[petsc-users] DIVERGED_NONLINEAR_SOLVE error
Fri Aug 2 22:47:47 CDT 2013
"Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
> Thank you, Mat, problem resolved. It's floating point errors. Located
> it after turning on the debugging option.
Run in a debugger and pass the option -fp_trap to PETSc.  It should
break the first place a NaN or denormal is computed.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130802/23fb9fe6/attachment.pgp>
