[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Bishesh Khanal bisheshkh at gmail.com
Tue Aug 6 08:06:23 CDT 2013
On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>> > Now, I implemented two different approaches, each for both 2D and
>>>>> 3D, in
>>>>> > MATLAB. It works for the smaller sizes but I have problems solving
>>>>> it for
>>>>> > the problem size I need (250^3 grid size).
>>>>> > I use staggered grid with p on cell centers, and components of v on
>>>>> cell
>>>>> > faces. Similar split up of K to cell center and faces to account for
>>>>> the
>>>>> > variable viscosity case)
>>>>> Okay, you're using a staggered-grid finite difference discretization of
>>>>> variable-viscosity Stokes.  This is a common problem and I recommend
>>>>> starting with PCFieldSplit with Schur complement reduction (make that
>>>>> work first, then switch to block preconditioner).  You can use PCLSC or
>>>>> (probably better for you), assemble a preconditioning matrix containing
>>>>> the inverse viscosity in the pressure-pressure block.  This diagonal
>>>>> matrix is a spectrally equivalent (or nearly so, depending on
>>>>> discretization) approximation of the Schur complement.  The velocity
>>>>> block can be solved with algebraic multigrid.  Read the PCFieldSplit
>>>>> docs (follow papers as appropriate) and let us know if you get stuck.
>>>> I was trying to assemble the inverse viscosity diagonal matrix to use
>>>> as the preconditioner for the Schur complement solve step as you suggested.
>>>> I've few questions about the ways to implement this in Petsc:
>>>> A naive approach that I can think of would be to create a vector with
>>>> its components as reciprocal viscosities of the cell centers corresponding
>>>> to the pressure variables, and then create a diagonal matrix from this
>>>> vector. However I'm not sure about:
>>>> How can I make this matrix, (say S_p) compatible to the Petsc
>>>> distribution of the different rows of the main system matrix over different
>>>> processors ? The main matrix was created using the DMDA structure with 4
>>>> dof as explained before.
>>>> The main matrix correspond to the DMDA with 4 dofs but for the S_p
>>>> matrix would correspond to only pressure space. Should the distribution of
>>>> the rows of S_p among different processor not correspond to the
>>>> distribution of the rhs vector, say h' if it is solving for p with Sp = h'
>>>> where S = A11 inv(A00) A01 ?
>>> PETSc distributed vertices, not dofs, so it never breaks blocks. The P
>>> distribution is the same as the entire problem divided by 4.
>> Thanks Matt. So if I create a new DMDA with same grid size but with dof=1
>> instead of 4, the vertices for this new DMDA will be identically
>> distributed as for the original DMDA ? Or should I inform PETSc by calling
>> a particular function to make these two DMDA have identical distribution of
>> the vertices ?
> Yes.
>> Even then I think there might be a problem due to the presence of
>> "fictitious pressure vertices". The system matrix (A) contains an identity
>> corresponding to these fictitious pressure nodes, thus when using a
>> -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of size
>> that correspond to only non-fictitious P-nodes. So the preconditioner S_p
>> for the Schur complement outer solve with Sp = h' will also need to
>> correspond to only the non-fictitious P-nodes. This means its size does not
>> directly correspond to the DMDA grid defined for the original problem.
>> Could you please suggest an efficient way of assembling this S_p matrix ?
> Don't use detect_saddle, but split it by fields -pc_fieldsplit_0_fields
> 0,1,2 -pc_fieldsplit_1_fields 4
How can I set this split in the code itself without giving it as a command
line option when the system matrix is assembled from the DMDA for the whole
system with 4 dofs. (i.e. *without* using the DMComposite or
*without*using the nested block matrices to assemble different blocks
separately and
then combine them together).
I need the split to get access to the fieldsplit_1_ksp in my code, because
not using detect_saddle_point means I cannot use
-fieldsplit_1_ksp_constant_null_space due to the presence of identity for
the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>    Matt
>>>    Matt
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130806/6dbdfa74/attachment.html>
