[petsc-users] question on PETSc option '-snes_mf_operator'
Dmitry Karpeev karpeev at mcs.anl.gov
Thu Sep 27 13:30:41 CDT 2012
On Thu, Sep 27, 2012 at 1:22 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Sep 27, 2012 at 2:13 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
>> Thank you Matt.
>> I've noticed that there is a different option '-snes_fd', and I guess
>> PETSc will use finite difference method for both Jacobian (action) and
>> Preconditioner?
> -snes_fd uses FD to create the entire dense Jacobian. This is just for
> testing. -snes_mf uses FD to evaluate the action
> of the Jacobian on a vector.
>> By the way, do you have any comments on my another question?
>> One more question, if I pass '-snes' to PETSc, since it is direct
>> Newton's method, I assume it will explicitly construct a Jacobian. Does
>> this Jacobian come from user provided Jacobian or from the finite
>> difference Jacobian?
>  Ling,
-snes isn't really a PETSc option.  I think Moose recommends using it for
"completeness" and in contrast to -snes_mf or -snes_mf_operator,
so that users aren't confused about what's being used to compute the
Jacobian when both -snes_mf and -snes_mf_operator are omitted.
I'll copy this to to moose-users, in case it is useful there.
-snes_mf will implement the action of the Jacobian approximately by
differencing the residual. No preconditioner matrix will be used.
-snes_mf_operator is like -snes_mf, except the user-provided preconditioner
-snes_fd will *assemble* both the Jacobian and the preconditioner matrix
using the same residual-differencing algorithm as in -snes_mf.
Dmitry.
> The option -snes does not do anything. I am not sure what you are asking
> here. If you mean,
> what is used when you pass -snes_mf or -snes_mf_operator, it is FD, not
> the user provided
> Jacobian routine if it exists.
>    Matt
>> Best,
>> Ling
>> On Thu, Sep 27, 2012 at 12:09 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Thu, Sep 27, 2012 at 2:01 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
>>>> Dear all,
>>>> I have a question on the PETSc option '-snes_mf_operator'.
>>>> I am reading the    <PETSc Users Manual Revision 3.3>. On page 100, 2nd
>>>> paragraph, it says:
>>>> "However, it allows us to check the analytic Jacobian we construct in
>>>> FormJacobian() by passing the -snes_mf_operator flag. This causes PETSc to
>>>> approximate the Jacobian using finite differencing of the function
>>>> evaluation (discussed in section 5.6), and the analytic Jacobian
>>>> becomes merely the preconditioner."
>>>> I wonder, if the '-snes_mf_operator' option is used, the Jacobian will
>>>> always be calculated from the finite difference method while
>>>> ignore whatever has been provided from user.
>>> Yes, yhe action will be FD, but it will take the user provided operator
>>> to form a preconditioner from.
>>>    Matt
>>>> Thanks,
>>>> Ling
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120927/6cc80553/attachment.html>
