[petsc-users] GAMG speed
Michele Rosso mrosso at uci.edu
Thu Aug 1 13:35:11 CDT 2013
Barry,
I am using a finite difference Cartesian uniform grid and DMDA and so
far it has not given me any problem.
I am using a ksp solver (not snes). In a previous thread, I was told an
odd number of grid points was needed for the geometric multigrid, is
that correct?
I tried to run my case with
-pc_type mg -da_refine 4
but it does not seem to use the -da_refine option:
mpiexec   -np 4 ./test  -pc_type mg -da_refine 4  -ksp_view -options_left
KSP Object: 4 MPI processes
   type: cg
   maximum iterations=10000
   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000
   left preconditioning
   using nonzero initial guess
   using UNPRECONDITIONED norm type for convergence test
PC Object: 4 MPI processes
   type: mg
     MG: type is MULTIPLICATIVE, levels=1 cycles=v
       Cycles per PCApply=1
       Not using Galerkin computed coarse grid matrices
   Coarse grid solver -- level -------------------------------
     KSP Object:    (mg_levels_0_)     4 MPI processes
       type: chebyshev
         Chebyshev: eigenvalue estimates:  min = 0.134543, max = 1.47998
         Chebyshev: estimated using:  [0 0.1; 0 1.1]
         KSP Object:        (mg_levels_0_est_)         4 MPI processes
           type: gmres
             GMRES: restart=30, using Classical (unmodified)
Gram-Schmidt Orthogonalization with no iterative refinement
             GMRES: happy breakdown tolerance 1e-30
           maximum iterations=10, initial guess is zero
           tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
           using NONE norm type for convergence test
         PC Object:        (mg_levels_0_)         4 MPI processes
           type: sor
             SOR: type = local_symmetric, iterations = 1, local
iterations = 1, omega = 1
           linear system matrix = precond matrix:
           Matrix Object:           4 MPI processes
             type: mpiaij
             rows=262144, cols=262144
             total: nonzeros=1835008, allocated nonzeros=1835008
             total number of mallocs used during MatSetValues calls =0
       maximum iterations=1, initial guess is zero
       type: sor
         SOR: type = local_symmetric, iterations = 1, local iterations =
1, omega = 1
         type: mpiaij
     type: mpiaij
  Solution       =    1.53600013     sec
#PETSc Option Table entries:
-da_refine 4
-ksp_view
-options_left
-pc_type mg
#End of PETSc Option Table entries
There is one unused database option. It is:
Option left: name:-da_refine value: 4
Michele
On 08/01/2013 11:21 AM, Barry Smith wrote:
>     What kind of mesh are you using? Are you using DMDA? If you are using DMDA (and have written your code to use it "correctly") then it should be trivial to run with geometric multigrid and geometric multigrid should be a bit faster.
>     For example on src/snes/examples/tutorials/ex19.c   I run with ./ex19 -pc_type mg -da_refine 4 and it refines the original DMDA 4 times and uses geometric multigrid with 5 levels.
>     Barry
> On Aug 1, 2013, at 1:14 PM, Michele Rosso <mrosso at uci.edu> wrote:
>> Hi,
>> I am successfully using PETSc (v3.4.2)  to solve a 3D Poisson's equation with CG + GAMG as I was suggested to do in a previous thread.
>> So far I am using GAMG with the default settings, i.e.
>> -pc_type gamg -pc_gamg_agg_nsmooths 1
>> The speed of the solution is satisfactory, but I would like to know if you have any suggestions to further speed it up, particularly
>> if there is any parameters worth looking into to achieve an even faster solution, for example number of levels and so on.
>> So far I am using Dirichlet's BCs for my test case, but I will soon have periodic conditions: in this case, does GAMG require particular settings?
>> Finally, I did not try geometric multigrid: do you think it is worth a shot?
>> Here are my current settings:
>> I run with
>> -pc_type gamg -pc_gamg_agg_nsmooths 1 -ksp_view -options_left
>> and the output is:
>>    type: cg
>>    type: gamg
>>      MG: type is MULTIPLICATIVE, levels=3 cycles=v
>>        Using Galerkin computed coarse grid matrices
>>      KSP Object:    (mg_coarse_)     4 MPI processes
>>        type: preonly
>>      PC Object:    (mg_coarse_)     4 MPI processes
>>        type: bjacobi
>>          block Jacobi: number of blocks = 4
>>          Local solve info for each block is in the following KSP and PC objects:
>>        [0] number of local blocks = 1, first local block number = 0
>>                  [0] local block number 0
>> KSP Object:          (mg_coarse_sub_)         1 MPI processes
>>            type: preonly
>> KSP Object:        (mg_coarse_sub_)            left preconditioning
>>            PC Object:        (mg_coarse_sub_)       1 MPI processes
>>            type: preonly
>>           1 MPI processes
>>            type: lu
>>            LU: out-of-place factorization
>>            type: lu
>>            tolerance for zero pivot 2.22045e-14
>>              using diagonal shift on blocks to prevent zero pivot
>>              matrix ordering: nd
>>              matrix ordering: nd
>>              factor fill ratio given 5, needed 0
>>                Factored matrix follows:
>>              factor fill ratio given 5, needed 4.13207
>>                    Matrix Object:              Matrix Object:                 1 MPI processes
>>                    type: seqaij
>>                      rows=395, cols=395
>>                      package used to perform factorization: petsc
>>                    total: nonzeros=132379, allocated nonzeros=132379
>>                          not using I-node routines
>>             1 MPI processes
>>                    type: seqaij
>>                      rows=0, cols=0
>>                    total: nonzeros=1, allocated nonzeros=1
>>              type: seqaij
>>            Matrix Object:KSP Object:           1 MPI processes
>>              type: seqaij
>>              rows=0, cols=0
>>              total: nonzeros=0, allocated nonzeros=0
>>            rows=395, cols=395
>>              total: nonzeros=32037, allocated nonzeros=32037
>>            type: preonly
>>            type: lu
>>              matrix ordering: nd
>>                    type: seqaij
>>                    rows=0, cols=0
>>              type: seqaij
>>              rows=0, cols=0
>>            type: preonly
>>            type: lu
>>              matrix ordering: nd
>>                    type: seqaij
>>                    rows=0, cols=0
>>              type: seqaij
>>              rows=0, cols=0
>>        [1] number of local blocks = 1, first local block number = 1
>>          [1] local block number 0
>>        [2] number of local blocks = 1, first local block number = 2
>>          [2] local block number 0
>>        [3] number of local blocks = 1, first local block number = 3
>>          [3] local block number 0
>>          type: mpiaij
>>          rows=395, cols=395
>>            not using I-node (on process 0) routines
>>    Down solver (pre-smoother) on level 1 -------------------------------
>>      KSP Object:    (mg_levels_1_)     4 MPI processes
>>        type: chebyshev
>>          Chebyshev: eigenvalue estimates:  min = 0.0636225, max = 1.33607
>>        maximum iterations=2
>>      PC Object:    (mg_levels_1_)     4 MPI processes
>>        type: jacobi
>>          type: mpiaij
>>          rows=23918, cols=23918
>>          total: nonzeros=818732, allocated nonzeros=818732
>>    Up solver (post-smoother) same as down solver (pre-smoother)
>>    Down solver (pre-smoother) on level 2 -------------------------------
>>      KSP Object:    (mg_levels_2_)     4 MPI processes
>>        type: chebyshev
>>          Chebyshev: eigenvalue estimates:  min = 0.0971369, max = 2.03987
>>      PC Object:    (mg_levels_2_)     4 MPI processes
>>        type: jacobi
>>          type: mpiaij
>>      type: mpiaij
>> -ksp_view
>> -options_left
>> -pc_type gamg
>> There are no unused options.
>> Thank you,
>> Michele
