[petsc-users] GAMG speed
Thu Aug 1 15:04:59 CDT 2013
   You can use the option -pc_mg_galerkin  and then MG will compute the coarser matrices with a sparse matrix matrix matrix product so you should not need to change your code to try it out.  You still need to use the KSPSetDM() and -da_refine n to get it working
   If it doesn't work, send us all the output.
   Barry
On Aug 1, 2013, at 2:47 PM, Michele Rosso <mrosso at uci.edu> wrote:
> Barry,
> you are correct, I did not use it. I think I get now where is the problem. Correct me if I am wrong, but for the
> geometric multigrid to work, ksp must be provided with subroutines to compute the matrix and the rhs at any level through
> KSPSetComputeOperators and KSPSetComputeRHS.
> I do not do that, I simply build a rhs vector and a matrix and then I solve the system.
> If you confirm what I just wrote, I will try to modify my code accordingly and get back to you.
> Thank you,
> Michele
> On 08/01/2013 11:48 AM, Barry Smith wrote:
>>   Do you use KSPSetDM(ksp,da);  ?  See src/ksp/ksp/examples/tutorials/ex19.c
>>    Barry
>> On Aug 1, 2013, at 1:35 PM, Michele Rosso
>> <mrosso at uci.edu>
>>  wrote:
>>> Barry,
>>> I am using a finite difference Cartesian uniform grid and DMDA and so far it has not given me any problem.
>>> I am using a ksp solver (not snes). In a previous thread, I was told an odd number of grid points was needed for the geometric multigrid, is that correct?
>>> I tried to run my case with
>>> -pc_type mg -da_refine 4
>>> but it does not seem to use the -da_refine option:
>>> mpiexec   -np 4 ./test  -pc_type mg -da_refine 4  -ksp_view -options_left
>>> KSP Object: 4 MPI processes
>>>  type: cg
>>>  maximum iterations=10000
>>>  tolerances:  relative=1e-08, absolute=1e-50, divergence=10000
>>>  left preconditioning
>>>  using nonzero initial guess
>>>  using UNPRECONDITIONED norm type for convergence test
>>> PC Object: 4 MPI processes
>>>  type: mg
>>>    MG: type is MULTIPLICATIVE, levels=1 cycles=v
>>>      Cycles per PCApply=1
>>>      Not using Galerkin computed coarse grid matrices
>>>  Coarse grid solver -- level -------------------------------
>>>    KSP Object:    (mg_levels_0_)     4 MPI processes
>>>      type: chebyshev
>>>        Chebyshev: eigenvalue estimates:  min = 0.134543, max = 1.47998
>>>        Chebyshev: estimated using:  [0 0.1; 0 1.1]
>>>        KSP Object:        (mg_levels_0_est_)         4 MPI processes
>>>          type: gmres
>>>            GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>>>            GMRES: happy breakdown tolerance 1e-30
>>>          maximum iterations=10, initial guess is zero
>>>          tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>          using NONE norm type for convergence test
>>>        PC Object:        (mg_levels_0_)         4 MPI processes
>>>          type: sor
>>>            SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
>>>          linear system matrix = precond matrix:
>>>          Matrix Object:           4 MPI processes
>>>            type: mpiaij
>>>            rows=262144, cols=262144
>>>            total: nonzeros=1835008, allocated nonzeros=1835008
>>>            total number of mallocs used during MatSetValues calls =0
>>>      maximum iterations=1, initial guess is zero
>>>      type: sor
>>>        type: mpiaij
>>>    type: mpiaij
>>> Solution       =    1.53600013     sec
>>> #PETSc Option Table entries:
>>> -da_refine 4
>>> -ksp_view
>>> -options_left
>>> -pc_type mg
>>> #End of PETSc Option Table entries
>>> There is one unused database option. It is:
>>> Option left: name:-da_refine value: 4
>>> Michele
>>> On 08/01/2013 11:21 AM, Barry Smith wrote:
>>>>    What kind of mesh are you using? Are you using DMDA? If you are using DMDA (and have written your code to use it "correctly") then it should be trivial to run with geometric multigrid and geometric multigrid should be a bit faster.
>>>>    For example on src/snes/examples/tutorials/ex19.c   I run with ./ex19 -pc_type mg -da_refine 4 and it refines the original DMDA 4 times and uses geometric multigrid with 5 levels.
>>>>    Barry
>>>> On Aug 1, 2013, at 1:14 PM, Michele Rosso
>>>> <mrosso at uci.edu>
>>>>  wrote:
>>>>> Hi,
>>>>> I am successfully using PETSc (v3.4.2)  to solve a 3D Poisson's equation with CG + GAMG as I was suggested to do in a previous thread.
>>>>> So far I am using GAMG with the default settings, i.e.
>>>>> -pc_type gamg -pc_gamg_agg_nsmooths 1
>>>>> The speed of the solution is satisfactory, but I would like to know if you have any suggestions to further speed it up, particularly
>>>>> if there is any parameters worth looking into to achieve an even faster solution, for example number of levels and so on.
>>>>> So far I am using Dirichlet's BCs for my test case, but I will soon have periodic conditions: in this case, does GAMG require particular settings?
>>>>> Finally, I did not try geometric multigrid: do you think it is worth a shot?
>>>>> Here are my current settings:
>>>>> I run with
>>>>> -pc_type gamg -pc_gamg_agg_nsmooths 1 -ksp_view -options_left
>>>>> and the output is:
>>>>>   type: cg
>>>>>   type: gamg
>>>>>     MG: type is MULTIPLICATIVE, levels=3 cycles=v
>>>>>       Using Galerkin computed coarse grid matrices
>>>>>     KSP Object:    (mg_coarse_)     4 MPI processes
>>>>>       type: preonly
>>>>>     PC Object:    (mg_coarse_)     4 MPI processes
>>>>>       type: bjacobi
>>>>>         block Jacobi: number of blocks = 4
>>>>>         Local solve info for each block is in the following KSP and PC objects:
>>>>>       [0] number of local blocks = 1, first local block number = 0
>>>>>                 [0] local block number 0
>>>>> KSP Object:          (mg_coarse_sub_)         1 MPI processes
>>>>>           type: preonly
>>>>> KSP Object:        (mg_coarse_sub_)            left preconditioning
>>>>>           PC Object:        (mg_coarse_sub_)       1 MPI processes
>>>>>           type: preonly
>>>>>          1 MPI processes
>>>>>           type: lu
>>>>>           LU: out-of-place factorization
>>>>>           type: lu
>>>>>           tolerance for zero pivot 2.22045e-14
>>>>>             using diagonal shift on blocks to prevent zero pivot
>>>>>             matrix ordering: nd
>>>>>             matrix ordering: nd
>>>>>             factor fill ratio given 5, needed 0
>>>>>               Factored matrix follows:
>>>>>             factor fill ratio given 5, needed 4.13207
>>>>>                   Matrix Object:              Matrix Object:                 1 MPI processes
>>>>>                   type: seqaij
>>>>>                     rows=395, cols=395
>>>>>                     package used to perform factorization: petsc
>>>>>                   total: nonzeros=132379, allocated nonzeros=132379
>>>>>                         not using I-node routines
>>>>>            1 MPI processes
>>>>>                   type: seqaij
>>>>>                     rows=0, cols=0
>>>>>                   total: nonzeros=1, allocated nonzeros=1
>>>>>             type: seqaij
>>>>>           Matrix Object:KSP Object:           1 MPI processes
>>>>>             type: seqaij
>>>>>             rows=0, cols=0
>>>>>             total: nonzeros=0, allocated nonzeros=0
>>>>>           rows=395, cols=395
>>>>>             total: nonzeros=32037, allocated nonzeros=32037
>>>>>           type: preonly
>>>>>           type: lu
>>>>>             matrix ordering: nd
>>>>>                   type: seqaij
>>>>>                   rows=0, cols=0
>>>>>             type: seqaij
>>>>>             rows=0, cols=0
>>>>>           type: preonly
>>>>>           type: lu
>>>>>             matrix ordering: nd
>>>>>                   type: seqaij
>>>>>                   rows=0, cols=0
>>>>>             type: seqaij
>>>>>             rows=0, cols=0
>>>>>       [1] number of local blocks = 1, first local block number = 1
>>>>>         [1] local block number 0
>>>>>       [2] number of local blocks = 1, first local block number = 2
>>>>>         [2] local block number 0
>>>>>       [3] number of local blocks = 1, first local block number = 3
>>>>>         [3] local block number 0
>>>>>         type: mpiaij
>>>>>         rows=395, cols=395
>>>>>           not using I-node (on process 0) routines
>>>>>   Down solver (pre-smoother) on level 1 -------------------------------
>>>>>     KSP Object:    (mg_levels_1_)     4 MPI processes
>>>>>       type: chebyshev
>>>>>         Chebyshev: eigenvalue estimates:  min = 0.0636225, max = 1.33607
>>>>>       maximum iterations=2
>>>>>     PC Object:    (mg_levels_1_)     4 MPI processes
>>>>>       type: jacobi
>>>>>         type: mpiaij
>>>>>         rows=23918, cols=23918
>>>>>         total: nonzeros=818732, allocated nonzeros=818732
>>>>>   Up solver (post-smoother) same as down solver (pre-smoother)
>>>>>   Down solver (pre-smoother) on level 2 -------------------------------
>>>>>     KSP Object:    (mg_levels_2_)     4 MPI processes
>>>>>       type: chebyshev
>>>>>         Chebyshev: eigenvalue estimates:  min = 0.0971369, max = 2.03987
>>>>>     PC Object:    (mg_levels_2_)     4 MPI processes
>>>>>       type: jacobi
>>>>>         type: mpiaij
>>>>>     type: mpiaij
>>>>> -ksp_view
>>>>> -options_left
>>>>> -pc_type gamg
>>>>> There are no unused options.
>>>>> Thank you,
>>>>> Michele
