[petsc-users] interpolation function in multigrid
coco at dmi.unict.it coco at dmi.unict.it
Tue Sep 11 17:11:27 CDT 2012
Dear all,
I am using the multigrid as preconditioner, and I got in a trouble
with the interpolation function. In practice, I defined a user
interpolation function:
PetscErrorCode UserMultAddInterpolation(Mat mat,Vec x,Vec v2, Vec y);
and I noticed that the vectors v2 and y are zero in input, while I am
expected that they are the solution computed in the smooth down
process at the same level. In detail, given the following source code
of the petsc file mg.c :
ierr =
KSPSolve(mglevels->smoothd,mglevels->b,mglevels->x);CHKERRQ(ierr);  /*
pre-smooth */
     while (cycles--) {
       ierr = PCMGMCycle_Private(pc,mglevelsin-1,reason);CHKERRQ(ierr);
     ierr =
MatInterpolateAdd(mglevels->interpolate,mgc->x,mglevels->x,mglevels->x);CHKERRQ(ierr);
I observed that mglevels->x is a vector which contains the correct
values after the KSPSolve calling for the pre-smooth step, but it is a
zero vector when given in input to the MatInterpolateAdd routine.
I would like to debug the mg.c code, for instance accessing the single
values of the vector mglevels->x and figuring out where they are
zeroed out between the KSPSolve and MatInterpolateAdd callings. Would
you have some suggestion for this debugging?
Thank you for the collaboration.
Best regards,
Armando
