[petsc-users] Error when using PCDestroy
Thu Sep 27 06:45:37 CDT 2012
On Thu, Sep 27, 2012 at 4:31 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>  On 26/9/2012 11:04 PM, Barry Smith wrote:
> On Sep 26, 2012, at 4:03 PM, TAY wee-beng <zonexo at gmail.com> <zonexo at gmail.com> wrote:
>  Hi,
> When I run a code in debug mode with -log_summary, there is no problem. However, in optimized mode, I encounter error "Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range"
> It happens at :
> call PCDestroy(pc_semi_x,ierr)
> Is there any reason why it works well in debug mode but not in optimized mode?
>     Memory corruption. Run first debug then optimized version under valgrind.
>  I ran valgrind in debug mode and found:
> *==4977== Invalid read of size 4**
> **==4977==    at 0x5D4A8E7: PetscCheckPointer (petscimpl.h:219)**
> **==4977==    by 0x5D4997A: PCDestroy (precon.c:112)**
> **==4977==    by 0x5B96AB9: pcdestroy_ (preconf.c:162)**
> **==4977==    by 0x4A02E8: global_data_mp_de_ini_var_ (global.F90:1362)**
> **==4977==    by 0xD2D2E0: MAIN__ (ibm3d_high_Re.F90:1140)**
> **==4977==    by 0x4335CB: main (in /home/wtay/Results/10/a.out)**
> **==4977==  Address 0xba21430 is 1,872 bytes inside a block of size 2,452
> free'd**
> **==4977==    at 0x4C263CF: free (vg_replace_malloc.c:427)**
> **==4977==    by 0x4FC2B84: PetscFreeAlign (mal.c:75)**
> **==4977==    by 0x4FC5BB1: PetscTrFreeDefault (mtr.c:322)**
> **==4977==    by 0x5D4A059: PCDestroy (precon.c:121)**
> **==4977==    by 0x5E30990: KSPDestroy (itfunc.c:786)**
> **==4977==    by 0x5B98FCB: kspdestroy_ (itfuncf.c:236)**
> **==4977==    by 0x4A020D: global_data_mp_de_ini_var_ (global.F90:1360)**
> **[0]PETSC ERROR: --------------------- Error Message
> **[0]PETSC ERROR: Invalid argument!**
> **[0]PETSC ERROR: Wrong type of object: Parameter # 1!**
> **[0]PETSC ERROR:
> **[0]PETSC ERROR: Petsc Development HG revision:
> 3675b37c376d9b5704273c07c9eacb10845dbbe9  HG Date: Thu Jul 05 23:16:22 2012
> -0500**
> **[0]PETSC ERROR: See docs/changes/index.html for recent updates.**
> **[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.**
> **[0]PETSC ERROR: See docs/index.html for manual pages.**
> **[0]PETSC ERROR:
> **[0]PETSC ERROR: ./a.out on a petsc-3.3 named hpc12 by wtay Thu Sep 27
> 10:04:56 2012**
> **[0]PETSC ERROR: Libraries linked from
> /home/wtay/Lib/petsc-3.3-dev_shared_debug/lib**
> **[0]PETSC ERROR: Configure run at Fri Jul  6 16:18:04 2012**
> **[0]PETSC ERROR: Configure options --with-mpi-dir=/opt/openmpi-1.5.3/
> --with-blas-lapack-dir=/opt/intelcpro-11.1.059/mkl/lib/em64t/
> --with-debugging=1 --download-hypre=1
> --prefix=/home/wtay/Lib/petsc-3.3-dev_shared_debug --known-mpi-shared=1
> --with-shared-libraries**
> **[0]PETSC ERROR:
> **[0]PETSC ERROR: PCDestroy() line 112 in
> /home/wtay/Codes/petsc-dev/src/ksp/pc/interface/precon.c**
> Does it mean that the pc_semi_x has already been freed when I call
> KSPDestroy(ksp_semi_x,ierr) earlier on? It's strange that I do not get this
> error if I just run the code in debug mode without valgrind.
Yes you do not separately destroy the KSP and PC.
   Matt
> Yours sincerely,
> TAY wee-beng
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120927/2a841be8/attachment-0001.html>
