[petsc-users] Is MatSetUp required with MatCreateNormal and MatCreateMPIAIJWithSplitArrays?
Thu Nov 29 11:25:31 CST 2012
On Nov 29, 2012, at 9:48 AM, Mihai Alexe <malexe at vt.edu> wrote:
> Hello all,
> I am creating a large rectangular MPIAIJ matrix, then a shell NormalMatrix that eventually gets passed to a KSP object (all part of a constrained least-squares solver).
> Code looks as follows:
>  //user.A_mat and user.Hess are PETSc Mat
>  info = MatCreateMPIAIJWithSplitArrays( PETSC_COMM_WORLD, *locrow, *loccol, nrow,
> 				  *ncol, onrowidx, oncolidx,
> 				  (PetscScalar*) onvals, offrowidx, offcolidx,
> 				  (PetscScalar*) values, &user.A_mat ); CHKERRQ(info);
>  info = MatCreateNormal( user.A_mat, &user.Hess ); CHKERRQ(info);
>  info = MatSetUp( user.Hess );
> Is MatSetUp() required for A or Hess to be initialized correctly? Or some call to MatSetPreallocation?
   No you shouldn't need them.   Try with valgrind   http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
  Barry
> My code crashes after displaying (with -info -mat_view_info):
> [0] PetscCommDuplicate(): Duplicating a communicator 47534399113024 67425648 max tags = 2147483647
> [0] PetscCommDuplicate(): Duplicating a communicator 47534399112000 67760592 max tags = 2147483647
> [0] MatCreate_SeqAIJ_Inode(): Not using Inode routines due to -mat_no_inode
> [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 8920860 X 1508490; storage space: 0 unneeded,34572269 used
> [0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
> [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 615
> Matrix Object: 1 MPI processes
>   type: seqaij
>   rows=8920860, cols=1508490
>   total: nonzeros=34572269, allocated nonzeros=0
>   total number of mallocs used during MatSetValues calls =0
>     not using I-node routines
> [0] PetscCommDuplicate(): Using internal PETSc communicator 47534399112000 67760592
> [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 8920860 X 18752388; storage space: 0 unneeded,1762711 used
> [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 349
>   type: seqaij
>   rows=8920860, cols=18752388
>   total: nonzeros=1762711, allocated nonzeros=0
>   type: seqaij
>   type: seqaij
> [0] VecScatterCreateCommon_PtoS(): Using blocksize 1 scatter
> [0] VecScatterCreate(): General case: MPI to Seq
> [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 8920860 X 38109; storage space: 0 unneeded,1762711 used
> Matrix Object: 160 MPI processes
>   type: mpiaij
>   rows=131858910, cols=18752388
> The code ran just fine on a smaller (pruned) input dataset.
> I don't get a stacktrace unfortunately... (running in production mode, trying to switch to debug mode now).
> Regards,
> Mihai
