[petsc-users] Recommended solver and preconditioner to solve Poisson eqn on win7
Fri Sep 14 18:17:25 CDT 2012
On Fri, Sep 14, 2012 at 6:14 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Also, add -pc_gamg_agg_nsmooths 1 as Mark suggested. It will reduce the
> iteration count significantly at the expense of somewhat higher setup cost.
Unless I am reading this wrong, you have a bizarre coarse grid solver. It
should be redundant LU but instead
you have GMRES/BJacobi?
   Matt
> On Fri, Sep 14, 2012 at 6:11 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> *      #                          WARNING!!!                    #*
>> *      #   This code was compiled with a debugging option,      #*
>> *      #   To get timing results run ./configure                #*
>> *      #   using --with-debugging=no, the performance will      #*
>> *      #   be generally two or three times faster.              #*
>> On Fri, Sep 14, 2012 at 6:08 PM, Zhenglun (Alan) Wei <
>> zhenglun.wei at gmail.com> wrote:
>>>  I'm sorry about that. I attached the output files here with '
>>> -ksp_monitor -ksp_view -log_summary'. They are named after the grid size
>>> and pc-type.
>>> cheers,
>>> Alan
>>> On 9/14/2012 5:51 PM, Jed Brown wrote:
>>> On Fri, Sep 14, 2012 at 5:49 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Fri, Sep 14, 2012 at 5:40 PM, Zhenglun (Alan) Wei <
>>>>>  Dear folks,
>>>>>     I did some test with -pc_type gamg with
>>>>> /src/ksp/ksp/example/tutorial/ex45.c. It is not as good as default -pc_type
>>>>> when my mesh (Cartisian) is 100*50*50; while it is a little bit better than
>>>>> the default one when the mesh is 200*100*100. Therefore, I guess this type
>>>>> of pc is good for larger problem. Is that ture? or is there any rule of
>>>>> thumb for this type of preconditioner? BTW, I tested it with 8 processes.
>>>>  When asking questions about convergence, always always ALWAYS send
>>>> the output of -ksp_monitor -ksp_view. If
>>>> you don't, we are just guessing blindly.
>>>  And -log_summary because this is about performance.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120914/87bea290/attachment.html>
