[petsc-users] Cannot convert error
Eduardo erocha.ssa at gmail.com
Wed Sep 19 08:12:34 CDT 2012
Well, that is true if you develop the whole code yourself. But what if
you have to use some third-party code that uses an older version of
Petsc?? The problem is that my own code uses Petsc and some library
that also uses Petsc (but an older version). You cannot rule out this
possibility.
Eduardo
On Wed, Sep 19, 2012 at 9:55 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 19, 2012, at 6:49 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Wed, Sep 19, 2012 at 6:25 AM, Eduardo <erocha.ssa at gmail.com> wrote:
>> Is there a macro I can get the Petsc release? I'd like to link my code
>> with libraries that are using a old version of Petsc. However, in the
>> future these libraries may change to a newer version. So I want to
>> write my code with ifdefs so that I can change from one version to the
>> other easily.
>> See include/petscversion.h
>> Starting in petsc-3.3, there are convenience macros PETSC_VERSION_LT() and PETSC_VERSION_LE(). You can add to your headers:
>> #if !defined(PETSC_VERSION_LT)
>> #  define PETSC_VERSION_LT (... copy from petscversion.h)
>> #endif
>> then in your source,
>> #if PETSC_VERSION_LE(3,3,0) /* last version doing it the old way */
>>   the old way
>> #else
>>   the new way
>> #endif
>   Since PETSc is user installable we don't recommend taking this route. We recommend just always developing and user your code with the latest PETSc release.
>     Barry
