[petsc-users] How to choose a suitable restarted m when using GMRES?
w_ang_temp w_ang_temp at 163.com
Sat Nov 24 11:14:47 CST 2012
>> 2012-11-25 00:46:29,"Jed Brown" <jedbrown at mcs.anl.gov> 写道:
>>On Sat, Nov 24, 2012 at 5:38 PM, w_ang_temp <w_ang_temp at 163.com> wrote:
>>    So, is there no effective way to determine a suitable m? Only by doing lots of tests to find
>>an appropriate value in practical application? Or something need to be noticeable of using GMRES
>>with an effective way?
>Just use the default until it doesn't converge well or until you run out of memory. You're not going to have any theory here unless you know a lot of about your >problem and want to think carefully about it, neither of which seem to be true, and even if it was, it's unlikely to be practically important. If you want some >entertainment, read Mark Embree's 2003 SIAM Review article "The tortoise and the hare restart GMRES".
 This article is interesting and helpful. Thanks.
>Consider using MINRES instead of GMRES.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121125/e1793631/attachment.html>
