[petsc-users] petsc-users Digest, Vol 45, Issue 33
coco at dmi.unict.it coco at dmi.unict.it
Fri Sep 14 10:18:14 CDT 2012
Thank you! I solved my problems using your suggestion and I found the
bug in my code.
Best regards,
Armando
> Message: 5
> Date: Tue, 11 Sep 2012 18:43:50 -0500
> From: Barry Smith <bsmith at mcs.anl.gov>
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] interpolation function in multigrid
> Message-ID: <E5801048-2299-46A0-AF78-CD1B811D1BC2 at mcs.anl.gov>
> Content-Type: text/plain; charset=iso-8859-1
> On Sep 11, 2012, at 5:11 PM, coco at dmi.unict.it wrote:
>> Dear all,
>> I am using the multigrid as preconditioner, and I got in a trouble
>> with the interpolation function. In practice, I defined a user
>> interpolation function:
>> PetscErrorCode UserMultAddInterpolation(Mat mat,Vec x,Vec v2, Vec y);
>> and I noticed that the vectors v2 and y are zero in input, while I
>> am expected that they are the solution computed in the smooth down
>> process at the same level. In detail, given the following source
>> code of the petsc file mg.c :
>> ierr =
>> KSPSolve(mglevels->smoothd,mglevels->b,mglevels->x);CHKERRQ(ierr);
>> /* pre-smooth */
>>    while (cycles--) {
>>      ierr = PCMGMCycle_Private(pc,mglevelsin-1,reason);CHKERRQ(ierr);
>>    ierr =
>> MatInterpolateAdd(mglevels->interpolate,mgc->x,mglevels->x,mglevels->x);CHKERRQ(ierr);
>> I observed that mglevels->x is a vector which contains the correct
>> values after the KSPSolve calling for the pre-smooth step, but it
>> is a zero vector when given in input to the MatInterpolateAdd
>> routine.
>> I would like to debug the mg.c code, for instance accessing the
>> single values of the vector mglevels->x and figuring out where they
>> are zeroed out between the KSPSolve and MatInterpolateAdd callings.
>> Would you have some suggestion for this debugging?
>    You can call VecView(mglevels->x,0) directly in the debugger (for
> a small problem) I would start by simply calling it right after the
> KSPSolve() then right before the MatInterpolateAdd() if the second
> is zero but the first ok then run with two levels and break in the
> inner PCMGMCycle_Private() and print the same thing there (remember
> the value of mglevels changes.
>    Good luck,
>    Barry
>> Thank you for the collaboration.
>> Best regards,
>> Armando
> petsc-users mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> End of petsc-users Digest, Vol 45, Issue 33
