[petsc-users] DIVERGED_NONLINEAR_SOLVE error
Fri Aug 2 15:33:04 CDT 2013
On Sat, Aug 3, 2013 at 4:22 AM, Jin, Shuangshuang <Shuangshuang.Jin at pnnl.gov
> wrote:
>  Hello,
>      My code solves a linear system AX=B using superlu_dist in PETSc, and
> use some of X’s data to solve a DAE problem. I get a very wild error:
>      When I use less than 8 processors to run the code, it runs just fine
> with correct results. When I use greater than 8 processors, such as 16 or
> 32 processors, I’ll get an error and a lot of generated core.##### files.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR:   !
> [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE,
> increase -ts_max_snes_failures or make negative to attempt recovery!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Development GIT revision:
> a0a914e661bf6402b8edabe0f5a2dad46323f69f  GIT Date: 2013-06-05 14:18:39
> -0500
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: dynSim on a arch-complex named node0055.local by d3m956
> Fri Aug  2 11:56:10 2013
> [0]PETSC ERROR: Libraries linked from
> /pic/projects/ds/petsc-dev.6.06.13/arch-complex/lib
> [0]PETSC ERROR: Configure run at Fri Jul 26 14:32:37 2013
> [0]PETSC ERROR: Configure options --with-scalar-type=complex
> --with-clanguage=C++ PETSC_ARCH=arch-complex --with-fortran-kernels=generic
> --download-superlu_dist --download-mumps --download-scalapack
> --download-parmetis --download-metis --download-elemental --with-debugging=0
> [0]PETSC ERROR:
> [0]PETSC ERROR: TSStep() line 2515 in
> /pic/projects/ds/petsc-dev.6.06.13/src/ts/interface/ts.c
> [0]PETSC ERROR: TSSolve() line 2632 in
> [0]PETSC ERROR: simu() line 566 in "unknowndirectory/"simulation.C
> [0]PETSC ERROR: runSimulation() line 99 in "unknowndirectory/"dynSim.h
> [node0055:32539] *** Process received signal ***
> [node0055:32535] *** Process received signal ***
> [node0055:32535] Signal: Aborted (6)
> [node0055:32535] Signal code:  (24153104)
> [node0055:32534] *** Process received signal ***
> [node0055:32534] Signal: Aborted (6)
> [node0055:32534] Signal code:  (24199552)
> [node0055:32539] Signal: Aborted (6)
> [node0055:32539] Signal code:  (24157648)
> [node0055:32537] *** Process received signal ***
> [node0055:32537] Signal: Aborted (6)
> [node0055:32537] Signal code:  (24546704)
> [node0055:32538] *** Process received signal ***
> The Error Message from PETSc pointed out that “TSStep has failed due to
> DIVERGED_NONLINEAR_SOLVE, increase -ts_max_snes_failures or make negative
> to attempt recovery!”, but I think it’s because the superlu_dist computed
> an all “nan” X as I printed it out.
> However, I don’t understand why using 8 or 16 processors should make such
> a difference.
It sounds like you are computing a NaN somewhere, possibly your residual
evaluation. However, we should
catch this when we evaluate the norm. Please turn on debugging in your
build.
   Matt
> Can anyone give me some help for the trouble shooting?
> Thanks,
> Shuangshuang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130803/075ca571/attachment-0001.html>
