[petsc-users] Use kspsolve repeatly
Dave May dave.mayhem23 at gmail.com
Thu Aug 1 09:16:48 CDT 2013
If you want a meaningful answer to your questions, it would be much faster
and simpler if you just sent your source code.
On 1 August 2013 15:29, 丁老师 <ztdepyahoo at 163.com> wrote:
> I use the latest version PETSC, and the matrix has the same nonzero
> pattern during each outer iteration.
> I want to know does the kspsolve allocate memory for PC dring each call.
> 在 2013-08-01 20:46:36,"Matthew Knepley" <knepley at gmail.com> 写道:
> On Thu, Aug 1, 2013 at 12:58 PM, 丁老师 <ztdepyahoo at 163.com> wrote:
>> I need to use the kspsolve(A,b,x) repeatly in my code in the following
>> style.
>> but i have noticed from the system load monitor that during the code
>> running, it allocate new memeory every step.
>> I use the default setting for the PC.
>> Could you please told me how to resolve this problem.
> 1) There is no enough here to give us an idea what you are doing
> 2) Are you using the latest release? If so, it prevents you from adding
> new nonzreos to the matrix, which is my first guess.
>    Matt
>> for (int i=0;i<maxit;i++)
>> MatsetValues(    )....
>> kspsolve(A,b,x)
>> < span title="neteasefooter">
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130801/190abbd7/attachment.html>
