[petsc-users] KSPSetUp does not scale
Thomas Witkowski thomas.witkowski at tu-dresden.de
Mon Nov 19 04:26:48 CST 2012
I have some scaling problem in KSPSetUp, maybe some of you can help me
to fix it. It takes 4.5 seconds on 64 cores, and 4.0 cores on 128 cores.
The matrix has around 11 million rows and is not perfectly balanced, but
the number of maximum rows per core in the 128 cases is exactly halfe of
the number in the case when using 64 cores. Besides the scaling, why
does the setup takes so long? I though that just some objects are
created but no calculation is going on!
The KSPView on the corresponding solver objects is as follows:
KSP Object:(ns_) 64 MPI processes
   type: fgmres
     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
     GMRES: happy breakdown tolerance 1e-30
   maximum iterations=100, initial guess is zero
   tolerances:  relative=1e-06, absolute=1e-08, divergence=10000
   right preconditioning
   has attached null space
   using UNPRECONDITIONED norm type for convergence test
PC Object:(ns_) 64 MPI processes
   type: fieldsplit
     FieldSplit with Schur preconditioner, factorization FULL
     Preconditioner for the Schur complement formed from the block
diagonal part of A11
     Split info:
     Split number 0 Defined by IS
     Split number 1 Defined by IS
     KSP solver for A00 block
       KSP Object:      (ns_fieldsplit_velocity_)       64 MPI processes
         type: preonly
         maximum iterations=10000, initial guess is zero
         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
         left preconditioning
         using DEFAULT norm type for convergence test
       PC Object:      (ns_fieldsplit_velocity_)       64 MPI processes
         type: none
         linear system matrix = precond matrix:
         Matrix Object:         64 MPI processes
           type: mpiaij
           rows=11068107, cols=11068107
           total: nonzeros=315206535, allocated nonzeros=315206535
           total number of mallocs used during MatSetValues calls =0
             not using I-node (on process 0) routines
     KSP solver for S = A11 - A10 inv(A00) A01
       KSP Object:      (ns_fieldsplit_pressure_)       64 MPI processes
         type: gmres
       PC Object:      (ns_fieldsplit_pressure_)       64 MPI processes
         type: none
         linear system matrix followed by preconditioner matrix:
           type: schurcomplement
           rows=469678, cols=469678
             Schur complement A11 - A10 inv(A00) A01
             A11
                 type: mpiaij
                 total: nonzeros=0, allocated nonzeros=0
                   using I-node (on process 0) routines: found 1304
nodes, limit used is 5
             A10
                 type: mpiaij
                 rows=469678, cols=11068107
                 total: nonzeros=89122957, allocated nonzeros=89122957
             KSP of A00
MPI processes
                 type: preonly
divergence=10000
processes
                 type: none
                   type: mpiaij
             A01
                 type: mpiaij
                 rows=11068107, cols=469678
                 total: nonzeros=88821041, allocated nonzeros=88821041
           type: mpiaij
             using I-node (on process 0) routines: found 1304 nodes,
limit used is 5
     type: mpiaij
     rows=11537785, cols=11537785
     total: nonzeros=493150533, allocated nonzeros=510309207
Thomas
