[petsc-users] GAMG speed
Michele Rosso mrosso at uci.edu
Thu Aug 1 13:14:05 CDT 2013
I am successfully using PETSc (v3.4.2)  to solve a 3D Poisson's equation
with CG + GAMG as I was suggested to do in a previous thread.
So far I am using GAMG with the default settings, i.e.
-pc_type gamg -pc_gamg_agg_nsmooths 1
The speed of the solution is satisfactory, but I would like to know if
you have any suggestions to further speed it up, particularly
if there is any parameters worth looking into to achieve an even faster
solution, for example number of levels and so on.
So far I am using Dirichlet's BCs for my test case, but I will soon have
periodic conditions: in this case, does GAMG require particular settings?
Finally, I did not try geometric multigrid: do you think it is worth a shot?
Here are my current settings:
I run with
-pc_type gamg -pc_gamg_agg_nsmooths 1 -ksp_view -options_left
and the output is:
KSP Object: 4 MPI processes
   type: cg
   maximum iterations=10000
   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000
   left preconditioning
   using nonzero initial guess
   using UNPRECONDITIONED norm type for convergence test
PC Object: 4 MPI processes
   type: gamg
     MG: type is MULTIPLICATIVE, levels=3 cycles=v
       Cycles per PCApply=1
       Using Galerkin computed coarse grid matrices
   Coarse grid solver -- level -------------------------------
     KSP Object:    (mg_coarse_)     4 MPI processes
       type: preonly
       maximum iterations=1, initial guess is zero
       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
       using NONE norm type for convergence test
     PC Object:    (mg_coarse_)     4 MPI processes
       type: bjacobi
         block Jacobi: number of blocks = 4
         Local solve info for each block is in the following KSP and PC
objects:
       [0] number of local blocks = 1, first local block number = 0
                 [0] local block number 0
KSP Object:          (mg_coarse_sub_)         1 MPI processes
           type: preonly
divergence=10000
KSP Object:        (mg_coarse_sub_)            left preconditioning
           PC Object:        (mg_coarse_sub_)       1 MPI processes
           type: preonly
          1 MPI processes
           type: lu
           LU: out-of-place factorization
           type: lu
           tolerance for zero pivot 2.22045e-14
             using diagonal shift on blocks to prevent zero pivot
             matrix ordering: nd
             matrix ordering: nd
             factor fill ratio given 5, needed 0
               Factored matrix follows:
             factor fill ratio given 5, needed 4.13207
                   Matrix Object:              Matrix
Object:                 1 MPI processes
                   type: seqaij
                     rows=395, cols=395
                     package used to perform factorization: petsc
                   total: nonzeros=132379, allocated nonzeros=132379
                   total number of mallocs used during MatSetValues calls =0
                         not using I-node routines
            1 MPI processes
                   type: seqaij
           linear system matrix = precond matrix:
                     rows=0, cols=0
                   total: nonzeros=1, allocated nonzeros=1
calls =0
   Matrix Object:             1 MPI processes
             type: seqaij
           Matrix Object:KSP Object:           1 MPI processes
             type: seqaij
             rows=0, cols=0
             total: nonzeros=0, allocated nonzeros=0
           rows=395, cols=395
             total: nonzeros=32037, allocated nonzeros=32037
           type: preonly
           type: lu
             matrix ordering: nd
                   type: seqaij
                   rows=0, cols=0
             type: seqaij
             rows=0, cols=0
           type: preonly
           type: lu
             matrix ordering: nd
                   type: seqaij
                   rows=0, cols=0
             type: seqaij
             rows=0, cols=0
       [1] number of local blocks = 1, first local block number = 1
         [1] local block number 0
       [2] number of local blocks = 1, first local block number = 2
         [2] local block number 0
       [3] number of local blocks = 1, first local block number = 3
         [3] local block number 0
       Matrix Object:       4 MPI processes
         type: mpiaij
         rows=395, cols=395
           not using I-node (on process 0) routines
   Down solver (pre-smoother) on level 1 -------------------------------
     KSP Object:    (mg_levels_1_)     4 MPI processes
       type: chebyshev
         Chebyshev: eigenvalue estimates:  min = 0.0636225, max = 1.33607
       maximum iterations=2
     PC Object:    (mg_levels_1_)     4 MPI processes
       type: jacobi
         type: mpiaij
         rows=23918, cols=23918
         total: nonzeros=818732, allocated nonzeros=818732
   Up solver (post-smoother) same as down solver (pre-smoother)
   Down solver (pre-smoother) on level 2 -------------------------------
     KSP Object:    (mg_levels_2_)     4 MPI processes
       type: chebyshev
         Chebyshev: eigenvalue estimates:  min = 0.0971369, max = 2.03987
     PC Object:    (mg_levels_2_)     4 MPI processes
       type: jacobi
         type: mpiaij
         rows=262144, cols=262144
         total: nonzeros=1835008, allocated nonzeros=1835008
     type: mpiaij
#PETSc Option Table entries:
-ksp_view
-options_left
-pc_type gamg
#End of PETSc Option Table entries
There are no unused options.
Thank you,
Michele
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130801/c3f77144/attachment-0001.html>
