[petsc-users] snes ex62.c header file
Thu Sep 27 06:49:14 CDT 2012
On Thu, Sep 27, 2012 at 7:46 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> If I understand correctly, the first step to running SNES ex62.c is to
> create the header file, however:
> $ $PETSC_DIR/bin/pythonscripts/PetscGenerateFEMQuadrature.py dim order dim
> 1 laplacian dim order 1 1 gradient
> $PETSC_DIR/src/snes/examples/tutorials/ex62.h
> Traceback (most recent call last):
>   File
> "/home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p3/bin/pythonscripts/PetscGenerateFEMQuadrature.py",
> line 12, in <module>
>     from FIAT.reference_element import default_simplex
> ImportError: No module named FIAT.reference_element
In order to run the tests, you must configure with
  # For finite element support
  --download-scientificpython --download-fiat --download-generator
  # For unstructured mesh generation and partitioning
  --download-triangle --with-ctetgen --download-chaco
and you can run the tests using the new Python build system
  python2.7 ./config/builder2.py check src/snes/examples/tutorials/ex62.c
or do it manually as you are doing.
   Matt
dr. ir. Christiaan Klaij
> CFD Researcher
> Research & Development
> E mailto:C.Klaij at marin.nl
> T +31 317 49 33 44
> MARIN
> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120927/201f0598/attachment.html>
