[petsc-users] ksppreonly question
Fri Sep 21 17:50:34 CDT 2012
  Ok, so it is using a FULL LU factorization of A1.  Hence with what I outlined below you would use -ksp_type preonly -pc_type lu
   If you reorganize the iteration then in exact arithmetic it is what we in PETSc call Richardson's method with preconditioner defined from M (the LU of M) so I was wrong; you can do as Jed suggested
KSPSetOperations(ksp, A,A1,….) and run with -ksp_type richardson to mimic the old algorithm. Simply switch to -ksp_type gmres and you have the late 80's version of the algorithm
   Barry
On Sep 21, 2012, at 5:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 21, 2012, at 5:26 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Fri, Sep 21, 2012 at 5:21 PM, Shao-Ching Huang <huangsc at gmail.com> wrote:
>> In this particular finite volume discretization, the flux normal to a
>> face involves the cell-center values on each side of the face (1),
>> plus values from neighboring nodes (2) [due to non-orthogonal mesh
>> cell shape]. The A1 part include coefficients from (1). A2 includes
>> those in (2).
>> 1. Call KSPSetOperators(ksp,A,A1,flag)
>> You can make A in the above a MATSHELL that applies A1 + A2 matrix-free (or just the A2 part).
>> 2. Use any Krylov method. The specific method -ksp_type richardson will do the defect-correction version of what you have written, but a real Krylov method will almost certainly perform much better. Note that A1^{-1} will be applied using whatever method you choose (via -pc_type). A V-cycle of algebraic multigrid should work very well.
>   To mimic the exact old algorithm for comparison purposes
>  I don't think you can get this directly with KSP you'll need to manage the "outer" iteration yourself, something like
>     for (n=0; n<Nmax ….
>          MatMultAdd(A2,x,b,c) where A2 is the opposite sign of your A2 above
>          KSPSolve(ksp,c,x);
> Your KSP solve could use any solver you like (what does the old code use?, you should use the same thing for comparison purposes)
> Of course, this is only for comparison purposes, no one in 2012 except in a legacy code would use such a primitive nested solver.
>  Barry
