[petsc-users] Recommended solver and preconditioner to solve Poisson eqn on win7
TAY wee-beng zonexo at gmail.com
Sat Sep 15 02:16:40 CDT 2012
On 14/9/2012 4:38 PM, Mark F. Adams wrote:
> On Sep 14, 2012, at 8:47 AM, Jed Brown <jedbrown at mcs.anl.gov
> <mailto:jedbrown at mcs.anl.gov>> wrote:
>> On Fri, Sep 14, 2012 at 3:47 AM, TAY wee-beng <zonexo at gmail.com
>> <mailto:zonexo at gmail.com>> wrote:
>>     Hi,
>>     I need to solve the Poisson eqn on my win7 machine. I'm currently
>>     using BCGS without preconditioner. I can't use HYPRE since I'm
>>     using Fortran and win7. It's rather slow.
>>     Is there a recommended solver and preconditioner to solve the
>>     Poisson eqn to get me started?
>> What discretization?
>> Run with -pc_type gamg to start.
> and
> -pc_gamg_agg_nsmooths 1
I am using non-uniform Cartesian grid to solve. What do you mean by the
discretization? I 'm using finite volume method to obtain a system of
linear eqns.
I tried both -pc_type gamg and -pc_gamg_agg_nsmooths 1 but the solver
breaks down. The error msg is:
/[0]PETSC ERROR:
//[0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
Exception,probably divide by zero//
//[0]PETSC ERROR: Try option -start_in_debugger or
-on_error_attach_debugger//
//[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors//
//[0]PETSC ERROR: likely location of problem given in stack below//
//[0]PETSC ERROR: ---------------------  Stack Frames
//[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
available,//
//[0]PETSC ERROR:       INSTEAD the line number of the start of the
function//
//[0]PETSC ERROR:       is given.//
//[0]PETSC ERROR: [0] KSPComputeExtremeSingularValues_GMRES line 24
src/ksp/ksp/impls/gmres/C:\wtay\DOWNLO~1\Codes\PETSC-~1\src\ksp\ksp\impls\gmres\gmreig.c//
//[0]PETSC ERROR: [0] KSPComputeExtremeSingularValues line 40
src/ksp/ksp/interface/C:\wtay\DOWNLO~1\Codes\PETSC-~1\src\ksp\ksp\INTERF~1\itfunc.c//
//[0]PETSC ERROR: [0] PCGAMGOptprol_AGG line 1294
src/ksp/pc/impls/gamg/C:\wtay\DOWNLO~1\Codes\PETSC-~1\src\ksp\pc\impls\gamg\agg.c//
//[0]PETSC ERROR: [0] PCSetUp_GAMG line 559
src/ksp/pc/impls/gamg/C:\wtay\DOWNLO~1\Codes\PETSC-~1\src\ksp\pc\impls\gamg\gamg.c//
//[0]PETSC ERROR: [0] PCSetUp line 810
src/ksp/pc/interface/C:\wtay\DOWNLO~1\Codes\PETSC-~1\src\ksp\pc\INTERF~1\precon.c//
//[0]PETSC ERROR: [0] KSPSetUp line 182
//[0]PETSC ERROR: [0] KSPSolve line 351
//[0]PETSC ERROR: --------------------- Error Message
//[0]PETSC ERROR: Signal received!//
//[0]PETSC ERROR:
//[0]PETSC ERROR: Petsc Development HG revision:
d560f272ff1b6e7f4e28667ab8b55f0c7408979e  HG Date: Wed Jul 25 14:42:03
2012 -0500//
//[0]PETSC ERROR: See docs/changes/index.html for recent updates.//
//[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.//
//[0]PETSC ERROR: See docs/index.html for manual pages.//
//[0]PETSC ERROR:
//[0]PETSC ERROR:
C:\Obj_tmp\ibm3d_high_Re_staggered_AB2\Debug\ibm3d_high_Re_staggered_AB2.exe
on a petsc-3.3 named USER-PC by User Sat Sep 15 09:12:58 2012//
//[0]PETSC ERROR: Libraries linked from
/cygdrive/d/wtay/Lib/petsc-3.3-dev_win32_vs2008/lib//
//[0]PETSC ERROR: Configure run at Thu Jul 26 11:01:27 2012//
//[0]PETSC ERROR: Configure options --with-cc="win32fe cl"
--with-fc="win32fe ifort" --with-cxx="win32fe cl"
--with-mpi-dir=/cygdrive/c/MPICH2/ --download-f-blas-lapack=1
--prefix=/cygdrive/d/wtay/Lib/petsc-3.3-dev_win32_vs2008
--with-debugging=1 --useThreads=0//
//[0]PETSC ERROR:
//[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file//
//application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0/
Btw, I've used both GMRES and BCGS as the ksp. What other options can I try?
Thanks
> (I should make this the default)
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120915/d1e9dea9/attachment.html>
