[petsc-users] PetscSFReduceBegin does not work correctly on openmpi-1.4.3 with 64 integers
fdkong fd.kong at foxmail.com
Mon Sep 10 22:47:33 CDT 2012
>> Hi all,
>> The function PetscSFReduceBegin runs well on MPICH, but does not work
>> on  openmpi-1.4.3, with 64 integers. Anyone knows why?
>1) What error are you seeing? There are no errors in the build.
Yes, There are no errors in the build and configure. But when I ran my code involved the function PetscSFReduceBegin on supercomputer, I got the error below:
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ./linearElasticity on a arch-linu named node0353 by fako9399 Mon Sep 10 16:50:42 2012
[0]PETSC ERROR: Libraries linked from /projects/fako9399/petsc-3.3-p3/arch-linux264-cxx-opt/lib
[0]PETSC ERROR: Configure run at Mon Sep 10 13:58:46 2012
[0]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=8 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-clanguage=cxx --with-shared-libraries=1 --with-dynamic-loading=1 --download-f-blas-lapack=1 --with-batch=1 --known-mpi-shared-libraries=0 --with-mpi-shared=1 --download-parmetis=1 --download-metis=1 --with-64-bit-indices=1 --with-netcdf-dir=/projects/fako9399/petsc-3.3-p3/externalpackage/netcdf-4.1.3install --download-exodusii=1 --with-debugging=no --download-ptscotch=1
[0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 0 with PID 1517 on
node node0353 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
I had done some debugs, and then found the error came from the function PetscSFReduceBegin.
>2) Please do not send logs to petsc-users, send them to
>petsc-maint at mcs.anl.gov
Ok, Thanks.
>  Matt
>> Maybe this link could help us guess why?
>> http://www.open-mpi.org/community/lists/devel/2005/11/0517.php
>> I attached the configure.log and make.log files.
>> Fande Kong
>> ShenZhen Institutes of Advanced Technology
>> Chinese Academy of Sciences
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120911/2e1bf019/attachment-0001.html>
