[petsc-users] Which IDE you use to develop petsc application
Karl Rupp rupp at mcs.anl.gov
Tue Nov 27 14:32:11 CST 2012
Hi Anton,
thanks for the detailed instructions. I will make sure that they are
moved to an appropriate place :-)
Best regards,
Karli
On 11/22/2012 12:07 PM, Anton Popov wrote:
> As promised, description files how to use Eclipse PTP for
> development/parallel debugging of PETSc applications are in the attachment.
> I recommend installing debug versions of MPICH2, PETSc, parallel SDM
> debugger, and valgrind (if necessary) to /opt directory
> Just follow the instructions.
> Cheers,
> Anton
> On 11/18/12 4:43 PM, Fande Kong wrote:
>> yeap, It sounds very interesting. Could you please give some
>> instructions on how to use eclipse link both Petsc and MPI?
>> On Sat, Nov 17, 2012 at 3:08 AM, Anton Popov <popov at uni-mainz.de
>> <mailto:popov at uni-mainz.de>> wrote:
>>     On 11/16/12 2:03 AM, Barry Smith wrote:
>>             Because we are developing PETSc as a library that must be
>>         portable to many users most people who develop the PETSc
>>         libraries do not use a IDE.
>>             For someone who is writing AN APPLICATION that uses PETSc
>>         (especially an application with guis) it makes sense to use an
>>         IDL to do that development. What you chose should depend on
>>         what machine you develop on and what your are experienced with
>>         or comfortable with. In the users manual we try to provide
>>         some information on using PETSc from a variety of IDEs. We are
>>         interested in collecting information on using PETSc from IDEs
>>         and improving our documentation.
>>     I managed Eclipse PTP on Mac OS (probably the same on Linux).
>>     Provided that a debug (preferably valgrind-clean) version of
>>     MPICH2 library with MPD process manager can be installed, Eclipse
>>     Indigo can be easily configured for using PARALLEL SDM debugger
>>     with PETSc applications.
>>     If you're interested, I can send detailed configuration / setup
>>     instructions.
>>     Anton
>>             Barry
>>         On Nov 15, 2012, at 4:52 PM, Fande Kong <fd.kong at siat.ac.cn
>>         <mailto:fd.kong at siat.ac.cn>> wrote:
>>               Got it. Thanks.
>>             On Thu, Nov 15, 2012 at 3:49 PM, Matthew Knepley
>>             <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>             On Thu, Nov 15, 2012 at 5:41 PM, Fande Kong
>>             <fande.kong at colorado.edu <mailto:fande.kong at colorado.edu>>
>>             wrote:
>>                 Hi all,
>>                 In order to improve development the efficient of the
>>                 petsc application
>>                 development, which IDE are you using?
>>             Emacs+gdb.
>>                Matt
>>                 Regards,
>>                 Fande Kong
>>                 Department of Computer Science
>>                 University of Colorado at Boulder
>>             What most experimenters take for granted before they begin
>>             their
>>             experiments is infinitely more interesting than any
>>             results to which
>>             their experiments lead.
>>             -- Norbert Wiener
>>             Fande Kong
>>             ShenZhen Institutes of Advanced Technology
>>             Chinese Academy of Sciences
>> Fande Kong
