[petsc-users] Recommended solver and preconditioner to solve Poisson eqn on win7
Fri Sep 14 18:11:56 CDT 2012
*      #                          WARNING!!!                    #*
*      #   This code was compiled with a debugging option,      #*
*      #   To get timing results run ./configure                #*
*      #   using --with-debugging=no, the performance will      #*
*      #   be generally two or three times faster.              #*
On Fri, Sep 14, 2012 at 6:08 PM, Zhenglun (Alan) Wei <zhenglun.wei at gmail.com
> wrote:
>  I'm sorry about that. I attached the output files here with '
> -ksp_monitor -ksp_view -log_summary'. They are named after the grid size
> and pc-type.
> cheers,
> Alan
> On 9/14/2012 5:51 PM, Jed Brown wrote:
> On Fri, Sep 14, 2012 at 5:49 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Sep 14, 2012 at 5:40 PM, Zhenglun (Alan) Wei <
>> zhenglun.wei at gmail.com> wrote:
>>>  Dear folks,
>>>     I did some test with -pc_type gamg with
>>> /src/ksp/ksp/example/tutorial/ex45.c. It is not as good as default -pc_type
>>> when my mesh (Cartisian) is 100*50*50; while it is a little bit better than
>>> the default one when the mesh is 200*100*100. Therefore, I guess this type
>>> of pc is good for larger problem. Is that ture? or is there any rule of
>>> thumb for this type of preconditioner? BTW, I tested it with 8 processes.
>>  When asking questions about convergence, always always ALWAYS send the
>> output of -ksp_monitor -ksp_view. If
>> you don't, we are just guessing blindly.
>  And -log_summary because this is about performance.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120914/a39f143d/attachment.html>
