[petsc-users] using '-snes_type test' to test my coded Jacobian
Wed Sep 19 15:37:28 CDT 2012
Upgrade to petsc-3.3
On Wed, Sep 19, 2012 at 3:34 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
> Framework Information:
> SVN Revision:            13656
> PETSc Version:           3.1.0
> Current Time:            Wed Sep 19 14:17:01 2012
> Executable Timestamp:    Wed Sep 19 14:14:46 2012
> I believe my version is 3.1.0.
> Ling
> On Wed, Sep 19, 2012 at 2:31 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Are you using an older version of PETSc?
>> On Wed, Sep 19, 2012 at 2:56 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
>>> No Jacobian output showed when I did this,
>>> ./my-project-opt -i input.i -snes_compare_explicit
>>> Any suggestion?
>>> Ling
>>> On Wed, Sep 19, 2012 at 1:12 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
>>>> On Wed, Sep 19, 2012 at 1:03 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>> On Wed, Sep 19, 2012 at 1:54 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
>>>>>> Dear Matt,
>>>>>> Thanks again for helping me on the '-snes_type test' issue. This is a
>>>>>> great tool which helped us make really good progress recently.
>>>>>> I have couple of more questions about the '-snes_type test'. From my
>>>>>> understanding, this finite difference method is based on a tiny
>>>>>> perturbation from a base solution vector. This base solution vector, from
>>>>>> my observation, seems to be [1, 1, 1, ....].  However, this solution vector
>>>>>> sometimes is very far from real physics, which causes issue, for example a
>>>>>> dependent pressure variable get negative value.
>>>>>> I wonder,
>>>>>> 1), if this [1, 1, 1, ...] base solution vector is always used during
>>>>>> the real simulation, for example when using the finite difference
>>>>>> preconditioner. Or this base solution vector will change as solution gets
>>>>>> updated?
>>>>> -snes_type test tries three different states: your user-defined state,
>>>>> then constant -1.0, then constant +1.0. It does not solve the system so you
>>>>> can't continue stepping, but you can just look at the result from the first
>>>>> test.
>>>> Ahhh....... I see, that's why I always see three comparisons there. The
>>>> first one should help me better when dealing with real simulation case.
>>>>>> 2), is it possible to choose a different base solution, for example,
>>>>>> [1000, 1000, 1000, 10, 10, 10, 1.e9, 1.e9, 1.e9] as the base solution
>>>>>> vector when using the '-snes_type test'  option to test my hand-coded
>>>>>> Jacobian.
>>>>> You can also use -snes_compare_explicit which shows the matrix (only
>>>>> linearized around your actual state) and actually solves the system. There
>>>>> is also -snes_compare_explicit_draw. If you know that you preallocated
>>>>> correctly, -snes_compare_coloring is better. Details here.
>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESComputeJacobian.html
>>>> This is something new to me. I'd take a look at the link. Thanks a lot,
>>>> Jed.
>>>> Best,
>>>> Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120919/c6613970/attachment-0001.html>
