S_p
>>>>>>> matrix would correspond to only pressure space. Should the distribution of
>>>>>>> the rows of S_p among different processor not correspond to the
>>>>>>> distribution of the rhs vector, say h' if it is solving for p with Sp = h'
>>>>>>> where S = A11 inv(A00) A01 ?
>>>>>> PETSc distributed vertices, not dofs, so it never breaks blocks. The
>>>>>> P distribution is the same as the entire problem divided by 4.
>>>>> Thanks Matt. So if I create a new DMDA with same grid size but with
>>>>> dof=1 instead of 4, the vertices for this new DMDA will be identically
>>>>> distributed as for the original DMDA ? Or should I inform PETSc by calling
>>>>> a particular function to make these two DMDA have identical distribution of
>>>>> the vertices ?
>>>> Yes.
>>>>>  Even then I think there might be a problem due to the presence of
>>>>> "fictitious pressure vertices". The system matrix (A) contains an identity
>>>>> corresponding to these fictitious pressure nodes, thus when using a
>>>>> -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of size
>>>>> that correspond to only non-fictitious P-nodes. So the preconditioner S_p
>>>>> for the Schur complement outer solve with Sp = h' will also need to
>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>> Don't use detect_saddle, but split it by fields -pc_fieldsplit_0_fields
>>>> 0,1,2 -pc_fieldsplit_1_fields 4
>>> How can I set this split in the code itself without giving it as a
>>> command line option when the system matrix is assembled from the DMDA for
>>> the whole system with 4 dofs. (i.e. *without* using the DMComposite or *
>>> without* using the nested block matrices to assemble different blocks
>>> separately and then combine them together).
>>> I need the split to get access to the fieldsplit_1_ksp in my code,
>>> because not using detect_saddle_point means I cannot use
>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>> This is currently a real problem with the DMDA. In the unstructured case,
>> where we always need specialized spaces, you can
>> use something like
>>     PetscObject  pressure;
>>     MatNullSpace nullSpacePres;
>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure), PETSC_TRUE, 0,
>> NULL, &nullSpacePres);CHKERRQ(ierr);
>>     ierr = PetscObjectCompose(pressure, "nullspace", (PetscObject)
>>     ierr = MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>> and then DMGetSubDM() uses this information to attach the null space to
>> the IS that is created using the information in the PetscSection.
>> If you use a PetscSection to set the data layout over the DMDA, I think
>> this works correctly, but this has not been tested at all and is very
>> new code. Eventually, I think we want all DMs to use this mechanism, but
>> we are still working it out.
> Currently I do not use PetscSection. If this makes a cleaner approach, I'd
> try it too but may a bit later (right now I'd like test my model with a
> quickfix even if it means a little dirty code!)
>> Bottom line: For custom null spaces using the default layout in DMDA, you
>> need to take apart the PCFIELDSPLIT after it has been setup,
>> which is somewhat subtle. You need to call KSPSetUp() and then reach in
>> and get the PC, and the subKSPs. I don't like this at all, but we
>> have not reorganized that code (which could be very simple and inflexible
>> since its very structured).
> So I tried to get this approach working but I could not succeed and
> encountered some errors. Here is a code snippet:
> //mDa is the DMDA that describes the whole grid with all 4 dofs (3
> velocity components and 1 pressure comp.)
> ierr = DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>     ierr =
> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);
>     ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //I've
> the mNullSpaceSystem based on mDa, that contains a null space basis for the
> complete system.
>     ierr =
> KSPSetFromOptions(mKsp);CHKERRQ(ierr);
> //This I expect would register these options I give:-pc_type fieldsplit
> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
> //-pc_fieldsplit_1_fields 3
>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);
>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC that was
> obtained from the options (fieldsplit)
>     ierr =
> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
> //I have created the matrix mPcForSc using a DMDA with identical //size to
> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>     KSP *kspSchur;
>     PetscInt kspSchurPos = 1;
>     ierr =
> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>     ierr =
> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
> //The null space is the one that correspond to only pressure nodes, created
> using the mDaPressure.
>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
Sorry, you need to return to the old DMDA behavior, so you want
  -pc_fieldsplit_dm_splits 0
or
  PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
     Matt
> The errors I get when running with options: -pc_type fieldsplit
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: No support for this operation for this object type!
> [0]PETSC ERROR: Support only implemented for 2d!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named edwards by
> bkhanal Tue Aug  6 17:35:30 2013
> [0]PETSC ERROR: Libraries linked from
> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
> --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
> -with-clanguage=cxx --download-hypre=1
> [0]PETSC ERROR:
> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
> [0]PETSC ERROR: PCSetUp() line 890 in
> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPSetUp() line 278 in
> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: solveModel() line 181 in
> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
> WARNING! There are options you set that were not used!
> WARNING! could be spelling mistake, etc!
> Option left: name:-pc_fieldsplit_1_fields value: 3
>>    Matt
>>>>    Matt
>>>>>>    Matt
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130806/18072079/attachment-0001.html>
