[petsc-users] a config problem
Kainan Wang kennan.wong at gmail.com
Thu Apr 25 23:11:54 CDT 2013
Hello,
  I tried to install petsc 3.3-p6 on a cluster with gcc/4.4.3 or
gcc/4.4.5.I manually load the module of gotoblas (v1.30) and specify
in the petsc
configure command as
./configure --with-blas-lapack-dir=/opt/apps/gotoblas/1.30
and I got the following error:
You set a value for --with-blas-lapack-dir=<dir>, but
/opt/apps/gotoblas/1.30 cannot be used
However, if I change the compiler to intel (v11.1) the same configure can
work and installation is smooth.
Best,
Kainan
Kainan Wang
www.math.tamu.edu/~kwang
Texas A&M University
Wish U happiness EveRyday !!!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130425/de632e4f/attachment.html>
