[petsc-users] Convert mat SEQAIJ to MPIAIJ
Thomas Witkowski thomas.witkowski at tu-dresden.de
Tue Sep 4 02:53:53 CDT 2012
Am 03.09.2012 18:02, schrieb Hong Zhang:
> Thomas :
>     In my FETI-DP code, each rank creates a SEQAIJ matrix that
>     represents the discretization of the interior domain. Just for
>     debugging, I would like to join these sequential matrices to one
>     global MPIAIJ matrix. This matrix has no off diagonal nnzs and
>     should be stored corresponding to the ranks unknowns, thus, first
>     all rows of the first rank and so on. What's the most efficient
>     way to do this? Is it possible to create this parallel matrix just
>     as a view of the sequential ones, so without copying the data?
>     Thanks for any advise.
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateMPIAIJConcatenateSeqAIJ.html
> Note: entries in seqaij matrices are copied into a mpiaij matrix without
> inter-processor communication. Use petsc-3.3 for this function.
The function does not do what I expect. For example, if we have two mpi
task and each contains one local square matrix with n rows, I want to
create a global square matrix with 2n rows. This function create a
non-square matrix of size 2n x n.
Thomas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120904/e9cd13cc/attachment.html>
