[petsc-users] When pull the petsc-dev for update:Connection timed out
Sun Nov 25 23:07:58 CST 2012
Check again whether ex45.c contains DMSetInitialGuess.
On Mon, Nov 26, 2012 at 5:44 AM, Alan <zhenglun.wei at gmail.com> wrote:
>  Thanks Dr. Brown,
>     What I did are:
> hg pull -u: under /petsc-dev
> hg update
> make all test
> what else should I do? how can I check the PETSc version in my computer?
> thanks,
> Alan
> On Mon, Nov 26, 2012 at 2:16 AM, Zhenglun (Alan) Wei <
>> Dear folks,
>>     Here are some problems when I'm using the new PETSc and tried to run
>> src/ksp/ksp/example/tutorial/ex45.c
>> 1, when I compile it, it says that 'DMSetInitialGuess' can not be found.
>> So, I commented it out; however, this command still appears in
>> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex45.c.html.
>> Therefore, I wonder if my PETSc has not been updated correctly.
>  You still don't have a current clone of petsc-dev. The HTML file is from
> the release version, in which that function was deprecated but still
> present. Look at the petsc-dev docs if that's what you're using.
>> 2, in old version code, I implemented a post-processing code using:
>>   ierr = DMDAGetCoordinateDA(da, &cda);
>>   ierr = DMDAGetGhostedCoordinates(da, &gc);
>>   ierr = DMDAVecGetArray(cda, gc, &coors);
>>     in order to get the locations of 'coors' stored in 'DM da'. However,
>> the current version seems does not have 'DMDAGetCoordinateDA' and
>> 'DMDAGetGhostedCoordinates'. Then, what should I do to get the 'coors'?
>> Specifically, what should I do to get 'Vec gc'.
>  These routines were promoted.
>  http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
>> thanks,
>> Alan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121126/1d24c4bd/attachment.html>
