[petsc-users] Improve in speed/efficiency from partitioning in 1 direction to 3 directions
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Tue Sep 4 04:11:00 CDT 2012
This doesn't strike me as a particularly large problem.  I'm not sure
it's worth doing unless you are going to be looking at more unknowns
in the future.
A
On Tue, Sep 4, 2012 at 10:08 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> My Fortran CFD code is currently partitioned in the z direction. Total grid
> size is around is 153x248x620. Hence depending on the no. of procs, the z
> direction 620 is partitioned. The grid size changes but the ratio is around
> there.
> Parititoning in 3 directions was initially too complex for me. However, it
> seems to be much simplified with the use of DM. However, there's still a lot
> of work to be done to make it working.
> I'm wondering how much improvement in speed/efficiency will I get, if I
> partition from 1 direction to 3 directions. Is it worth the effort?
> Yours sincerely,
> TAY wee-beng
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
