[petsc-users] MPI Derived Data Type and Non Blocking MPI Send/Recieve
Zhenglun (Alan) Wei zhenglun.wei at gmail.com
Thu Sep 6 17:38:09 CDT 2012
Dear All,
      I hope you're having a nice day.
      I met a memory problem for MPI data communication. I guess here is
a good place to ask this question since you guys are experts and may
experienced the same problem before.
      I used the MPI derived data type (MPI_Type_contiguous,
MPI_Type_vector and MPI_Type_indexed) to communicate data for a
simulation of 3D problem. The communication is fine, as I checked every
single data it sent and received. However, the problem is that the
memory keeps increasing while communication. Therefore, I tested each of
these three types. MPI_Type_contiguous does not have any problem; while
MPI_Type_vector and MPI_Type_indexed have problem of memory
accumulation. I tried to use MPI_Type_free, but it does not help. Have
anyone experienced this problem before?
      Would this be related to the non-blocking MPI communication
(MPI_Isend and MPI_Irecv). I have to use this non-blocking communication
since the blocking communication is extremely slow when it has a lot of
data involved in the communication.
      Is there any alternative way in PETSc that could do the similar
work of MPI derived types?
thanks,
Alan
